Old 08-29-2005, 11:19 PM   #1
sheikthin
Member#: 77592
* missdawn = MILF
now with 25% less pistons
Default JDM V7 STi heads vs. JDM non-STi heads
this may have been covered before somewhere but i have to order these soon and need to know the differences before i make this jump. i have the opportunity to get V7 JDM non-sti heads with avcs for $800 canadian. what are the downsides to this vs. the JDM STi heads? i'm sure they're still better than the USDM wrx heads that i already have and would rather not put on the STi shortblock i just got. what will the compression be with these on there? are they worth getting since i'm on a budget or should i save up for 6 months and get the JDM STi heads for $2k or so.
sheikthin is offline   Reply With Quote
Old 08-30-2005, 10:37 AM   #2
sheikthin
Member#: 77592
* missdawn = MILF
bump bump bump
Old 08-30-2005, 12:31 PM   #3
dvang
Member#: 84188
05 legacy
caravan full of kids now
from my understanding there the same a s regulaar wrx heads with avcs thats all
dvang is offline   Reply With Quote
Old 08-30-2005, 01:55 PM   #4
SooobieSnack
Member#: 44380
Originally Posted by dvang
from my understanding there the same a s regular wrx heads with avcs thats all
No... The Ver 7 spec C heads have larger intake ports, stiffer valve springs, a more agressive cam profile, an 8k rev limit and AVCS.
SooobieSnack is offline   Reply With Quote
Old 08-30-2005, 02:35 PM   #5
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
Originally Posted by SooobieSnack
No... The Ver 7 heads have larger intake ports, stiffer valve springs, a more agressive cam profile, an 8k rev limit and AVCS.
I believe the original poster was inquiring about V7 WRX heads, not STI.
verc is offline   Reply With Quote
Old 08-30-2005, 04:31 PM   #6
SooobieSnack
Member#: 44380
JDM Version 7 STI - AVCS, larger intake ports, 8k redline, and slightly more agressive cam profile than USDM WRX.
-Hill
Old 08-30-2005, 04:38 PM   #7
Ace009
Member#: 70353
2004 WRX
read much?
here, try again.
Ace009 is offline   Reply With Quote
Old 08-30-2005, 05:22 PM   #8
SooobieSnack
Member#: 44380
No I can't read or write and I was raised by wolves in northern Montana... A little more info never hurt anybody.
Old 08-30-2005, 05:28 PM   #9
sheikthin
Member#: 77592
* missdawn = MILF
the question is what is the difference between v7 jdm sti heads and v7 jdm non-sti heads. the vendor that i might buy these from say they're non-sti v7 jdm heads. i know the jdm sti heads have larger valves, more aggressive cams, higher rev limit and avcs, but what do the v7 non-sti jdm heads have.
Old 08-30-2005, 05:29 PM   #10
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
supposedly, v7 jdm non-sti heads are similiar to jdm sti heads in terms of ports, but don't have as aggressive cams and valvetrain
petawabit is offline   Reply With Quote
Old 08-30-2005, 05:53 PM   #11
sheikthin
Member#: 77592
* missdawn = MILF
same valves and springs different cams? or different valves, springs and cams all together
Old 08-30-2005, 08:34 PM   #12
Starkiller
Member#: 82741
2007 350Z Silver
Aren't they just regular USDM WRX heads w/AVCS? I was under the assumption that the JDM STI heads had the good stuff.
Starkiller is offline   Reply With Quote
Old 08-30-2005, 11:47 PM   #13
02Toyowrx
Member#: 56520
anyways $800 before you decide to get those from Canada talk to Steve at Innovative automotive im sure he has a pair layin around. What ECU do you plan to use? Also Innovative Auto has a direct plug in harness to use the AVCS in your car.
02Toyowrx is offline   Reply With Quote
Old 08-31-2005, 12:05 AM   #14
cronic
Member#: 9749
Ok let me add what i know.. The JDM WRX comes with the same head casting as the USDM Wrx, HOWEVER i had a jdm wrx in my Gc which had big port heads. It seems subaru will throw together whatever they have sitting around when building cars.. The JDM WRX also has a 7400rpm redline so possably the valvetrain is a bit better, but i can not confirm that.
I would try and get a pic of the heads from your supplier and post them.. Are you getting them from 4star?
cronic is offline   Reply With Quote
Old 08-31-2005, 12:22 AM   #15
sheikthin
Member#: 77592
* missdawn = MILF
yeah they're from fourstar. if they're just like the usdm heads but with avcs, then i'll just save up to get the sti heads from innovative. i'll just re-use my usdm wrx heads for now since there's no damage to them. sounds like that would just be a waste of money and not be the right parts for my solution. so in a few months i'll get the jdm sti v7 heads for my new EJ257 with 750cc injectors, fp green, turboxs front mount, utec and other little goodies. and then i'll concentrate on a 6spd swap or 5spd ra....still deciding and doing research on that one. thanks again for the help guys.
Old 10-02-2005, 10:51 PM   #16
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
+1
Just today i found out my JDM EJ205 has big ports.
RS_to_WRX_swap is offline   Reply With Quote
JDM V7 STi TMIC vs USDM STi TMIC crystalhelix Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 01-13-2006 03:16 PM
jdm ver. 8 sti heads vs usdm sti heads Peeblesmx445 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 56 12-17-2005 09:00 PM
V8 heads vs USDM STi heads 2000wrx General Community 5 05-10-2005 02:53 PM
V7 Sti Strut vs V8 STI struts -any diffrent? DickWRX Brakes, Steering & Suspension 3 02-08-2005 06:10 PM
ver 8 heads vs. USDM STi heads ebeck Subaru Conversions 10 04-17-2004 12:45 PM
