Old 09-02-2005, 11:35 PM   #1
Burton4g63
Member#: 85779
2005 2.5 RS Sport
Default The "Miracle Mod" on an RS
just a quick question, will the grounding mod work on a 2.5 rs? I also have bogging issues at low rpms.
Where should i ground the two points on the intake manifold?
Should I ground my injen intake also?
Burton4g63 is offline   Reply With Quote
Old 09-02-2005, 11:39 PM   #2
FriedIceCream
Member#: 84154
2010 S&M WTF
Trans Purple
the previous thread said it was for MAP sensor I think..05's have MAF...but if it works us as well i would to know!!
FriedIceCream is offline   Reply With Quote
Old 09-03-2005, 12:03 PM   #3
Russell Rogers
Member#: 27261
I'm Ron Burgundy?
works greta on maf cars.
Russell Rogers is offline   Reply With Quote
Old 09-03-2005, 02:09 PM   #4
El_Kameleon_G
Member#: 87103
2005 Impreza RS RWD
Plat'num Plus...SOLD!
The mod worked great on my car and I only have 2 wires. One from batt. to strut bolt and the other from batt. to intake manifold. Also, I sanded and cleaned stock grounds as the they ground over the paint. Smooths out engine enough to notice.
El_Kameleon_G is offline   Reply With Quote
Old 09-03-2005, 04:05 PM   #5
FalconRS
Member#: 92913
2005 2.5RS Wagon
Crystal Grey Metallic
I posted a thread in the electrical section about my ground kit for my '05. Definitely made a difference. Smoother idle, Volts gauge showed more juice, and it does feel like that low RPM bog is reduced by quite a bit.
FalconRS is offline   Reply With Quote
Old 09-03-2005, 09:11 PM   #6
i_luv_my_scooby
Member#: 89465
Where at Falcon? And I thought the grounding kit is BS. I've been reading a lot about it and they say its BS.
i_luv_my_scooby is offline   Reply With Quote
Old 09-03-2005, 10:27 PM   #7
FalconRS
Member#: 92913
2005 2.5RS Wagon
Well, I dunno about BS. If a smoother idle is more of a "subjective" type of result, the extra 0.5V on my Volts gauge from before and after is certain hard evidence it did something. My gauge before always showed just under the 14V mark, 13.7-13.8V. After installing my ground kit, it never drops below the 14.2-14.3 range. And I've always been taught 14.x Volts is what a voltmeter SHOULD show on a running car, always. So it did something.
Best place to look with the most accurate write-up is on my cardomain site...
http://www.cardomain.com/ride/2074176/2
The pictures are out of date, I've since changed things around, but the write-up I did IS correct.
Old 09-04-2005, 01:00 PM   #8
Yesitsdrew5310
Member#: 95182
2005 Impreza 2.5 RS
Silver w/ JDM Roof Vent
Paranoid Fabrications makes a grounding kit made to fit the 2.5 RS or the WRX. The kit did alot more than I expected. The jerkiness in 1st gear went away, and now after you hit the gas a bit, you coast instead of jerk to slow down. It feels like my engine woke up and is new (and I own an 05'). I would strongly suggest just getting the kit; it works great for everyone I know that has it. Here is the link:
Well thats really stupid, I cant post url links untill 10 messages. That will get annoying. Well go to camotoy.you know what. Then click on subaru parts, and it will get you there.
Happy driving!
Drew Brashler
Yesitsdrew5310 is offline   Reply With Quote
Old 09-04-2005, 03:50 PM   #9
El_Kameleon_G
Member#: 87103
2005 Impreza RS RWD
Or you could go to home depot and make one yourself, like me, for about $5
Old 09-04-2005, 04:49 PM   #10
RSimport
Member#: 24718
05 impreza RS
white
I did this to MY99 rs and it helped it alot. 1st gear jerkyness was gone, seemed to help with the flat spot in the rpm as well. Plus, the car idled much better. I don't think the mod is BS at all. And those who say it is either didn't try it or just didn't notice it as much as everyone else did.
Chris
RSimport is offline   Reply With Quote
Old 09-04-2005, 04:59 PM   #11
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Who are 'they' that said this? Are you talking about here in this huge thread about this mod?
NA 2.5 Hesitation + SPG = New Car
Kevin Thomas is offline   Reply With Quote
Old 09-05-2005, 03:24 AM   #12
i_luv_my_scooby
Member#: 89465
Will these grounding kits make a difference in an automatic RS?
Old 09-05-2005, 04:13 AM   #13
zechsiw
Member#: 41791
2007 mkV GTI
grounding really make a difference and voltage stablizer does too.
grounding for auto, just make sure you run a wire to tranny, you will get smoother gear change. coz I just reconnect my grounding (add a wire to tranny), I really feel the difference.
recently I made some voltage stablizers for my friends. STi w/ catless turbo back, Mazda3 stock auto, civic stock auto. All of them feel more low end torque.
zechsiw is offline   Reply With Quote
Old 10-08-2005, 02:08 PM   #14
resident1155
Member#: 92659
2002 Impreza RS
running a ground wire to your tranny is not going to help your transmission shift. That is the most ridiculous thing I have ever heard.
resident1155 is offline   Reply With Quote
Old 10-08-2005, 09:20 PM   #15
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
Where is the TCM located on most modern transmissions?...either inside the tranny or bolted to the casing.
Albert is offline   Reply With Quote
Old 10-24-2005, 01:23 AM   #16
resident1155
Member#: 92659
2002 Impreza RS
Seriously though, lets use some common sense. upgrading the ground wires is not going to make your transmission miraculously perform better in any way. I have run an 8 guage ground directly to a bolt on my 4eat transmission. I can tell you it doesn't do much.
Somebody needs to remove this thread. I have done this mod. This is no miracle mod. It only helps fix the very minor issues. People need to stop exaggerating it by making multiple threads. More in performance can be seen from adding ngk iridium plugs. I noticed more of a difference from those than the grounding mod. A miracle would be me opening my hood tomorrow to find an ej20T instead of my ej25.
Old 10-24-2005, 02:11 AM   #17
Airboy
Member#: 72829
2006 WRX
2015 WRX
Where/what are your voltmeter wires connected to?
Airboy is offline   Reply With Quote
Old 10-24-2005, 08:35 AM   #18
t3hWIT
Member#: 58779
95 STi RA (rhd)
98 Tacoma (300k Club)
I'd do it on my car to fix the bogging probem, but it might be caused by the torqueless 1.8...
t3hWIT is offline   Reply With Quote
Are the strut bodies on an '03 2.5 RS the same as an '02 WRX? lotarg Newbies & FAQs 3 05-27-2010 07:53 PM
Destroyed the 2nd gear on an RS. Some advice please? powerlabs Transmission (AT/MT) & Driveline 19 08-02-2004 11:01 PM
WRX harness through the firewall on an RS swap Zephyr Subaru Conversions 3 12-06-2003 10:26 PM
Unusual idea for firming up the brake pedal on an RS Bob O Brakes, Steering & Suspension 4 02-02-2003 08:03 PM
Who has installed the Dual Cup Holder on an RS? BigElm General Forum Archive 8 11-22-2000 05:40 PM
