#1 |
Member#: 87762
OK...I have everthing pulled off per the FSM instructions.
Hardest part for me was getting the transmission bolts off. Going to the hardware store to get a steel cable to hook to my lift. Any suggestions on breaking the seal between the tranny and the engine ? CAn I simply put a jack under the tranny and begin to lift the engine with my cherry picker ? I am thinking that the upward lift from the cherry picker will break the seal. Any thoughts/suggestions from those that are experienced with this ? P.S.: I finally figured out where my manual trans fluid gauge/stick is located !!!
#2 |
Member#: 60162
Vehicle:04 Aspen RS The One Not Turbo'd, NA!! |
That little tranny stick likes to hide down in there doesn't it
The cherry picker will probably break it loose, you might need to give it a little force to break it loose, but not a whole lot. |
#3 | |
Member#: 87762
I am assuming that I just poor the replacement Tranny fluid down the tranny stick hole ?? |
#4 |
Member#: 66304
Vehicle:98 RWD BG Outback ...with R200 and ITBs ;) |
That's what I do, but make sure to add 3Q and drive it around the block and then check it, it will probably take another Qt.
Make sure all your mounts are loose and your O2 sensors and wire clusters are unplugged, then "lift and shake". Just as general advice, don't force anything though, if you have trouble just be patient. |
#5 |
Member#: 6486
Vehicle:00 Impreza 2.5 RS Blue Ridge Pearl |
Get yourself a putty knife that you can hit with a hammer. Wedge it between the block and the trans. Once you have a gap use a prybar.
Get a jack under the tranny to lift the whole deal enough to clear the motor mount studs out of the cross member. |
#6 | |||
Member#: 815
Vehicle:2013 Boss 302 White 2000 2.5 RS Coupe Silver |
#7 |
Member#: 87762
Got it out a few hours ago. How do I upload photo's ????
If someone can tell me how then I can upload photo's of the breakdown of the engine, if anyone is interested. Last edited by Mike1967; 09-01-2005 at 06:43 PM. |
#8 |
Member#: 87762
I was making great headway until I ran into the torx bolts on camshaft caps/covers.
I am having a difficult time finding an off the shelf Torx that fits these bolts....GGRRRRR Can anyone tell me what size torx bit to use....and if this bit can be bought from a hardware store vs. Subaru's OEM Tool It is larger than a 40 and smaller than a 45.....but all I cannot locate a bit between 40 and 45 HELLLPPP !!! ![]() |
#9 |
Member#: 87762
Can't figure out how to post pics arrggghh
#10 |
Member#: 87762
#11 |
Member#: 87762
#12 |
Member#: 18978
SCIC
Vehicle:96 brighton 05 AP2 ,09 GE8 |
Same here, I just pulled it out yesterday afternoon:-)
Try using photobucket, its easy and has lots of space |
#13 | |
Member#: 11786
Vehicle:02 TS Black on White |
The guy at the parts store told me it was a 40 anyways |
#14 | |
Member#: 87762
I have a new appreciation for Snap On Tools. The local dealer came throught twice today. First on the Torx Plus 40 and second on the 12 pt 14 MM for the head screws. What can I say....I don't plan very well or read directions ![]() |
#15 |
Member#: 87762
Ummm...so what exactly does a blown head gasket look like anyway ?
I have the first head off and was expecting to see the gasket in pieces....but instead I saw a gasket that was completely intact. But it does appear that the head is warped 2x above tolerance. I cleaned very thoroughly with a scraper and carb cleaner. Then took straight edge with feeler gauges. Appears to be warped. The gasket had bubbled areas with what appears to be a paper covering flaking off of the metal gasket. I don't believe that the gasket was originally covered with paper, so am assuming that the material coating it is residue from overburnt oil or coolant or both. valves and pistons were/are pitch black. I really got this engine hot. |
| Thread Tools | |
| Display Modes | |
| Coolent leaked into my engine now it wont start | pjones89 | Factory 2.0L Turbo Powertrain | 3 | 09-28-2006 12:50 PM |
| Pulled my motor out...now to remove some weight! | dcoty | Normally Aspirated Powertrain | 59 | 03-18-2004 10:43 PM |
| pulling my project car engine *pics* | philip_g | Off-Topic | 7 | 01-16-2004 02:02 AM |
| Grease monkey overfilled my engine, now what | Dealer Xing | Legacy Forum | 21 | 05-16-2002 11:54 AM |
| When pulling the engine, which Engine mount bolts to pull? | Eric SS | Normally Aspirated Powertrain | 3 | 10-04-2001 02:46 PM |
