Old 08-31-2005, 04:02 PM   #1
rites
Member#: 50652
2000 Impreza 2.5RS
Pearl Sadona Red
Default launching a 2.5rs
I'm in the dark about what is the best way to launch a RS and at what rpm it is ideal to launch it at anyone mind clueing me in. A friend is wanting to see what my car could do next to his at the local drag strip
rites is offline   Reply With Quote
Old 08-31-2005, 04:05 PM   #2
svek
Member#: 82259
1999 impreza 2.2L
Brilliant Red <4EAT Club>
rev it up to 6k and side step the clutch
@ what rpm depends a lot on your tires and mods. but i know you want to slip the clutch and not dump it. slip is like dumping it but it slightly slower. and your foot is keeping the pedal at bay the entire time
<---drives an auto
svek is offline   Reply With Quote
Old 08-31-2005, 04:32 PM   #3
AlpoRS
Member#: 81338
2005 2.5 RS Wagon
Crystal Gray Metallic
ya, sidestepping the clutch is a terrible idea...sorry. That will kick the **** out of your transmission.
What you want to do to launch it is rev it up to about 5600 or so...i think thats the top of the power band, let the clutch out until you just begin move. Then push the clutch in so that it is just barely not touching. When you want to go, hammer the gas a split second before you start letting the clutch out, then when you do start to let it out, let it out fast enough so that you arent letting the engine sit at redline, but slow enough so that it doesnt drop below the power band...it take some practice.
Basically, you want to try and keep the rpms between 5000ish and redline just by how much the clutch is grabbing because you will be at WOT.
When it comes to shifting...just hammer through the gears once you get close to redline...it takes some practice. Go do it a few times before you go to the track, and learn where the power band starts and ends
AlpoRS is offline   Reply With Quote
Old 08-31-2005, 05:00 PM   #4
Demoted
Member#: 88931
05 RS
Regal Blue
i have a stock 05 rs and i've out launched quite a few rex's by holding at 4k (peak torque) and slip the clutch as you gas it. I get a quick chirp outta my tires and never drop below 4k... gives me enough time in 1st without slipping for too long to shift and use 2nd till 5,600 etc. (and it saves your clutch a little more than holding at peak hp)
an RS has a very nice torque line, and wheelspin isn't excessive besauce of lack of power, some people will argue that you don't accellerate as fast while spinning, but i use the wheel spin to jump me to the speed i want to be in a short distance. It's also a technique if your good at anticipating when to launch the quick chip should be done a fraction of a second before light turns green, so when it's green your crossing the line at a faster speed than who's next to you.
Demoted is offline   Reply With Quote
Old 08-31-2005, 06:13 PM   #5
zmaster
Member#: 88995
11 WRX Premium
True Subaru color WRB
what is WOT?
zmaster is offline   Reply With Quote
Old 08-31-2005, 06:14 PM   #6
svek
Member#: 82259
1999 impreza 2.2L
wide open throttle.
see: acronym thread
Old 08-31-2005, 06:42 PM   #7
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
The main trick is, as Alpo RS stated, put the slightest bit of load on the clutch before launching.. this gets all the gears and splines snugged up so that you don't have a violent shockwave rip through the driveline and tear things apart. Once you learn to do that.. beat away on it.. you're not going to break it with a mostly stock engine.
Old 08-31-2005, 11:12 PM   #8
FalconRS
Member#: 92913
2005 2.5RS Wagon
Crystal Grey Metallic
Right click --> Bookmark this page.
Thanks guys, great info here!
FalconRS is offline   Reply With Quote
Old 08-31-2005, 11:19 PM   #9
Lethargic1
Member#: 20998
Ok, so I know not to do it, what exactly is sidestepping the clutch?
Lethargic1 is offline   Reply With Quote
Old 09-01-2005, 12:15 AM   #10
svek
Member#: 82259
1999 impreza 2.2L
imagine your foot fully depressing the clutch. then imagine moving your foot to the left while the car is in gear and gassed to redline.
uh oh.....spaghetti'os
Old 09-01-2005, 02:03 AM   #11
JonzFaSTi
Member#: 85575
2013 STi
Dark Gray Metallic
No one uses the E-brake before the Launch???? I pull that thing up burn the clutch and launch I jumped on a 6sp G35 doing that until 2nd gear. But yeah it kinda burns your clutch I dont recomend it to often.
JonzFaSTi is offline   Reply With Quote
Old 09-01-2005, 02:25 AM   #12
Lethargic1
Member#: 20998
hmm...I guess I can see why you wouldn't want to do this.
Old 09-01-2005, 02:59 AM   #13
Caplin 2.5
Member#: 71203
2005 2.5rs
I've been practicing this non-stop. Every empty straight road i come to i do it. I've tried all sorts of launching.... revving up to peak hp (5600 rpms) and dropping the clutch, revving up to peak torque (about 4600 rpms) and dropping the clutch but my most recent one that i have yet to perfect and probably wont for a while since its such a bitch is holding the rev at about 5100 in between peak hp n torque, then let go of the clutch very slightly so the car starts rolling forwards then drop it. I guess i did what AlpoRS was saying.
