Welcome to the North American Subaru Impreza Owners Club Thursday August 27, 2015
Old 08-30-2005, 04:31 AM   #1
SubyRSdriver
Visiting NASIOC Timeout
Member#: 94839
2005 2.5 RS
Default question about moding my stock intake vs. buying the injen CAI
Well… I have been seriously considering purchasing the Injen CAI for my ‘05 RS when ptuning gets them back in stock. BUT! After some pretty extensive review, it seems the general consensus is.. even though Injen says you can get up to 17-20 HP gains.. The intake is really more of a noise thing than a real performance mod. SO! What I was thinking of doing is… removing the silencer box on top and the factory plastic piping all the way down to the stock air box. Leaving the piece of pipe with the MAF sensor which bolts onto the air box in place. Then going to a machine shop and having them custom make an aluminum pipe like an intake… which goes from the intake manifold blots onto the bolts from the silencer and connects to the pipe with the MAF sensor to the air box. This pipe will also include the little nipples for the vacuum hoses as well. If I gain 1-2 horsepower cool! If not cool! But this should sound like an intake since the silencer is being taken off right?? If you could let me know what you thing of this mod I would be grateful? I just cant see paying like 230+ for the Injen CAI when I could do this for prob under 100 dollars. Plus I have a K&N filter in my air box as well! Thanks in advance andy
SubyRSdriver is offline   Reply With Quote
Old 08-30-2005, 05:05 AM   #2
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
they sell something just like what you described but i forget were to find it here is what it looks like and what its called i would help more but i really need some sleep http://subarureview.com/showreview.php?id=355
99subi is offline   Reply With Quote
Old 08-30-2005, 06:53 AM   #3
X4 SRT
Member#: 40636
2001 2.5 RS Coupe
Lame! Why would you want to make your car sound like you have an intake when you don't? If you want some gains spend the money on an intake. If you want your car to make cool sounds then buy one of those fake blow off valve sound systems on ebay.
X4 SRT is offline   Reply With Quote
Old 08-30-2005, 07:55 AM   #4
FriedIceCream
Member#: 84154
2010 S&M WTF
Trans Purple
get the real intake. its sorta like welding a bigger tip on your existing muffler...g-h-e-t-t-o....
FriedIceCream is offline   Reply With Quote
Old 08-30-2005, 10:57 AM   #5
kaisersouse
Member#: 85900
2001 Forester S
unless that pipe is going to run thru your fender wall (making it cold-air) i dont see the point...but to each their own!
kaisersouse is offline   Reply With Quote
Old 08-30-2005, 11:24 AM   #6
Lethargic1
Member#: 20998
Good point. I pretty much agree with everyone else. You might as well do it right and buy a nice CAI. At least they make them for your car. Some of us have more difficulty finding such things
Lethargic1 is offline   Reply With Quote
Old 08-30-2005, 10:22 PM   #7
FromEvoToRS37
Member#: 91396
2015 BRZ Series.Blue
haha I've seen those, aw I miss my (real) bov ssssssssss pssshhhhhh
FromEvoToRS37 is online now   Reply With Quote
Old 08-30-2005, 11:18 PM   #8
zEy^2.5RS
Member#: 84927
2011 WRX
Satin White Pearl
zEy^2.5RS is offline   Reply With Quote
Old 08-30-2005, 11:21 PM   #9
wagonman
Member#: 971
buy the cobb intake and call it a day.
wagonman is offline   Reply With Quote
Old 08-30-2005, 11:51 PM   #10
Sudafed
Member#: 70090
2002 2.5 RS
Default agreed
agreed. fork the extra money and get something with proven results. intakes are and never will be just about sound...
Sudafed is offline   Reply With Quote
Old 08-31-2005, 12:42 AM   #11
zEy^2.5RS
Member#: 84927
2011 WRX
Satin White Pearl
COBB don't make an intake for the 05's!!! I'd go with the Injen.. most, if not all, people have had postive responses after buying it.
Old 08-31-2005, 02:49 AM   #12
SubyRSdriver
Member#: 94839
2005 2.5 RS
Hey! thanks for all the comments.... someone said something about if I dont drop it into the fender wall what's the point.. sorry.. forgot to mention I put a Ver. 8 STI hood and scoop on my RS and the engine bay is prob cooler than the in the fender wall... that scoop moves some massive amounts of air.. anyhow.. i'm most likey going to put a real intake on there! short ram though because of the scoop..
Old 08-31-2005, 06:44 AM   #13
X4 SRT
Member#: 40636
2001 2.5 RS Coupe
You're crazy if you think your going to get cooler air with a short ram becuse your car now has a hood scoop. Get something that goes down to the fender well. Thats where all the cold air is going to be.
