Old 08-30-2005, 12:10 PM   #1
kaisersouse
Member#: 85900
2001 Forester S
Default Doing an AT fluid swap in a few days...do i NEED to change the filter?
Replacing my pink stuff with trickshift (thicker)...is it neccesary that I change the filter at the same time or can i wait until i pick one up? Also...since the trickshift is thicker will i run into issues using an OEM AT filter?
Also I assume I drain via the drain plug and refill via the tranny dipstick correct?
kaisersouse is offline   Reply With Quote
Old 08-30-2005, 12:19 PM   #2
solbey11
Member#: 89234
I recommend taking your car somewhere to have the tranny flushed. Just taking the plug out will only drain about half the fluid in the transmission. Fluid still remains in the torque converter and other places. With a flush it actually forces all of the fluid out as it refills it with new fluid. 100% new fluid. Subaru doesn't recommend replacing the filter on a normal tranny service. Only when damage has been done to the tranny and it needs to be rebuilt. I'm not sure how much fluid you will actually need to do a tranny flush, it's more than recommended though. But just a drain and refill takes about 4 qts and the actual tranny holds around 8 I think.
solbey11 is offline   Reply With Quote
Old 08-30-2005, 12:22 PM   #3
kaisersouse
Member#: 85900
2001 Forester S
what if i force air into the dipstick/fill area with the plug off? I have special fluid im putting in (6qts) and while i dont mind mixing it with the old (which is actually pretty new and in good conidtion) I'd like to get as much out without doing a total flush.
Old 08-30-2005, 01:13 PM   #4
BoneStockTS
Member#: 80670
If it's worth doing, it's worth doing right ....
BoneStockTS is offline   Reply With Quote
Old 08-30-2005, 01:14 PM   #5
kaisersouse
Member#: 85900
2001 Forester S
but if i take it somewhere they will use their own fluid right? I have my own that I want put in there...
Old 08-30-2005, 01:30 PM   #6
kaisersouse
Member#: 85900
2001 Forester S
alright im dropping the pan instead. Now i need to find a gasket....
Old 08-30-2005, 08:57 PM   #7
solbey11
Member#: 89234
Subaru uses FujiBond for their gaskets. Its a pinkish/red silicone type sealer. Dropping the pan will probably get 6 qts out of the transmission. I think when Subaru had the parking pawl recall you had to drop the pan and the solenoid body. They paid for 6 qts of fluid. If you take it to a place for a full transmission flush, tell them you have your own tranny fluid to put in it. They will probably do it.
Old 08-30-2005, 09:36 PM   #8
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
Full flush: somewhere around 11-12 quarts
Drop pan: 6 quarts or so
Remove Drain Plug: 4 quarts
And you don't need to replace the filter. Might find more answers in the Transmission Forum as well.
AJ
AJ711 is offline   Reply With Quote
Old 08-30-2005, 10:14 PM   #9
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Call your garage of choice and ask if they'll use your fluid. Is the new fluid compatible with the stock stuff?
I agree that if it's worth doing then it's worth doing right. WOuld you change 1/3-1/4 of your motor oil at a time? Probably not.
I read that it's "not recommended" to change the filter, but I'd probably do it anyhow.
Tim Sanderson is offline   Reply With Quote
2005 WRX 4eat, do I need to change the fuel filter? eurospek Service & Maintenance 12 02-24-2009 12:42 PM
So apparently you need to change the filter in your HVAC unit... perret318 Off-Topic 44 01-29-2007 02:43 PM
How often do you need to Change the rear differential fluid in a 2001 Outback Sport? chillington Service & Maintenance 6 09-02-2005 03:01 PM
having an alarm installed here in a few days, what to do first White 2.5rs Car Audio, Video & Security 4 10-17-2004 10:23 PM
Is it true that I DO NOT need to change the color discription of my car at DMV ? DannyGT Tri-State Area Forum 5 01-27-2004 05:19 PM
