#1 |
Member#: 41605
SCIC
Vehicle:2003 STG 4 WRX Sedan Sonic Yellow |
Hey guys,
I just bought a pair of zero sports cf ducts (from another member) and I can't seem to install them properly. They have screws on the inside but there's nowhere for the screw to go into under the existing side marker area. I'm just a little confused. Can someone help me out?
#2 |
Member#: 58906
any pics of this item and screws?
#3 |
Member#: 41605
SCIC
here ya go...
#4 |
Totally Biased
Moderator Member#: 10104
AKIC
Vehicle:WOW! JUST WOW! I make posts disappear |
um...ur suppose to drill the hole...should have got a template from the guy too...
#5 |
Member#: 41605
SCIC
anyone have a spare template I can borrow by some chance?
#6 |
Member#: 90855
Yup, you have to drill a small hole.
Good luck getting your hand in on the driver's side to tighten the screw. It's a tight fit for someone with large hands. Anyway, I didn't have a template either, so I just lined everything up on the fender, and made my hole. Btw, use some automotive spec double sided tape to hold it all on too, as that should keep it all together if the screw comes loose. |
#7 |
Member#: 41605
SCIC
Yeah, I was wondering how hard it would be to tighten that screw. Is it better to do this through the intake hole (due to the absence of the intake elbow)? How did you exactly go about doing the driver's side?
#8 |
Member#: 60415
Vehicle:2012 WRX Silver |
Why not just dremel off the bolt threads and just use the 3m double sided tape ? My cf ducts don't have any bolt and are held on by the dst fine
#9 | |
Member#: 41605
SCIC
#10 |
Member#: 20773
SCIC
Vehicle:2002 WRX Midnight Black Pearl |
lol i'd rather mess my authentic ducts up rather than my authentic wrx
#11 |
Member#: 7138
TXIC
Take a piece of paper, hole punch as far into the center of the paper as possible. Stick the bolt through the paper. Trace the sidemarker. Remove sidemarker, cut out template.
Then position template on the fender to your liking. Drill hole where the hole punch is and then bolt the sidemarker with some 3m double sided tape (staples carries the good stuff with red backing). Take the time to make a template for each sidemarker because the bolts may not be in the exact same spot. - chris |
#12 |
Member#: 41605
SCIC
Yep, already made my template before your post but thanks for the suggestion. Hopefully, it should go well.
#13 | |
Member#: 90855
The drivers side is tougher. I tried going through where the battery sits, but I hate removing the battery. I then tried going through the inner fender, as pulling the tire is more convenient, and it worked well. Good idea on the template. I never even considered that idea. ![]() Don't forget the washers either. I used an external lock washer on the inside. That should hold well. |
#14 |
Member#: 7138
TXIC
You dont even need to pull the tire, just turn the wheel to lock then pull open the fender liner.
- chris |
#15 |
Member#: 68866
Vehicle:2008 WRX hatch WRB |
I bought some and the guy chopped off the bolt so I have them just taped on but I worry that someday they will go flying off. I used the 3m auto tape
| Thread Tools | |
| Display Modes | |
| FS: GDA or GDB Zero Sports Air duct | Corprin | Private 'For Sale' Classifieds | 2 | 10-22-2005 07:29 PM |
| zero sports CF side duct | silvscorp | Interior & Exterior Modification | 2 | 11-01-2003 05:21 PM |
| (PIC'S) 22B Bumpers, Zero Sports/Jun Body kits, Zero Sports Rep Carbon Fiber Spoilers | Revolutions Motorsports | Vendor 'For Sale' Classifieds | 86 | 08-19-2003 11:06 AM |
| Zero Sports or Flatt carbon Air ducts.. | JB1 | Interior & Exterior Modification | 0 | 08-30-2001 11:52 PM |
| zero/sports part install... | mr.subaru | Forester Forum | 7 | 05-15-2001 08:15 AM |
