Old 08-30-2005, 07:35 PM   #1
LorenzoS
Member#: 50995
2002 WRX Wagon
Default Tire rotation question
The Subaru owner's manual says to rotate tires front / back on the same side. Conventional wisdom, including tirerack's site, suggests to rotate nondirectional tires on an AWD car using a rearward cross pattern.
It seems to me that wear would be more even switching left/right with the cross pattern. Does anyone know the reason for Subaru's recommendation? Is it simply to have the same procedure for directional and nondiractional tires?
LorenzoS is offline   Reply With Quote
Old 08-30-2005, 07:40 PM   #2
subywrx
Member#: 81858
Are you looking at the STi manual or WRX manual. Noted: 04+ WRX/STi manuals are the same but have with different section for the two.
subywrx is offline   Reply With Quote
Old 08-30-2005, 08:32 PM   #3
LorenzoS
Member#: 50995
2002 WRX Wagon
2002 Impreza manual. "Rotating the tires involves switching the front and rear tires on the right-hand side of the vehicle and similarly switching the front and rear tires on the left-hand side of the vehicle. (Each tire must be kept on its original side of the vehicle.) "
Tire Rotation question Kevin Thomas Tire & Wheel 4 11-18-2005 11:37 PM
Question about tire rotation on 05 STi with stock re070's... *help* AndrewSS Tire & Wheel 5 11-08-2005 08:29 PM
Tire rotation question? HAL1 Tire & Wheel 5 02-21-2005 08:35 PM
noob tire rotation question Hye-Teck Tire & Wheel 8 01-21-2005 10:34 PM
question about tire rotation FloridaWRX Brakes, Steering & Suspension 5 08-18-2001 07:41 PM
