Old 08-30-2005, 05:18 PM   #1
matthew_bh
Member#: 94873
Default GR2's + H&R on Legacy (BH) fitment issues
Hi, I'm looking into this setup......
Is this PNP setup for the BH or require some mod?
I found a bit info saying for the front I need the "FRONT IMPREZA UPPER SPRING SEATS" , but not sure is from GC or GD? what else do I need?
Oh, mine is canadian version not USDM, is there any different between the 2?
thanks in advance!
matthew_bh is offline   Reply With Quote
Old 08-30-2005, 05:26 PM   #2
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
tora would probably be your best source for this. If he doesn't post you should PM him. He seems to have tried lots of susp. combos, is in Canada, and has the same gen. car.
.02
Jared
gtwagon941 is offline   Reply With Quote
Old 08-30-2005, 06:14 PM   #3
flanders
Member#: 76382
2000 BH
BP Wannabe
I have heard the same but don't know which one. I have the same products listed but have not installed yet.
Ned
flanders is offline   Reply With Quote
Old 08-30-2005, 06:28 PM   #4
matthew_bh
Member#: 94873
so which gen of "FRONT IMPREZA UPPER SPRING SEATS" should I use? just the front? none at the rear?
For this setup (for wagon), can I use the stock top mounts? strong enough?
Old 08-30-2005, 07:03 PM   #5
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
PM tora.
Old 08-30-2005, 07:05 PM   #6
tora
Member#: 5851
09 Forester XT
+ NA Miata
It doesn't matter which perches you use. I used the 2001 Impreza ones but '02 should work just as well. You could just take the springs to the dealership and test fit. Anyways, I think they are all the same but go with either the early GD ones or late GC to play it safe.
tora is offline   Reply With Quote
Old 08-30-2005, 11:23 PM   #7
matthew_bh
Member#: 94873
cool! so I only need the FRONT upper spring seats from the GC, no need for the REAR?
So, what if I use the H&R on the stock struts, any good for the stocker? or I still need the spring seats?
Need Input on APS SR55 Fitment Issue PumpsGOTAWD Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 01-15-2007 06:19 PM
lowered Legacy w/ Wrx wheels fitment issues? Trin_Starr Legacy Forum 13 12-07-2005 07:13 PM
cusco OS front strut brace on sti. any fitment issues? Tobey Brakes, Steering & Suspension 2 02-13-2005 01:01 AM
Legacy suspension/fitment issues and what 2 do? serious Legacy Forum 0 02-13-2004 05:46 PM
Will the HKS SSQV fit on the STi IC w/o fitment issues? ScrambleBoost Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-07-2003 02:10 PM
