Old 08-18-2001, 01:43 PM   #1
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Default 22mm rear sway bar club please stand up.
I am now a member of the 22mm rear sway bar club with the addition of solid end links, who else has their bar set at 22?
The car feels so far alot flatter in the corners, havent gotten the arse out yet, but I have never been able too and that is my goal. I think 22 is going to be a good mach for my ver 5 suspension.
Anyone else with a similair set up, how do you like? So far all ive ever heard is 22mm? are you nuts! your gonna die. Well...I guess ill take that chance.
Jay McDade
Tri-State Meet Whore
Auto Tech--Lincoln/Mercury/Jaguar
www.hometown.aol.com/impreza25rs2000
Old 08-18-2001, 01:52 PM   #2
Weasel 555
world rally chucklehead
Member#: 4168
13 ST
Black with Sparkely bits
if u r gonna die...can i have your rs
Weasel 555 is offline   Reply With Quote
Old 08-18-2001, 02:57 PM   #3
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
sure you can have the crumpled up paper weight... hehe (knock on wood)
it will be a crunchy crispy RS! lol knock on wood again!
Bad Andy!
Jay McDade
Old 08-18-2001, 04:13 PM   #4
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
I've been running my Whiteline adj. bar on 22mm since I got it, maybe 17 months ago. The arse end comes out easy, just come into a corner hot and let off the throttle just as you're initiating the turn. If your tire pressures are decent, you'll get it to come out plenty.
Old 08-18-2001, 04:26 PM   #5
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
20 up front, 22 in the back here .
Brian
AIM: captaindamorgan ICQ: 84483950
http://www.northursalia.com
http://www.imprezamods.com
http://www.scoobymods.com
Come See The Magic World Inside the Abandoned Refrigerator!
Old 08-18-2001, 05:23 PM   #6
Tuning Factory Inc.
Vendor
Member#: 3600
Stock front and 22mm Cusco rear set to max stiffness. I dig it. Still need more oversteer though.
Tuning Factory Inc. is offline   Reply With Quote
Old 08-18-2001, 05:49 PM   #7
remarcable
Member#: 2362
1999 Legacy Outback
Blue w/ Paint Chips & Mud
I'll be putting a whiteline adjustable on my outback sometime this month, I'm going to try it at 20 or 21 (if it adjusts to those) first before going all the way to 22.
With my tire pressures at 36 front 34 rear I can get the ass end around in low traction conditions pretty easily with the stock 18mm rear bar.
However on the road, the thing understeers like a drunk cow on roller skates.
I'm also running the beefy tall outback sized tires which roll roll roll and roll some more no matter how high you set the pressure.
I think I melted some of the tread today in an empty parking lot. Whoops.
Michelin Rainforce S rated tires aren't great for homebrew autoX I suppose.
remarcable is offline   Reply With Quote
Old 08-18-2001, 06:44 PM   #8
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
LMAO, now ill have that funny arse image in my head all day!
Jay McDade
Old 08-18-2001, 07:10 PM   #9
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Had the bar at 22mm with solid aluminum links for a while.. First time that I spun the car out at an autoX too...
Revision is offline   Reply With Quote
Old 08-18-2001, 07:28 PM   #10
tahrndt
Member#: 1315
Slapped it on the ol Legacy and did not even think, just bolted it up to the middle hole. I suspect when I switch over to winter tires I will adj. the bar at the same time down to 20mm.
Good Luck/
TIm
tahrndt is offline   Reply With Quote
Old 08-18-2001, 08:20 PM   #11
Tats
Member#: 5692
WTF? YES! I am
better than you!
I am picking up my whitline tomorrow @ RalliSpec. I am going to set it at 18mm. (Stock Tires and Susp.)
Tats.
Tats is offline   Reply With Quote
Old 08-18-2001, 08:53 PM   #12
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
tim you have an 18-22mm adjustable? If so the middle whole is 20mm the hole towards the front of the car is 18 and the one closest to the rear of the car is 22mm
Just a heads up, if you are in the middle hole you are running at 20mm
Tats, I had my bar at 18mm w/my stock susp. and it didnt seem to help much
Now I just need new tires, the stock re's cant handle the stiffness of the suspension, hehe o well...time to destroy them I guess.
