Old 09-03-2005, 10:39 AM   #1
Lawsonmh15
Member#: 86815
Exclamation Best Coolant
Doing a coolant flush today, and I'm wondering what standards to stick to when looking for a joint to do the flush. I've heard Subie coolant is a bit diff. than the run of the mill.
I know ALOT of people swear by Mobil 1... What brand for coolant? Immediate answers are greatly appreciated.
Lawsonmh15 is offline   Reply With Quote
Old 09-03-2005, 11:00 AM   #2
Russell Rogers
Member#: 27261
I'm Ron Burgundy?
if you live where its warm then plain water with water wetter, but any penzoil coolant will do elsewhere.
Russell Rogers is offline   Reply With Quote
Old 09-03-2005, 11:54 AM   #3
Hayes
Member#: 11808
I would use factory OEM or GO5 to be safe AND use "Subaru coolant system conditioner" I don't and will not use a water wetter as there are just too many complants about it causing a brown sluge. WW is good for pure water fills and helps little with coolant/antifreeze mix. JMHO eddie
Hayes is offline   Reply With Quote
Best Tuner AM55 Southern California Impreza Club Forum -- SCIC 54 06-03-2010 02:10 PM
on an '08 sti, what is the best FIT rim i can get on 265/ 35ZR/18 tires ? m_pun Tire & Wheel 7 06-03-2010 01:06 AM
best coolant to use subypal Newbies & FAQs 5 12-16-2009 10:00 PM
the best coolant WRX_Mike Service & Maintenance 2 06-08-2006 04:52 PM
Best way to drain coolant? ScoobieSnaX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-07-2002 07:35 AM
