Old 09-01-2005, 10:42 PM   #1
Burton4g63
Member#: 85779
2005 2.5 RS Sport
Unhappy Low RPM Hesitation
Alright my car is brand new with almost 3k miles on it and im having a rare but annoying problem with 1st and second gear. When I let off the clutch and give it full throttle it goes, then a split second later boggs down for about 1-2 seconds then is back to its normal operation. My only mod is an injen intake (CAI). Id take it to subaru for them to check it out but would they just be idiots and tel me "duh, its your intake!". It dosent happen that much but maybe once or twice a day, roughly. It also seems as if it happens through my power band, not as dramaticlly, but around 3.5k rpm i get what seems to be a boost in power. Hopefully its normal but im so scared I did something because of my intake! Thanks for the help!
Taylor
Burton4g63 is offline   Reply With Quote
Old 09-01-2005, 11:14 PM   #2
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Did you reset your computer after installing the intake? If not try that first.
Also try the grounding mod
Old 09-01-2005, 11:30 PM   #3
Burton4g63
Member#: 85779
2005 2.5 RS Sport
hmm ive always seen threads about this "grounding mod" but never bothered reading. Sounds like some interesting stuff. I dont understand why but with all those people commenting im starting to think i should do it. However I probably woulnt know how.
Old 09-02-2005, 12:12 AM   #4
t3hWIT
Member#: 58779
95 STi RA (rhd)
98 Tacoma (300k Club)
i had problems similar to that with my short ram. check the hose connected to the idle air control valve. is it the same diamater/location on the intake end?
t3hWIT is offline   Reply With Quote
Help! Non-typical low RPM hesitation gtwagon941 Legacy Forum 13 06-18-2009 08:00 PM
2.5 NA 4EAT low RPM hesitation Hokie Guy Normally Aspirated Powertrain 24 10-10-2007 10:06 PM
Low RPM hesitation QwikRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 04-16-2006 07:04 PM
likely cause of low rpm hesitation/bogging??? vet Normally Aspirated Powertrain 15 01-14-2005 09:35 PM
Low RPM hesitation problems.. please help! (cont. ) Orbiter Technical Forum Archive 0 08-18-2000 03:47 AM
