Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 08-19-2001, 11:26 AM   #1
2000KSzRS
Member#: 6372
2004 STI
Default 2001 L Largest tire size
What is the largest tire I can run without problems(rubbing/strut etc)..? 2001 L 15in Rim
2000KSzRS is offline   Reply With Quote
Old 08-19-2001, 02:04 PM   #2
lakepop
Member#: 3851
2007 Outback Ltd.
Champagne Gold
Well, stock is 205-70-15 and if you want to stay plus zero you could use 215-65-15 or 225-60-15. After that I think you run into problems.
The next move would be to larger wheels and go plus 1 or plus 2. This involves more $ and I assume you just want to upgrade from the stockers.
Hope this helps..keep us posted. I too will upgrade once the tires need to be replaced.
lakepop is offline   Reply With Quote
Old 08-19-2001, 05:25 PM   #3
Crashton
Member#: 3808
2005 Forester XT!!!
Crystal Gray Metallic
Someone posted a while back that he was running 215/75/15 Cooper AT's. Not sure if it was posted here or the Yahoo Forester forum. Seems that the choices are 205/70/15, 215/65/15, 205/75/15 or 215/75/15. The last two sizes are avalible in a AT tread design for dirt road use. When my Bridgestone Dueller HT's die I'm buying Bridgestone AT's 205/75/15.
Chuck
Crashton is offline   Reply With Quote
Old 08-20-2001, 01:46 AM   #4
remarcable
Member#: 2362
1999 Legacy Outback
Blue w/ Paint Chips & Mud
I don't have a forester, but when I tried 205/75/15 ATX tires they rubbed around turns.
Forester may have larger wheel wells than Legacy, but it could have been the tires. I know at least one outback person is running 205/75/15 without problems.
(stock outback pre MY2000 was 205/70/15)
remarcable is offline   Reply With Quote
Old 08-27-2001, 03:47 PM   #5
juice
Member#: 1424
1998 Forester
Acadia Green Metallic
Forester does have slightly bigger wheel wells.
205/70R15 is stock
215/70R15 should fit
205/75R15 should fit
215/75R15 is pushing it
I know of at least one person that ran that last, and biggest size. Any of the others is more conservative and should fit OK.
Keep in mind you're making the gearing taller, so you'll lose torque, and you don't have a low range to make that up. You don't want to get too much bigger.
I got 16" rims, but with a different offset. I got 225/60R16 instead of 215/60R16 and I like them. They are 10mm wider and 6mm taller, and the wheel offset made just barely enough room. My guess is 235/60s would rub. 225/65 would also rub, so I'm at about the size limit.
Hope that helps.
-juice
juice is offline   Reply With Quote
Largest Intake Size DrakeV Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 11-16-2006 12:18 PM
Largest tire size on 04 sti? greysave Tire & Wheel 14 10-10-2005 11:50 PM
Best wheel and tire size for a 2001 RS. Space Boy Matt Tire & Wheel 4 12-06-2003 03:04 PM
Here is tire sizes chart. No more tire size Qs? Yeah, right! 25psi Brakes, Steering & Suspension 18 04-18-2001 03:29 PM
