Old 08-30-2005, 12:34 PM   #1
palpullero
Member#: 21170
1992 SVX, 2005 STi
Satin Pearl, CGM, 03 Baja
Default Advice: 235/45/17 or 245/45/17 on '05 STi
I am trying to decide if I either keep the same 225/45/17 size on my '05 STi or move up to 235/45/17 or even 245/45/17. Do you see any problems arising from the wider tires? I'm keeping the OEM BBS wheels.
D-Man
palpullero is offline   Reply With Quote
Old 08-30-2005, 12:41 PM   #2
boxered
Member#: 61884
Nope..you could even fit 255s
boxered is offline   Reply With Quote
Old 08-30-2005, 01:05 PM   #3
palpullero
Member#: 21170
1992 SVX, 2005 STi
Wow! 255s on an STi? Never thought it could....thanks.
D-Man
Old 08-30-2005, 01:25 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
255/40....not 255/45
Old 08-30-2005, 01:54 PM   #5
Jitenshakun
Member#: 61586
2005 STi
WI and all the goodies
So, are 235/45/17 and 245/45/17 both o.k. in terms of rubbing and the speedo on an '05 STi?
-J
Jitenshakun is offline   Reply With Quote
Old 08-30-2005, 02:11 PM   #6
waktasz
Member#: 86356
2015 s1000r
wheelie monster
245/45 is a pretty tall tire, I thinks. I thought most guys were going 235/40 instead of 235/45 too.
waktasz is online now   Reply With Quote
Old 08-30-2005, 02:18 PM   #7
Ace009
Member#: 70353
2004 WRX
Since you have 17x8 wheels, you could get away w/ 235/40 or 245/40.
Ace009 is offline   Reply With Quote
Old 08-30-2005, 02:37 PM   #8
palpullero
Member#: 21170
1992 SVX, 2005 STi
OK, so let me get this right: can I fit 235/45/17, or I need to go down to 40 as in 235/40/17? I would like to keep the same profile (45), but just make the tire wider.
D-Man
Old 08-30-2005, 02:51 PM   #9
slickvic
Member#: 29727
2003 Impreza WRX
by going from a 225/45 to a 245/40 you would be keeping almost the exact same sidewall height which I think is what you are looking for. It's a ratio to the tire width not a straight measurement.
slickvic is offline   Reply With Quote
Old 08-30-2005, 02:53 PM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
....d00d...here it is ........the STi really should have a 235/45 from the factory....there has been some proof(GPS) that the speedo reads 'off' by just about exactly the difference between a 225/45 and a 235/45.....SOOOOOooooooooo.....the STi, with it's gearing and power can use a taller tire to achieve a bit 'better' bearing.....and just the opposite is true for a WRX....which can benefit(IMO) from a 'shorter tire"
Old 08-30-2005, 03:14 PM   #11
palpullero
Member#: 21170
1992 SVX, 2005 STi
Thanks Scotty for the info. I feel I will get the 235/45/17 to be a bit taller but wider too. I also feel the STi should've come with 235 instead.
Live long and prosper...
Old 08-30-2005, 03:26 PM   #12
Jitenshakun
Member#: 61586
2005 STi
As near as I can tell the JDM STi came with 235/45/17, which makes me think that Subaru still had a pile of 225/45/17 tires to get rid of so they equipped them USDM.
Would a 245/40/17 fall in between the 225/45/17 and 235/45/17 ?
-J
Old 08-30-2005, 03:32 PM   #13
AtomicRacer
Member#: 84586
1995 Frankenpreza
2012 Tundra DC 5.7L
I run a 245/45-17 on my SSR comps (17x8.5 48 offset) and they do not rub. I ran the same tires on my factory '05 BBS wheels and they did not rub. The taller tire gives me a smoother ride and looks a ton better as it fills the wheel well up better.
AtomicRacer is offline   Reply With Quote
Old 08-30-2005, 03:58 PM   #14
Jitenshakun
Member#: 61586
2005 STi
Would the 245/40/17 rub with pinks (1/2" drop) on an 05 STi?
-J
Old 08-30-2005, 05:55 PM   #15
AtomicRacer
Member#: 84586
1995 Frankenpreza
2012 Tundra DC 5.7L
-J
I have pinks and my 245/45-17 has plenty of room. You can see it in th epics above.
-Paul
Old 08-30-2005, 07:37 PM   #16
subieworx
Member#: 47769
-J
Depends on the rims as well though. My friend has 255 40 17 Azenis 615's on Rota Torques and they rubbed the fender in th rear.
subieworx is offline   Reply With Quote
Old 08-30-2005, 10:06 PM   #17
palpullero
Member#: 21170
1992 SVX, 2005 STi
-Paul
Thanks Atomic for the info; makes me more confident to put down the money for 245s!
Old 03-07-2006, 03:15 PM   #18
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Resurrecting this thread...
AtomicRacer, What tires are you running in 245/45-17? You wouldn't happen to have the specs? Width, diameter, etc? I am thinking of trying the Nitto NT-01's for track tires and I wanted 245/40-17, but they only come in 245/45-17.
Old 03-07-2006, 05:02 PM   #19
waktasz
Member#: 86356
2015 s1000r
wheelie monster
^^ To bother atomic racer even more...your 245/45s don't rub without any fender rolling?
edit: duh you have an 05 STI with the super fenders...don't mind me
Old 03-08-2006, 07:22 AM   #20
mav1c
Hoodbridge!
Member#: 560
So is anyone else running 245/45-17 on an '05+ STI? Need to order tires soon and I want to make sure they'll fit.
Old 03-08-2006, 01:19 PM   #21
BlkWRXWag
Member#: 31821
2015 DS WRX
I have 245/45/17 on the OEM wheels on a 06 STI. No rub and I'm lowered on Cusco Zero 2 R's.
BlkWRXWag is offline   Reply With Quote
Old 03-08-2006, 01:41 PM   #22
palpullero
Member#: 21170
1992 SVX, 2005 STi
Question
Can anyone post close-up pics of 245/45/17 or even 245/40/18? Greatly appreciated if you can.
Old 03-08-2006, 02:05 PM   #23
STix66
Member#: 104433
2016 Mercedes - GLE
past cars-06 STI /13 WRX
Can anyone recommend a "certain brand" of tire @ the 245/45/17 ??
Thanks in advance for feedback....
STix66
STix66 is offline   Reply With Quote
WTB: 225/45/17 or 235/45/17 or 245/40/17 TestaRossa SCIC Private Classifieds 8 03-19-2010 12:11 AM
255/40/17 or 245/40/17? njwrx10 Tire & Wheel 11 12-23-2008 10:52 AM
245/45/17 or 245/40/17 what do you think? kg2128 Tire & Wheel 6 01-06-2006 01:37 AM
Yes or no 235 40 18 or 245 45 18 fit 2004 STI Help!! NORCAL STI Tire & Wheel 8 02-21-2005 08:51 PM
18x8.5 w/ 245-40-18 on '05 sti boost junkie Tire & Wheel 1 01-30-2005 12:27 PM
