#1 |
Member#: 47746
Vehicle:2000 Impreza 2.5 RS Midnight Blue |
just upgraded to a wrx turbo...running 25 engine with 2.2 ecu. i had a smaller turbo on it before. when i give it a good rev or drive...after boosting the car and letting off the gas or slowing to a stop the car will stall. any suggestions?
#2 |
Member#: 38068
South East
Vehicle:03 WRX Wagon |
actually just this morning on my way to work my car started doing this.mine is jus a wrx(wrong forum) but i would let off the gad and neutral and the idle would drop as normal then it would start to hunt(fluctuate) 750-1500 rpm about twice before it shuts off. Im going to pull of the throttle body and clean it along with the IAC valve. I havnt dug into my engine as yet so for it to be valve lash is unlikely(hopefully), and i am holding full boost and dont seem to have a miss. Ill let you know what happens even though it may be a different problem.
#3 |
Member#: 47746
k. thanks, let me know
#4 |
Member#: 38068
South East
mine was iac, cleaned it off properly before leaving work and everything is fine now, no more stalling.
most likely that will be your cause as well, at least hopefully as it is an easy fix. |
#5 |
Member#: 60353
Vehicle:2002 Stg. 4 WRX WRB |
I have te same problem w/ my WRX after a turbo upgrade. I will clean the IAC.
#6 |
Member#: 5692
Vehicle:WTF? YES! I am better than you! |
Check for vacuum leaks too.
#7 |
Member#: 47746
stupid question...how do you check for vacume leaks?
#8 |
Member#: 38068
South East
get carb cleaner , or similar, and spray around intake manifold area and surrounding and any hoses from intake manifld, it idle changes, thats where you leak is.
some people use a cigarette and let the smoke get sucked in my the leak |
#9 | |
Member#: 37196
-Jake |
#10 |
Member#: 83557
Vehicle:2003 PSM Now with 405 whp |
If you are venting your bov this could also be the problem.
#11 |
Member#: 47746
i figured it out. the maf sensor was to close to the turbo. go figure. extended it out about 7 inches from the turbo and ....tada ..... no more stalling!
| Thread Tools | |
| Display Modes | |
| Stupid RS stalls after driving for more than 30 minutes. | GC_Anthony | Normally Aspirated Powertrain | 8 | 12-04-2007 12:31 PM |
| Volkswagen on track to hit goals after strong Q3 | NYCshopper | Non-Subaru News & Rumors | 0 | 10-27-2006 08:02 AM |
| Car stalled after a short drive... | KIMUTAKU | Vancouver Impreza Club Forum -- VIC | 6 | 10-31-2005 04:05 AM |
| engine stall after hard break from regular driving?? | nantong2 | Legacy Forum | 0 | 09-12-2004 03:26 AM |
| OBS 1.8L stalling after refueling...HELP | redobs | Technical Forum Archive | 7 | 08-08-2000 10:14 AM |