When i did this one night on my way home i noticed that it was an extremely fast launch not as hard as revvin it up and dropping but fast without hearin tire screetch. It seemed to roll forward warming up then just launched off to redline.... the rpms never dropped below 5000 the meter just stayed at 5000 till the clutch grabbed then it picked up and slammed to redline. I still don't get how i did it.. i kept on tryin to do it again.... i guess i just slipped the clutch before droping it.
Caplin 2.5 is offline   Reply With Quote
Old 09-01-2005, 03:26 AM   #14
FalconRS
Member#: 92913
2005 2.5RS Wagon
This is a truly great thread. I posed this question in the proven power bragging because that's where the racers seem to hang, but got no sensible replies. Shoulda asked here I guess. I'm going to get out and give this a try first chance I get for sure. Thanks guys.
Old 09-01-2005, 03:59 AM   #15
JonzFaSTi
Member#: 85575
2013 STi
Dark Gray Metallic
caplin try using the e-brake when you launch that would be the result. But like I said its burns
Old 09-01-2005, 09:04 AM   #16
Calamity Jesus
Member#: 44501
1984 That's *Sir*
I use the e-brake to hold the car in place while I take the slack out of the driveline.. but that's because I don't want to leave early and cross the lights when autocrossing.
Old 09-01-2005, 09:34 AM   #17
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
When i first went and tried a drag race at Pacific Raceways, my first time i tried launching at 3000 rpms and that wasn't quite enough. So then i tried 5000 rpms. I don't sidestep the clutch, i let it out like i was on the road except alot faster. The rest of my runs had a 2.000 Second 60 foot time. And my best run (after i got the shifting down and everything) was 15.86
This is a totally stock 98 RS with 1/4 tank of gas
Old 09-01-2005, 01:33 PM   #18
Ruff
Member#: 32131
2006 Nissan 350Z
Was 01 2.5 RS
That is pretty good it for a stock 98, gj. For references, I pull 1.95 60' all day long. I was doing this with at first just an Injen intake, where I pulled a 15.005, and consitant 15.1s. Then with full exhaust I could still pull mid 1.9 60' with 14.910 being my quickest 1/4 with high 14s to 15 flat all day long.
Ruff is offline   Reply With Quote
Old 09-01-2005, 01:38 PM   #19
Master2192
Member#: 83254
98 2.5 RS
04 WRX
Your trap speed is higher than mine. My best was low 85 mph. My friends were trapping at higher speeds so i guess i beat them in the 60 foot. Anyone know why the 99s have a faster 0-60 time than the 98s? I thought nothing changed except some interior stuff..
Old 09-01-2005, 02:03 PM   #20
Caplin 2.5
Member#: 71203
2005 2.5rs
Wait im confused can you explain that?
Lemme try n clarify here... I rev it up and pull the e-brake up while the clutch is depressed then I drop the e-brake and launch? please explain, im intrested.
Old 09-01-2005, 02:14 PM   #21
impr25rs
Member#: 60162
04 Aspen RS
The One Not Turbo'd, NA!!
Caplin you roll up, stop, pull up the e brake, push the clutch in and rev to where you want to launch. Then hold the revs, let the clutch out slowly till you feel it grab slightly. The car will squat in a sense. The front will lift a little and the back will sink. Push the e brake button and hold the lever up. Then when you want to go, lift up on the clutch, drop the ebrake and step on the gas at the same time. This style takes the slack out of the suspension.
Oh and this makes the clutch smell if lift the clutch and hold the e brake. My DSM buddy showed me this and he can launch my car a crap load better then I could doing the normal way.
impr25rs is offline   Reply With Quote
Old 09-01-2005, 03:10 PM   #22
Ruff
Member#: 32131
2006 Nissan 350Z
Was 01 2.5 RS
98s have less hp, then 99-present. Like 162 hp vs our 165. Plus 00-01 are SOHC vs your DOHC.
Old 09-01-2005, 03:24 PM   #23
Caplin 2.5
Member#: 71203
2005 2.5rs
Hmmm i think i'll give it a go tonight...
Old 09-01-2005, 03:27 PM   #24
impr25rs
Member#: 60162
04 Aspen RS
Just remember to release the clutch a little, enough to make it squat.
Old 09-01-2005, 03:37 PM   #25
Caplin 2.5
Member#: 71203
2005 2.5rs
will do thanks for the info.
WTB/WTT : 08+ SWP 2.5rs hood DG39 NWIC Private Classifieds 13 07-28-2011 06:03 PM
FS : Sold krylon 1993 - 2001 Impreza Specific Parts 9 06-16-2010 08:51 PM
how do i launch with my 2002 2.5rs spankmeplz700 Newbies & FAQs 1 06-30-2002 12:04 PM
('93-'01) '01 2.5RS or '02 2.5RS jRS2.5 Impreza Forum 24 05-25-2001 08:03 AM
02 2.5rs vs 01 2.5rs Blindeye_03 General Forum Archive 8 02-24-2001 11:56 PM
