Old 09-01-2005, 02:22 PM   #1
chillington
Member#: 94445
Default So what does a dynamometer do to a AWD vehicle?
I heard it can ruin them. Is this true, and if so what exactly would happen?
chillington is offline   Reply With Quote
Old 09-01-2005, 02:30 PM   #2
bailey454
Member#: 36474
how would it ruin them?
bailey454 is offline   Reply With Quote
Old 09-01-2005, 02:30 PM   #3
Basshead
Member#: 112
2011 Jetta TDI
hehe, just make sure you run it on a 4wd dyno...you will have zero problems
Basshead is offline   Reply With Quote
Old 09-01-2005, 02:38 PM   #4
shemoves
Member#: 80663
2005 STi
If it is a 4wd Dyno...it is fine. If it is a 2wd dyno, it can signifcantly damage the all-wheel drive system...its designed to have all four wheels under the same load. If only two wheels are spinning, imagine how much effort the system is going to put into trying to transfer power from the spinning wheels to the stopped ones.
Here in AZ, all the emissions places only have 2wd dynos, so they can not do the part of the test that involves the rollers. Basically, just idle and OBDII...but, they make AWD test every year instead of every other year.
shemoves is offline   Reply With Quote
Old 09-01-2005, 02:58 PM   #5
i102spd
Member#: 92130
2002 2.5rs
definitely not good...
click HERE
i102spd is offline   Reply With Quote
Old 09-01-2005, 03:28 PM   #6
matguy
Member#: 94772
What would be the effect of simply lifting two of the weels off the ground?
matguy is offline   Reply With Quote
Old 09-01-2005, 03:31 PM   #7
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
It would try and move the power away from the wheels the car senses to be slipping and to the wheels that are on the dyno. The level of power transferred is not typically what the driven wheels will experience in their normal lives, hence, damage can occur to your car.
specialev is offline   Reply With Quote
Old 09-01-2005, 03:34 PM   #8
matguy
Member#: 94772
So, either way it's not going to be happy.
Old 09-01-2005, 03:37 PM   #9
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
It will be happy as pie if you use a four wheel dyno and load the wheels equally.
Old 09-01-2005, 03:40 PM   #10
thrdeye
Member#: 24569
2004 Mazda RX8
Titanium
.....and we all know that pies are VERY happy.
thrdeye is offline   Reply With Quote
Old 09-01-2005, 03:44 PM   #11
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
I'm happy when I am eating pie.
Or apparently just thinking about pie.
mmmmm, pie
Old 09-01-2005, 03:49 PM   #12
araderboy
Member#: 89124
im scared that ill get towed one day and they'll drag the car by the rear tires and total ruin my tranny
araderboy is offline   Reply With Quote
Old 09-01-2005, 04:53 PM   #13
seattle944t
Member#: 18308
2005 WRX STi
And then the Towing company gets to buy you new diffs to replace the ones they damaged by towing it.
seattle944t is offline   Reply With Quote
Old 09-01-2005, 05:00 PM   #14
sandwi54
Member#: 94532
2005 WRX SRR
Cobb Stage 2
Talking about towing, if a towing company drags the two back wheels during towing, that will damage the car right? Is the towing company required to pay for the damages by law?
sandwi54 is offline   Reply With Quote
Old 09-01-2005, 05:03 PM   #15
Protege Menace
Member#: 41950
faq u rug
damage it, yes
can you get them to pay for it? good luck.
Protege Menace is offline   Reply With Quote
Old 09-01-2005, 05:05 PM   #16
OrlandoSTi
Member#: 70566
2005 Impreza STi
Team Rptr
No matter what kind of dyno you're on..... They sure do eat up some tires.... I noticed my STi's wheel gap increasing during the process, haha.... However, watching the cars squat on an AWD dyno is sweet....
OrlandoSTi is offline   Reply With Quote
Old 09-01-2005, 05:07 PM   #17
Protege Menace
Member#: 41950
faq u rug
why? it SHOUDLNT eat up tires if done right.
unless the caqr is at a 45 degree angle to the rollers and is actually spueeling to all hell, the metal rollers should have extreemely low wear on the tires...?
Old 09-01-2005, 05:08 PM   #18
i102spd
Member#: 92130
2002 2.5rs
im pretty sure it's in the suby's manual that the car should only be towed on a flatbed... and the towhooks on the front and rear of the car are not for towing, simply for pulling the car from a ditch
Old 09-01-2005, 05:10 PM   #19
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
Not true. The dynapak hooks directly up to the hubs:
They're good portable tuning devices, but not reliable for advertising numbers.
Old 09-01-2005, 05:11 PM   #20
Calamity Jesus
Member#: 44501
1984 That's *Sir*
And tying them down on said flatbed.
Old 09-01-2005, 07:00 PM   #21
IntraWRX
Member#: 20773
Midnight Black Pearl
and on the dyno too.
IntraWRX is offline   Reply With Quote
Old 09-02-2005, 11:14 AM   #22
ofay
Member#: 69621
05 mines wrx RIP
still hatin ROTAS
SCC had a problem trying to dyno an M3 because its not 4wd, but it wont let the rear wheels spin faster than the front wheels or somehting like that, and on the 2wheel dyno it had a **** fit trying to transfer the power, which resulted in it showing very little hp on the dyno
ofay is offline   Reply With Quote
What does Cobb actually do to un-marry AP from Car if you send to them? Carlito2002WGN Newbies & FAQs 24 05-14-2008 05:59 AM
Ok so what will a FMIC do to my spool and what effect on power output? Davenow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 08-01-2004 06:46 PM
What does radiator coolant do to copper? IMPBOY Normally Aspirated Powertrain 2 02-16-2001 06:44 AM
So what does a clutch do? Dre2932 General Forum Archive 9 01-12-2001 04:34 PM
