Old 08-31-2005, 08:50 PM   #1
jsaunders
Member#: 40059
10 CTS--V
thunder grey
Default 05 sti exhaust on 92 ss
Like the title says - will a 05 sti tbe fit on a 92 legacy 2.2t. Is it a bolt on or is there a little work to make it fit? I will be hollowing out the cats.
Thanks Joel
jsaunders is offline   Reply With Quote
Old 08-31-2005, 10:28 PM   #2
napphappy
Member#: 56170
95 Impreza L
Ugly
I put a 05 STi catback on my 97 Legacy. It was not a bolt on procedure. I had to move all three hangers that were on the muffler. I left the hanger on the mid pipe in place. Doing so made it clear the rear axle fine but I had to extend the tip to get it to the bumper. And the mid pipe had to be extended. Some of that may be true on your car as well, maybe not.
napphappy is offline   Reply With Quote
Old 09-01-2005, 10:01 AM   #3
nimaxpro
Member#: 46318
It is NOT a direct fit.
I have a WRX exhaust on mine (but didn't put it on myself, bought it like that) and from what I know, one of the pipes will need to be extended about 3 inches and maybe a hanger or two relocated.
nimaxpro is offline   Reply With Quote
Old 09-02-2005, 11:15 PM   #4
jsaunders
Member#: 40059
10 CTS--V
thunder grey
Thanks for the replys, I did figure there would be a little cutting and welding. MY BIGGEST QUESTION -Does the turbo down pipefrom the sti fit and work onto the 2.2t with out problems. Thanks Again Joel
Old 09-02-2005, 11:22 PM   #5
THAWA
Member#: 44581
3 Boxers 2 AWD
3 turbo 1 6cyl & a 13BT
Why? They're essentially the same. You're just paying for new cats and a different muffler tip basically.
THAWA is offline   Reply With Quote
05 STi exhaust on an 03 WRX? C_Wood Newbies & FAQs 13 01-16-2007 08:45 AM
05 STI exhaust on 06 TR dan1587wrx Factory 2.5L Turbo Powertrain 2 01-05-2007 02:35 PM
05 sti exhaust on an 03 wrx 03bluwrx Factory 2.0L Turbo Powertrain 7 10-21-2006 08:00 PM
STi exhaust on '94 SS? shemoves Legacy Forum 10 10-11-2005 10:35 PM
05 STI Exhaust on 06 WRX Wagon Shavenyak Factory 2.5L Turbo Powertrain 9 10-04-2005 10:48 PM
Message Board Statistics All times are GMT -4. The time now is 11:03 AM.