Jay McDade
Old 08-18-2001, 09:47 PM   #13
froggert
Member#: 768
OB, volt, 911,
ram 1500, 1098s, m620
jay, i don't know which legacy tim has, but think that the 2000+ legacy bars are 20-22-24 mm.
froggert is offline   Reply With Quote
Old 08-19-2001, 01:54 PM   #14
Strider
I'm With Her
Member#: 2197
an inconvenience,
properly considered.
Hey Jay, I guess you had no problem using the stock bolts for the endlinks? Good to hear. If you're gonna head over to TGI Fridays on Wednesday, I'll probably see you there.
Later!
Jim
Strider is offline   Reply With Quote
Old 08-19-2001, 02:29 PM   #15
tsfxRS
Member#: 8442
98 2.5 RS
blur of red
I have a 20mm rear sway bar that i still have yet to put in the car. Right now my tires are rubbing a bit in the front (I just put them on yesturday) Is there a front bar I can upgrade to and do you think it would help at all with the rubbing under loaded conditions in a hard corner? Also where can i get the bar. Thanks
-Lou
tsfxRS is offline   Reply With Quote
Old 08-19-2001, 06:39 PM   #16
Tats
Member#: 5692
WTF? YES! I am
better than you!
Decided to have it shipped instead. Oh well, more waiting.
Tats.
(STILL waiting for my 22B vents to arrive, AND my Scoobysport) Both will be here soon though!
Old 08-19-2001, 09:33 PM   #17
tahrndt
Member#: 1315
Jay, Froggert is correct. The current gen. BH Legs are running alot stiffer rear sway bars than the BG models ( I think it has to do with the multi-link rear suspension vs. struts). The Whiteline Adj. bar goes from 20-24mm.
TIm
Old 08-19-2001, 10:41 PM   #18
fellfrosch7
Member#: 2389
'98 Impreza L Wagon
'90 Talon TSi AWD
Stock up front, 22mm in the back since the day I got it. Didn't bother "trying out" the 18 or 20mm settings... Maybe I'll change it to 18 during the winter. Although... if I get that Legacy wagon I think I might, I won't have to drive the RS in the winter.
fellfrosch7 is offline   Reply With Quote
Old 08-19-2001, 11:05 PM   #19
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
sorry bout the mix up tim hehe, I had that in the back of my mind too, mmmm yummmy 24 mm
Jim sorry I didnt reply to your pm yet, Ive been busy, got the endlinks, the other day, and the stock bolts worked fine, thanks again
Im gonna try and make to the meet wed, I may be late, my crew from our local wed supper meets will be down there, and Ill call them when I get of court...yup court...dam tickets errrrr!!!! I forgot I had court that night...I still try and make it.
Jay McDade
Old 08-20-2001, 09:46 AM   #20
skidplatez
Member#: 1575
2011 WRX Premium
Blackest Black
Default It's you tires! hehehehe
If you get new tire you will notice a huge difference in various swaybar settings right now with the REsuck92s you are giving away roll stiffness in the sidewall. stiffer tires are like having one more (higher) swaybar setting. That is why some folks change the bar and say " hey nothing happened" and some folks (with good tires) say " OMG I looped my car!"
but enough of that I have DMS Golds and my Whiteline bar set on 22! (with Falken Azenis tyres)
skidplatez is offline   Reply With Quote
Old 08-20-2001, 11:01 AM   #21
Opie
Floresbian
Member#: 470
2016 Legacy 3.6R
'15 FXT, '16 XV, '99 RS
Talking
Mmmmmm 19mm front (Stock w/ploy bushings & Kartboy Inserts), 21mm rear (SPO w/solid mounts & endlinks, all poly bushings)
Opie is offline   Reply With Quote
Helix 22mm Rear Sway Bar & Rear Endlinks 3 Day Sale! Gruppe-S Suspension/Brakes/Handling 2 11-30-2004 12:40 AM
where to buy 22mm rear sway bar bushings (urethane) Tobey Brakes, Steering & Suspension 0 08-06-2004 01:06 PM
Cusco 22mm Rear Sway Bar- opinions? Handsdown Brakes, Steering & Suspension 30 07-28-2004 10:30 PM
cusco 22mm rear sway bar Sokudo Private 'Wanted' Classifieds 3 06-05-2004 03:00 PM
WTB: 22mm Rear Sway Bar off 02 WRX Sedan mandrOid North West Impreza Club Forum -- NWIC 4 11-18-2002 02:00 PM
