Old 09-02-2005, 01:53 PM   #1
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
'96 BrightonCoupeWRX-SR30
Legacy Turbo legacy 2nd engine woops!
yes unfortunatly i screwed up installing my kit and re-routed all of the oil to the turbo instead of some of it. Bad idea i seized my engine ! but i am having a new motor installed with the kit on it only this time it is done properly. My question is should i go ahead and try out the turbo kit or am i deep enough with having to replace the engine once allready that i shouldnt chance it.
Details on new motor.
Newer 60k mi EJ22 long block
it may be newer than 1994 idk if this is bad for the integrity of the engine under boost but i believe the motors are the same as the older N/A engines with 9.5:1 CR and open deck block. Are the new motors dual port heads like mine or will my wrx headers not work.
The mechanic said he would install the turbo on the new motor but every extra part he needs will obviously cost me a good amount. Trying to avoid spending any more money than i allready have to.
Kawikid20o2 is offline   Reply With Quote
Old 09-02-2005, 04:09 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Find out for sure what that motor you are getting is. If it is new enough, it will not mate to the WRX headers.
But I don't see why mis routing the turbo oil lines would seize the motor. There is probably something else going on there...
Old 09-02-2005, 08:20 PM   #3
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
yea i accidentally routed too much of the oil away from the engine and it burned off the turbo on the turbine side and spilled out the compressor side so it ran dry and seized...it never really took any boost. when i refilled it with oil it ran but had a really bad knock from the middle of the motor it seized with in 40 miles of this knock developing.
Old 09-02-2005, 09:11 PM   #4
Scoobie Steve
Member#: 2289
1998 [email protected]
Subaru L Ver 6 STi Type R
You pumped 4+ quarts of oil into the compressor/turbine side of your turbo and didnt notice it?? You didnt notice the smoke trail you left for 7 miles. Sounds like you need some coffee
So you have a turbo kit on a NA engine? Where did you tap your oil from. Its almost impossible to do what you are saying happened. 98 and 99 2.2l are single ex port engines.
Scoobie Steve is offline   Reply With Quote
Old 09-03-2005, 03:10 AM   #5
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
Legacy
it smoked in the drive way! i didnt drive it untill i fixed the problem, the damage was allready done! the oil came from an oil sandwich which worked a little differently from how i thought it did. apparently oil was backfeeding the turbo because i had it set up with the return line going into the return line of the sandwich. Now i have a nipple welded into my oil pan so it is all straightened out.
Old 09-03-2005, 09:15 PM   #6
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
Legacy
ok apparently the motor is a 1994 EJ22 with 65Kmi it has a dual ported head design, so everything will work on the new motor, it is just a question of whether or not i should chance it.
Wtb: 2nd gear on output shaft. (90's turbo legacy 5mt or compatible) biggreen96 Private 'Wanted' Classifieds 0 05-06-2010 02:09 AM
1991 Turbo Legacy Good Engine/Bad Trans armcomdes Private 'For Sale' Classifieds 0 11-13-2004 11:23 AM
1991 Turbo Legacy Good Engine/Bad Trans armcomdes Legacy Forum 0 11-11-2004 09:28 PM
Turbo Legacy Engine into a 94 Impreza L? Homemade WRX Subaru Conversions 5 04-11-2003 10:48 AM
Need help... Just did a 2.2 turbo legacy engine swap... lscott Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-24-2002 09:26 PM
