Old 09-01-2005, 05:47 PM   #1
cdigerlando
Member#: 6070
2015 STi
Dark Gray Metallic
Default What type of Motor in the 2006 FXT?
Does anyone know what type of motor is in the FXT. I'm sure it is EJ25{something}. Thanks.
cdigerlando is offline   Reply With Quote
Old 09-02-2005, 12:17 AM   #2
DonkeyPunch
Member#: 18987
2014 Forester
Dark Grey Metallic
Yeah it is an EJ-25, but it has a higher output this year than 2005 or 2004 due to some ECU teaking, and something to do with the intake runners. It now makes around 230hp crank in stock form.
I should have waited when I bought the wife's car, but I would have to put up with the tail lights.
DP
DonkeyPunch is offline   Reply With Quote
Old 09-02-2005, 02:05 AM   #3
b4437
Member#: 23162
2006 300c,forester x
silver steel
you know the 2004 and 2005 is making the same horsepower as the 2006,right? it's the same engine as the sti,minus the turbo,and etc.
b4437 is offline   Reply With Quote
Old 09-02-2005, 02:25 AM   #4
dvang
Member#: 84188
05 legacy
caravan full of kids now
didnt the compression change or am i wrong here guys?
dvang is offline   Reply With Quote
Old 09-02-2005, 02:57 AM   #5
vhalin
Member#: 21445
08 STI
actually, the 2004/2005s are faster due to being lighter weight, other than that, they have the same engine :-p
vhalin is offline   Reply With Quote
Old 09-02-2005, 10:12 AM   #6
suman
Member#: 88313
i read the car and driver article yesterday and they also were saying that the 06 XTs are slower than the previous ones. they said that it has something to do with gearing. subaru changed it so that is has better fuel consumption but it hurts performance. at least that's what i read...
suman is offline   Reply With Quote
Old 09-02-2005, 10:54 AM   #7
cdigerlando
Member#: 6070
2015 STi
Dark Gray Metallic
Default Performance
The FXT compression ratio is up to 8.4:1. Also they eliminated the pre-turbo cat by developing an air feed system, which feeds air to the exhaust to improve the effectiveness of the post turbo cats. A really brilliant idea. Our FXT suffers from no turbo lag, which is the feature that I appreciate the most, owning a WRX. So the HP is up 20 HP, but the torque number are the same. I also heard that the gearing changes reduced the 0-60 times. But it's pretty darn fast for a box on wheels! I really like the car.
Right now I'm just trying to find a WIX oil filter to fit the car, and would prefer to get one based on the engine type, since their website does not distiguish between an FXT or a regular forester. I don't think it is the same as the STi, or the legacy. Similar but not the same. Just want to make sure, especially when installing an oil filter.
Thanks
Old 09-02-2005, 07:46 PM   #8
blinguskahn
Member#: 39301
STi 05 8cm FPRed
WRX 06 Blue FP20G
Yup! +0.2
blinguskahn is offline   Reply With Quote
Old 09-03-2005, 08:11 AM   #9
DonkeyPunch
Member#: 18987
2014 Forester
Dark Grey Metallic
Yes the filter should be the same as the STi. It is smaller than the normal WRX 2.0 ltr filter.
Wix part #51365.
DP
Old 09-04-2005, 09:43 AM   #10
cdigerlando
Member#: 6070
2015 STi
Dark Gray Metallic
Default filters
Wix part #51365.
DP
I can't stand those dinky filters. I prefer the larger ones. They used to specify the dinky filter for the WRX, but decided to change. I wouldn't put one in.
Old 09-04-2005, 01:05 PM   #11
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
its the same engine as the 06 wrx ..
xt is slower due to revised final drive ratio
Old 09-06-2005, 01:37 PM   #12
cdigerlando
Member#: 6070
2015 STi
Dark Gray Metallic
Default Wrx?
I thought the WRX was to stick with the 2 L platform? I would love to have this engine in my 2002 WRX. Its got a nice torque curve. Lots of low end and very little lage
What type of coolant would my '04 FXT need? stockdad Service & Maintenance 2 03-13-2007 06:53 PM
What type of Motor in the 2006 FXT? cdigerlando Pre-2002 Factory Turbo Powertrain 5 09-01-2005 05:46 PM
Pinging problems...what type of gas in Socal? ImportVenom Southern California Impreza Club Forum -- SCIC 67 08-19-2003 04:12 PM
What type of light in my JDM taillights? dRu888 Newbies & FAQs 8 04-17-2002 11:57 PM
What type of differentials does the WRC impreza use? Gambit Motorsports 2 03-19-2001 06:40 PM