Old 08-31-2005, 02:30 PM   #14
wifeys_scoob
Member#: 82248
08 Forester XT
all that scoop is going to do is give you more drag than cooling. if its cooling anything its cooling the intake manifold....not much would get to a short ram intake. put a reverse cowl in place of the scoop so it draws out the hot air instead of ramming cold air in, and put a CAI through the fender wall. you can get a brake vents to replace the fog light covers (if you dont have fog lights already in place) which will blast more cold air to the CAI than a scoop would to a short ram lying right behind your radiator.
i had a short ram in my car and it was horrible, even though i got it for free. no point in even spending the money there. i've had more power gains with the 05 injen intake than anything thus far.
wifeys_scoob is offline   Reply With Quote
Old 08-31-2005, 11:53 PM   #15
SubyRSdriver
Member#: 94839
2005 2.5 RS
yea.. I can def understand what you are saying and that does make good sense because that is kinda far from the scoop. BUT! I am seriously considering taking the piece from my OEM air system with the MAF sensor and having the inlets for the vac hoses put on the piece that will holf the cone filter.. therefore mt short ram will be like 5 inches long off the throttle body and the cone will be sitting right under the hood scoop... I think that would be pretty effetive.. what do you guys think?
Old 09-01-2005, 02:13 AM   #16
X4 SRT
Member#: 40636
2001 2.5 RS Coupe
You obviously have your mind made up on what you're going to do. You aren't really listening to what anyone is trying to tell you, so just go and do whatever it is you want. Good luck, and happy modding.
Old 09-01-2005, 02:23 AM   #17
Lethargic1
Member#: 20998
This advice seems to make a lot of sense, but it is your car. Do what you want with it. If you want to mount a short Ram then do it. You could always take it off and put it back to stock. Let us know how it works out.
Old 09-01-2005, 03:15 AM   #18
fluenceINc.
Member#: 93086
04 2.5 rs
san remo red
get the aem set up, i got it and it did give me about 10 hp
fluenceINc. is offline   Reply With Quote
Old 09-01-2005, 03:30 AM   #19
SubyRSdriver
Member#: 94839
2005 2.5 RS
Hmmm... I guess I either was misunderstood or totally came off wrong. I am totally listening to everything everyone has to say. I am new to the forum but I think this is the coolest thing ever. I would not think to do anything to my car without seeing what others on here think because I 100% respect everyone on here and want to thank all of you for taking the time to respond to my questions... I am def. Greatful! I also do not have my mind made up seriously taking into consideration everything everyone is saying.. I dont wanna come off as a NOB lol and I wouldn't waste your time if I didnt care!
Also you kinda told me off... but you didn't answer my question at all. So I'm gonna ask it again since i do care what you have to say. I totally agree that on a conventionally set up 05 2.5 RS the best way to go with the intake is into the fender wall.. we agree and if my car was conventional I wouldnt even ask id just do it. But! My question was..... since I have an STI hood scoop.... If I were to have an highly certified professional build me a custom short ram pipe about 5 inches in length utilizing my stock piece of pipe which has the MAF sensor... and this setup were to have the cone filter siting right inside the bottom
of the hood scoop.. just like the intercooler on a wrx... and have that constant rushing cooler outside air.. plus when idling it can be sucking in air from outside too... do you thing that would be fairly sufficient as an intake..??
Old 09-01-2005, 07:03 PM   #20
X4 SRT
Member#: 40636
2001 2.5 RS Coupe
Okay, okay. You're right I did kind of tell you off. Here is the truth. You should just buy an Injen intake for your car. Yeah it cost some money, but it has proven gains, and a lot of people on this board really seem to like it for their 05.
If you make a short ram for your car you better be sure that thing is very secure and won't move around. Your car has a MAF sensor and not a MAP sensor. If the MAF sensor is moving around, then the sensor will not get the correct airflow readings that it needs, and could cause bad things to happen to your motor.
Now as for the hoodscoop providing cool air for the intake. Not going to happen. The hoodscoope is designed to direct cool air over an intercooler. With the turbo cars there is a splitter under that scoop that helps direct air over the intercooler, with out that splitter the air just goes in and tumbles around in who knows what direction. So that means you aren't going to be getting any cool air over your intake. Oh, and when idleing that hoodscoop doesn't do crap. There is not hot air escaping from that thing at a stand still. So with that said the fender well is the best place for cold air.
My first road dyno - stock intake vs hybrid intake aurtini Normally Aspirated Powertrain 21 05-09-2009 01:07 AM
Help QUICK! Question about putting my Protuned map back onto the car... 2005wrbluesti AccessPort 7 01-13-2007 10:16 PM
stock intake vs CAI vs short ram intake STI RAGE Texas Impreza Club Forum -- TXIC 26 01-10-2007 10:41 PM
FS: Wheels: Ray's G-Games and Stock STI, Kartboy Shifter + Knob, Injen CAI 05 RS gharari Private 'For Sale' Classifieds 38 11-04-2005 01:48 AM
FS: Wheels: Ray's G-Games and Stock STI, Kartboy Shifter + Knob, Injen CAI 05 RS gharari South West Impreza Club Forum -- SWIC 0 10-17-2005 05:12 PM
