Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 08-31-2005, 03:09 PM   #1
mnlegacy
Member#: 94787
Default turbo my 93
hey i am planning on boosting my 93 legacy ls, awd, 5psi. rite now it has the 2.2 n/a, i am abotu to purchase, the wrx stock upipe, downpipe, turbo, exhaust manifolds, and injectors, also a safc2 for management. what else do i need to be safe, my motor has 114,000 miles on it, no problems as of now, i am hoping to get this done soon so please help, if u have a diagram for installing the safc in my car please post a link, also do i need to water cool the turbo, if not what do i do with the extra openings on the turbo, thanks all.
mnlegacy is offline   Reply With Quote
Old 08-31-2005, 04:30 PM   #2
suby53
Member#: 59648
97' Legacy Outback
I would definently water cool the turbo. Its easy ( T off your heater core lines) and it will extend the life of your turbo. Check out the diagrams page of northursalia.com. Thats where I got the ecu pinout for my SAFC-2. I'm running a similar setup with a wrx turbo but i'm using a fmu on stock injectors. What intercooler setup are you planning on using? You'll need to get a custom oil feed line made and weld a bung in your oil pan for the oil return line. PM me for any parts you need or ?'s. Good luck with the install!
suby53 is offline   Reply With Quote
Old 09-01-2005, 01:03 PM   #3
mnlegacy
Member#: 94787
bump come on someone else help me too
Old 09-06-2005, 10:04 AM   #4
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
don't forget the crossmember and wrx exhaust manifold to go along with that up pipe.
subachad is offline   Reply With Quote
Old 09-06-2005, 11:33 AM   #5
mnlegacy
Member#: 94787
yea i got the manifold, im just gonna notch my crossmember tho. let me know if that would work or not
Old 09-06-2005, 02:33 PM   #6
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
'96 BrightonCoupeWRX-SR30
Legacy
yea notching the xmember works just fine just try to measure out the cut so you dont sacrifice too much strength. Definitly T those heater core lines for coolant its easy bc they are right there. The turbo will run much cooler even though i have seen people running them without, the turbo will not last as long in that case. Are you going to run an intercooler, I would recommend that you do in order to keep your intake temps down. The engine will run more safely if you keep those temps low.
Kawikid20o2 is offline   Reply With Quote
Old 09-06-2005, 02:40 PM   #7
gc8impreza00
Member#: 81107
2000 2.5rs
silverthorn/Carbon Fiber
u should get ahold of rallitek for questions and parts...
gc8impreza00 is offline   Reply With Quote
Old 09-06-2005, 02:45 PM   #8
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
you will want to alter the turbo for the wastegate. IIRC the spring on it is set at 8psi...
Old 09-06-2005, 04:11 PM   #9
mnlegacy
Member#: 94787
k so just get a diff spring for wastegate? and i am going to run the stock wrx intercooler, its going to be all stock wrx parts, with an safc1 or safc2 for my fuel management( they can add 50% more or less than stock) and a bigger fuel pump with wrx injectors. if theres anything else i should know please help me out. thanks. after the kit is installed i am puttin on my wrx scoop, and gettin the legacy painter pearl mica blue.
Old 09-06-2005, 08:04 PM   #10
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
Legacy
Have you thought about the oil supply? that was the hardest part of the conversion for me. right now my mechanic is tapping the block on the new motor that i am installing in my car after the origional one blew due to a oil supply problem i had.
Old 09-07-2005, 10:08 PM   #11
Rice Boi
Member#: 25811
2002 WRX (6spd)
2010 TDI CupEdition (DSG)
what is the compression ratio? on this block, I'm thinking about doing this. I just upgraded wrx and I think I might throw this into my daily driver (2.2 Legacy)
Also, does anyone know were I can get suspention upgrades for this car (wagon)?
Rice Boi is offline   Reply With Quote
Old 09-07-2005, 10:32 PM   #12
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
N/A EJ22 CR is 9.5:1 its straight for a few psi prolly no more than 6 psi for stock internals.
EJ22T was 8.0:1 for 8.7psi
Old 09-07-2005, 10:37 PM   #13
Rice Boi
Member#: 25811
2002 WRX (6spd)
Another question, I've been doing some research, I read that this 02'+ WRX turbo components (the exhast manifold) will only cross over to 95 or lower EJ22 Legacy?
96 and up are single port heads and the WRX is dual. So this won't mate up with eachother? So what are my options? can I just change the flange to make it fit? Also does the brackets for the stock intercooler cross over as well?
Thanks for the input I'm really interested in this. I'm about to do a full tune up on the Legacy anyway(@ 75,000miles) .
Old 09-07-2005, 11:49 PM   #14
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
Legacy
that is generally correct although you may find some legacys with dual ported heads after 1995 but mine at 1992 is dual and i know all the legacy's from 1990-1994 were dual port so no problems running the wrx headers uppipe downpipe cat and midpipe it will need to be extended 1.5 ft though inorder to make it to the end
07 STI - 330whp on 93 oct, Stock Turbo - My Personal STI! P&L Motorsports Inc. Proven Power Bragging 36 03-04-2009 12:18 AM
my first post, I pick up my 93 wagon today keithhr General Community 2 08-26-2003 11:39 PM
what rear differential will work on my 93 turbo? serious Legacy Forum 5 11-16-2002 09:43 AM
Hail Storm messed up my car! Will an Outback hood fit my 93 impreza? shinra Service & Maintenance 2 05-02-2002 03:48 PM
Legacy Touring Wagon "Turbo" 93 Performance cdanders Legacy Forum 5 09-09-2000 05:09 PM
