Old 08-31-2005, 01:21 AM   #1
gelgel
Member#: 50522
03 rs
Default Help Please!!
I just installed my cobb catback. Everything looks fine. However, between the cat and the midpipe, it's leaking. Why is this happening? Is that oil leak? What should I do? Please help me out!
Thanks in advance!
Angel
gelgel is offline   Reply With Quote
Old 08-31-2005, 09:36 AM   #2
Pat L.I.
Member#: 20498
2006 WRX TR
if you have an exhaust leak.. the black soot-like stuff is carbon buildup from driving around with the leak. tighten the flanges, or replace the gaskets. if its a crack just get it welded shut. have the carbon cleaned off and you are good to go.
or. you have an oil leak somewhere on the engine or oil drain pan and it is spraying oil back onto your exhaust system as you drive. First thing to check is the oil drain plug. sometimes the crush washer gets bent wrong and oil leaks out of the plug area.
Pat L.I. is offline   Reply With Quote
Old 08-31-2005, 04:54 PM   #3
gelgel
Member#: 50522
03 rs
Hi Pat, thanks for your reply. It's dripping some "water-like" liquid. Also, when I tried to tighten the 2 spring bolts, they can't go as tight as with the oem midpipe. Is that a problem too?
Old 08-31-2005, 04:59 PM   #4
Pat L.I.
Member#: 20498
2006 WRX TR
Condensation is a byproduct of combustion. so you definately have a leak right where you are seeing it. is there a gasket between them? did you re-use it? or did cobb give you a new one? something isnt sealing.
Old 08-31-2005, 05:03 PM   #5
gelgel
Member#: 50522
03 rs
I reused the donut gasket cause it looks fine to me.
I thought that I can reuse the donut if it's not in a terrible condition.
but I had a new one handy as well!
Old 09-02-2005, 03:10 PM   #6
gelgel
Member#: 50522
03 rs
Thanks Pat. The problem's gone after I changed the donut!!
Need some help please cel plus more!!!! thrasher679 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-04-2010 09:21 AM
02 bugeye help...04 blob eye help..please help either or sammyswrxsti Interior & Exterior Modification 18 09-22-2008 02:39 PM
blitz gauge wiring help please PLEASE!!! :) orlandowrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-01-2002 11:36 PM
HELP PLEASE! FINAL STAGE on hella install.. please shoot me with some quick (repost) gerardchau Interior & Exterior Modification 10 02-26-2001 11:29 PM
HELP PLEASE! FINAL STAGE on hella install.. please shoot me with some quick answer! gerardchau General Forum Archive 2 02-20-2001 10:49 PM
