Old 08-30-2005, 06:27 PM   #1
GregBolby
Member#: 498
1981 jdm swapped gc
sniklfritz
Default guys what plugs are you running?
as it says
G
GregBolby is offline   Reply With Quote
Old 08-30-2005, 06:46 PM   #2
JessesTalon
Member#: 63925
95 R33 / 06 WRX
Dark Slvr / Crystal Slvr
3 NGK's 1 bosch
JessesTalon is offline   Reply With Quote
Old 08-30-2005, 08:22 PM   #3
Andursun0013
Member#: 11616
1998 2.35RS-T
2006 Baja 2007 Leg. Wagon
Originally Posted by JessesTalon
3 NGK's 1 bosch
NGK - BKR7E11 sounds right...but i wouldn't know without looking for sure
Andursun0013 is offline   Reply With Quote
Old 08-30-2005, 10:41 PM   #4
GregBolby
Member#: 498
1981 jdm swapped gc
sniklfritz
i was told the 11a where to large of a gap .44
which is what i have now
was told i need the bkr7e
which is like a .33 gap?
G
Old 08-30-2005, 10:46 PM   #5
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
BKR7E don't come pre-gapped.
I run those, at .030 gap.
B= 14mm thread diameter
K= Hex Size 5/8" w/ Projeccted Tip (ISO)
R= Resistor type construction
7= Heat Range of 7 (2 is hottest, 10 is coldest)
E= 19mm thread reach
11= .044" gap width (out of box)
http://www.kaila.net/tl125/tl125ngkcode.html
Wedge is offline   Reply With Quote
Old 08-30-2005, 11:10 PM   #6
GregBolby
Member#: 498
1981 jdm swapped gc
sniklfritz
so wedge what do you recomend and where online can i order them from?
scoobarurs "brett" is running bkr7e09 if im not mistaken
Old 08-31-2005, 03:25 PM   #7
STi-Nismo Dood
Member#: 4149
MY93 Impreza 6MT
GC8.6 Aspen White
I switched from a 9.5:1 NA Block to a WRX 8:0:1 Turbo block, but I kept my NA heads. So should I keep my old NA .44 gap or regap them to turbo block spec. of around .31? Sounds like I need a regap but more info. would be nice.
STi-Nismo Dood is offline   Reply With Quote
Old 08-31-2005, 08:11 PM   #8
JessesTalon
Member#: 63925
95 R33 / 06 WRX
Turbo cars should be gapped between .26 and .30... I haev always had my turbo cars at .28
Old 08-31-2005, 08:21 PM   #9
STi-Nismo Dood
Member#: 4149
MY93 Impreza 6MT
GC8.6 Aspen White
ok, i will try to regap it soon then. The car pings on 9 psi!! I am sure it is because I have a stock ECU, but hopefully the regap will do something positive to my bucket until I can afford it then. THANKS!
Old 08-31-2005, 08:46 PM   #10
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
I have BKR7E-9's I ordered 9's and they sent me plugs that were gapped to .36. Take that for what you will.
-Brett
ExecNav is offline   Reply With Quote
Old 08-31-2005, 09:10 PM   #11
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
If you can't find any locally, I order em from www.sparkplugs.com
I usually order a bunch of em at one time. They are pretty cheap.
Old 08-31-2005, 09:21 PM   #12
jam69007
Member#: 86968
02 WRX / 05 350Z
'11 335d
1 step colder Denso's
jam69007 is offline   Reply With Quote
Old 09-03-2005, 02:15 PM   #13
Phy6
Member#: 2219
2007 Exige S
For 04 STi, NGK one step colder: LFR7AIX from www.sparkplugs.com (good prices)
Everything runs well once it's warmed up! =)
Phy6 is offline   Reply With Quote
Old 09-08-2005, 09:13 PM   #14
CUNNINGHAM
Member#: 5563
JDM 98 GM6, 05 BP6
Porsche 955
I run 8's with a gap of .021. No issues. Plugs have been inspected a few times after a hard run and have found them to be nice and crispy.
CUNNINGHAM is offline   Reply With Quote
Old 09-08-2005, 10:08 PM   #15
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
BKR7E gapped .028
Hitokiri is offline   Reply With Quote
Old 09-08-2005, 10:44 PM   #16
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
'96 BrightonCoupeWRX-SR30
Legacy
denso gap= .030
Kawikid20o2 is offline   Reply With Quote
Old 09-14-2005, 02:38 PM   #17
TomsSVX5mt
Member#: 94810
1992 SVX 6mt
Liquid Silver
So what plugs would u suggest for a twin turboed EG33?? I already have a good idea of what I want but input is appreciated
Tom
TomsSVX5mt is offline   Reply With Quote
Big power guys, what header are you running? LeeC Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 27 08-23-2008 02:02 PM
16G guys, what injectors are you running? Umphreys448 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 07-31-2007 02:29 AM
16G guys, what boost are you running? pictureboy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 07-10-2006 03:58 PM
Ej207(v7sti) What plug are you running? DoctorNick Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-23-2005 08:12 AM
STX guys...what headers are you running? thechickencow Motorsports 14 12-02-2003 08:38 AM
