Old 08-30-2005, 04:28 AM   #1
silver03T
Member#: 88691
Default 03 vs 04 motor differences?
is there any difference when the body style changed for the WRX in terms of the 2.0L-T power plant? did anything change? tried searching, couldnt find anything.
silver03T is offline   Reply With Quote
Old 08-30-2005, 05:04 AM   #2
vinceGC8
Member#: 72263
2008 Impreza STi
Dark Grey Metallic
from what ive seen everything is pretty much the same. the ecu might be slightly different(ie closed and open loop switchover). im sure there probably a few small changes that are almost unnoticible but i only know of this one.
vinceGC8 is offline   Reply With Quote
Old 08-30-2005, 01:57 PM   #3
silver03T
Member#: 88691
mainly concerned on the motor end.
my 03 threw a rod and i found a 04 motor for sale.....
Old 08-30-2005, 03:53 PM   #4
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
No motor differences. A few ECU changes an extra sensor here or there and other minor stuff, but the internals are the same.
Old 08-30-2005, 04:12 PM   #5
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
What engine model is in the 2003s, 2004s (EJxx designation)?
specialev is offline   Reply With Quote
Old 08-30-2005, 04:18 PM   #6
nate.the.great
Member#: 72031
when did the fuel filter migrate into the tank? 04 or 05?
nate.the.great is offline   Reply With Quote
Old 08-30-2005, 04:28 PM   #7
thesmokingman
Member#: 17751
2002 WRX Wagon
944 Turbo track
04+ have better heads.
thesmokingman is offline   Reply With Quote
Old 08-30-2005, 04:32 PM   #8
silver03T
Member#: 88691
if i were to slap an 04-05 motor into my 03 and run it on my 03 ECU, will it run normal?
do the plugs line up?
Old 08-30-2005, 05:00 PM   #9
Student Driver
Member#: 65161
2002 2.5RS, AW
I can taste teh suck
I read that the valvetrain was slightly lighter on the 04 somewhere around here.
Student Driver is offline   Reply With Quote
Old 08-30-2005, 06:07 PM   #10
bofh
Member#: 59287
2007 WRB WRX
2004 WRB WRX (RIP)
Dude... You could slap your 03 ECU in my 04, and it would run better! If you tried for an 03 engine in my car, I might have to jack with a sensor or two... You will be fine.
bofh is offline   Reply With Quote
Old 08-30-2005, 09:20 PM   #11
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
EJ20 is the designation.
mcowger is offline   Reply With Quote
Old 08-30-2005, 11:02 PM   #12
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
Am i correct in that the 04's and up use the shimless design for the lifters.. The 02's and 03's use the shims?
I know the 04 uses shimless. Not sure when that changed though.
subbyspeed is offline   Reply With Quote
Old 08-30-2005, 11:39 PM   #13
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
I believe you are correct - 04+ have shimless buckets
Old 08-31-2005, 01:45 AM   #14
bofh
Member#: 59287
2007 WRB WRX
2004 WRB WRX (RIP)
Didn't that actually change in late 03 along with the 17mm sway bar, and wider gear set?
02/03 vs. 04+ WRX - Any mechanical/technical differences? Fury161 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 52 04-26-2005 09:46 AM
02/03 vs. 04/05 WRX ECU and wiring connectors different? (pics) xcntrk75 Subaru Conversions 4 03-18-2005 09:01 PM
CD and frontal area differences between 02/03 vs 04+ and sedan vs wagon??? BIGSKYWRX Brakes, Steering & Suspension 17 11-03-2004 11:25 PM
03 Vs 04 Suspension differences Bakes5 Baja Forum 2 04-29-2004 03:12 PM
Different side airbags in 03 vs. 04? riptide2 General Community 3 09-04-2003 01:35 PM
