Old 09-01-2005, 05:51 PM   #1
Mike1967
Member#: 87762
Default Play in Passenger Side Camshaft
I am pulling my heads today and just now got to the point of removing the timing belt.
During the removal of the CAM Pulley's I noticed that the passenger side pulley has about a quarter inch play. I can rotate it a quarter inch before I feel resistance from the camshaft.
Is this problematic ?????
I have photo's but don't know how to upload them
Mike1967 is offline   Reply With Quote
Old 09-01-2005, 06:10 PM   #2
Mike1967
Member#: 87762
anyone have any feedback for me on this one ?
Old 09-01-2005, 06:22 PM   #3
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Let me get this straight so that we both understand each other.
YOu matched the timing marks on all three sprockets(5 for dohc)?
YOu removed the timing belt?
You can rotate the passenger side cam sprocket(s) about 1/3 of a turn without resistance?
Totally normal.
Tim Sanderson is offline   Reply With Quote
Old 09-01-2005, 06:25 PM   #4
Mike1967
Member#: 87762
Totally normal.
THANKS !!!! (*Big sigh of relief !*)
Old 09-01-2005, 06:27 PM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Not a problem. When you remove the timing belt, if you have set things properly, one cam will be loaded, and the other will unloaded. I think you are playing with the unloaded cam...
Old 09-01-2005, 06:46 PM   #6
Mike1967
Member#: 87762
The other CAM does not want to "stand up"
I remember that this drove me nuts when I replaced the belt last time. When I align the sprocket to the timing mark it is like the cam is balancing on a needle. The slightest movement and it falls.
That is probably going to be the hardest thing about putting it all back together (I hope )
FS (OH): STi Front Brembo passenger side caliper, cheap!!! coolblue05 Suspension/Brakes/Handling 23 06-16-2010 01:54 PM
Passenger exhaust camshaft 2.0 Wrx Nessen Private 'Wanted' Classifieds 0 04-05-2010 07:34 AM
FS: 06 WRB side mirror good passenger side + broken driver's side monzon SCIC Private Classifieds 2 06-05-2009 11:00 PM
MO: Fiberglass sub box to fit in passenger side pocket in trunk clbd39 Interior/Dressup/Audio & Security 11 09-08-2007 08:53 PM
NY: In need of WRX Passenger Side Rear Door in WRBlue MACHWRX Private 'Wanted' Classifieds 5 10-04-2004 01:12 AM
