Old 09-02-2005, 01:00 AM   #1
hauvis
Member#: 50262
2000 Protege 90whp
Default Who is using Motul 8100 and how do you like it?
Thinking about switching to this ester based oil. I have an email into SOA but i know they are just going to say as long as it meets the standards specified in the manual it is ok to use.
If you are using this oil how do you like?
I've heard this ester based oil is so fine that it can slip past seals and end up being burnt.
Do you find your car burning more oil now?
hauvis is offline   Reply With Quote
Old 09-02-2005, 02:06 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
WRC Subaru's use all Motul fluids...and I know lots of locals, here, that use it and have been using it....
Old 09-02-2005, 09:12 AM   #3
mindchatter
Member#: 36447
Heav en for the weat
her & Hell for company
I switched from Amsoil (which I'd used since 7k approx) to Motul 3100 at about 48k. I now have 55k and will be switching back to Amsoil when I'm done with the 12 liters of Motul I bought. I've noticed oil temps have been approx 15 degrees Celsius higher, oil pressure seems more inconsistent, and it's more expensive. It was also a PITA to source, for me, anyway. Just my experience. I opted to try it for the reason Scotty cited.
mindchatter is offline   Reply With Quote
Old 09-02-2005, 10:26 AM   #4
SooobieSnack
Member#: 44380
You won't find a better oil for the price. I've been running this oil in my car for over a year now.
SooobieSnack is offline   Reply With Quote
Old 09-02-2005, 06:36 PM   #5
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Mobil Delvac 1 or Lubrication Engineers 8530 MONOLEC are both F A R better oils. Visit www.bobistheoilguy.com if you need any more oil info.
Old 09-03-2005, 12:15 AM   #6
So Cal STI
Member#: 93948
2005 WRX STI
WR Blue
I'm currently using Castrol GTX until 10k, then I want to switch to Motul 300V or 8100Eco.
So Cal STI is offline   Reply With Quote
Old 09-03-2005, 01:57 AM   #7
hauvis
Member#: 50262
2000 Protege 90whp
Went to super autobaks and they were out of motul 5w-40 so I went with Amsoil 10w-40.
So far I like it!
Old 09-03-2005, 12:08 PM   #8
bluesubie
Member#: 767
04 FXT
The 8100 Eco-nergy 5W30 is thinner than M1 5W30. I would only use one of the 40 weights in a modified STi, unless I saw a used oil analysis on the 5W30 in another STi. Not all of the 8100 oils are not ester based, probably PAO I guess.
Check the viscosity at 100C at Motorspot.com .
-Dennis
D'oh! Just saw your comment about 5W40. This is still good info for the others anyway.
Old 09-05-2005, 05:51 PM   #9
So Cal STI
Member#: 93948
2005 WRX STI
WR Blue
-Dennis
Wow good to know info. Going to a thicker grade i.e. 5w-40 and of course staying SOA spec could "cure" the oil from being too thin? Just curious.
Old 09-05-2005, 06:34 PM   #10
o2man98
Member#: 90762
2005 92x
Satin Grey
How about trying the Amsoil 5w-40 European Formula.
o2man98 is offline   Reply With Quote
who is running mbc and how do you have it plumbed rexblake Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 11-30-2009 03:56 PM
Those who have AP how do you like it boostedsti06 AccessPort 5 09-10-2007 06:34 PM
WPC treatments. Who has done it and how do you like it? Shh!ItGoes11's Built Motor Discussion 18 11-12-2006 08:59 PM
Any engineers here? What do you do, how do you like it? edubb11 Off-Topic 45 06-21-2006 11:23 PM
P&P VF22: Who has it and how do you like it? PattyB69 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-11-2006 01:13 AM
