Old 08-30-2005, 11:29 AM   #1
w chapman
Member#: 75673
Default No spark on #3 and #4 cyls?
I recently purchased a 98 Outback w/ an engine problem. It has the DOHC 2.5L . Trying to diagnose the problem.
Rented and OBD-II code reader which shows "misfire on #3 and #4 cylinders". So far I've swapped the ignitor and the coil with known good ones from my other Outback.....with no success.....still no spark on 3 and 4.
Plan to check continuity on wiring between ignitor and the coil.
I'd appreciate any other diagnostic tips.
Warren C.
w chapman is offline   Reply With Quote
Old 08-30-2005, 05:16 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Plugs and wires good? That would be the obvious place to start IMO. What is the "engine problem"?
Pat Olsen
'97 Legacy 2.5GT sedan
advice on no spark from cylinder # 3 and 4 - ignitor? supermoose Subaru Conversions 3 09-06-2013 12:35 PM
no spark on two coils william07 Service & Maintenance 0 10-23-2009 12:09 AM
ej22 no spark cyl 1 and 2 Shockster0429 Normally Aspirated Powertrain 1 06-29-2007 07:59 AM
no spark, cylinders 3 and 4 snoopyone8 Normally Aspirated Powertrain 7 05-19-2006 08:58 PM
Misfire in #3 and #4 dan avoN7 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-08-2004 12:27 PM
