Old 08-30-2005, 09:41 AM   #1
02_Forester
Member#: 11015
'06 Volvo V70R
Sonic Blue
Default Calculating miles traveled vs speedo inaccuracy
My 225/45 18s run about 2mph slower than what the speedo actually indicates. Does this impact the actual miles traveled?
If so, is there a mathmatical calculation I could use to determine the actual miles driven vs what is being displayed?
thanks.
02_Forester is offline   Reply With Quote
Old 08-30-2005, 11:17 AM   #2
Howl
Member#: 57830
Your speedo and odo work off the same gearing. The gearing is set at the factory and is usually a bit fast with OEM tires (speedo and odo read high). How much it's off depends on the size of your tires. Even tire wear can affect your odo/speedo over time. That's why TSD rally people use adjustable odos.
I found that my TS with 195/60-r15's was about 3% off. With 205/55-r16's it's about 0.5% off.
The formula is simply a percentage. If your odo/speedo is fast by 1% and your speedo reads 50mph you are actually travelling at 49.5mph. If your odo says you've travelled 1,000 miles you've actually travelled 990 miles.
Howl is offline   Reply With Quote
Old 08-30-2005, 11:50 AM   #3
ripvw
Member#: 27790
ripvw is offline   Reply With Quote
Old 08-30-2005, 03:53 PM   #4
02_Forester
Member#: 11015
'06 Volvo V70R
Sonic Blue
Thanks guys
My calculations show that an electron can travel much faster than light. Yes. Deus ex Machina Off-Topic 12 03-29-2006 11:29 PM
Traveling vs. Dating MeddlingKids Off-Topic 12 09-07-2004 02:07 PM
my trip reads 10.3 miles for every 10 miles traveled! Kyguy Normally Aspirated Powertrain 7 08-05-2003 11:12 AM
1/4 mile times vs road races madmmt Proven Power Bragging 1 08-04-2002 10:47 PM
any one have the link for the tire size/speedo calculator? Ghostrider#2 Brakes, Steering & Suspension 2 06-12-2002 11:34 AM
