Old 09-03-2005, 12:56 PM   #1
Padge
Member#: 74412
'05 Impreza WRX STi
Obsidian Black Pearl
Default How did you run your SIRIUS/XM satelite antenna wire?
Anyone have pics of clever ways to install it? Im kind if unsure how to discretely run the wire from the outside of the car to the inside.
Thank you.
Padge is offline   Reply With Quote
Old 09-03-2005, 12:59 PM   #2
rites
Member#: 50652
2000 Impreza 2.5RS
Pearl Sadona Red
Just put it back behind the rear seats where your brake light is. It will work fine.
rites is offline   Reply With Quote
Old 09-03-2005, 01:51 PM   #3
Padge
Member#: 74412
'05 Impreza WRX STi
really? What if the windows are tinted... will that cause a problem?
Old 09-03-2005, 10:38 PM   #4
robsgotit
Member#: 59674
06 06/2.5i 03/1.8t
there silver
i also mounted mine by the third brake light,
robsgotit is offline   Reply With Quote
Old 09-03-2005, 11:05 PM   #5
turboscooby13
Member#: 56280
2003 M3
I put mine on the trunk:
and the receiver:
turboscooby13 is offline   Reply With Quote
Old 09-03-2005, 11:27 PM   #6
Butterz
Member#: 21205
2004 Poopwagon
2010 135i
i just put mine up on the dash on the passenger side with a small piece of double sided tape. it works fine and it is not easy to notice, plus no need to worry about routing it all the way outside.
Butterz is offline   Reply With Quote
Old 09-03-2005, 11:51 PM   #7
Daboro's Rex
Member#: 55915
04 WRX stage 1/2
Wr blue pearl
if you mount it inside the car you need to have a ground contact, meaning you need to have a piece of metal that the ant. sits on. or else you will not get that good of reception, if it is on the outside then you can mount it on the trunk or on the front right on top of the front windshield.
Daboro's Rex is offline   Reply With Quote
Old 09-04-2005, 12:48 AM   #8
dan0025
Member#: 68492
08 WRX Hatch Back
89 BMW 325i track car
I mounted mine on the rear glass using 3M double sided automotive tape. It fits just between bottom of glass and 3rd brake lamp with minimal coverage of brake lamp. Then run the antenna wire under the bottom of rear seat and under interior rocker trim up under dash. The trim pieces and seat bottom are sooooo easy to take apart it won't take you very long to do it the right way so you won't have 10 ft. of antenna wire laying around the cockpit. DON'T mount it on your roof or trunk with the magnet unless you don't care about scratches in your paint!
dan0025 is offline   Reply With Quote
Old 09-04-2005, 01:08 AM   #9
ptsmalls
Member#: 31960
2012 R
I put mine inside right behind the rear seats....works perfect!
ptsmalls is offline   Reply With Quote
Old 09-04-2005, 03:02 AM   #10
boozy04
Member#: 87034
08 Stg2 9.5's 275s
SSM
I ran mine down the side of the headunit, under the steering wheel, then down the door sills the whole way out the hatch in my 05 wagon, you can't see any of it.... i REALLY need to figure out a way to hard wire the power though instead of havin the cigarette lighter open...... help!
boozy04 is offline   Reply With Quote
Old 09-04-2005, 03:35 AM   #11
jsmonet
Member#: 14190
2005 STi
white
don't be a wuss, just mount it 8" or so forward of the rear glass, on the roof (or whatever's most visually appealing). run the cord straight back to the weather stripping and tuck it in there. go toward the passenger side, run it down the weatherstripping, and at the trunk. pop your trunk, pull up the weather stripping there, file a divit into the metal so you don't pinch your cord, and put the weather stripping back over it. now run the cable forward through the space under the rear passenger seatbelt spool, under the carpet and trim, across the floor in the front where the ecu is, and up into the radio.
do it once. do it right. getting lazy this time around will have you pissed off and doing it my way ANYWAY, just at a later date.
jsmonet is offline   Reply With Quote
How did you feed your speaker wires through the door gourmet? joejoe3 Car Audio, Video & Security 11 12-16-2009 08:47 PM
How did you find your therapist/counselor/person to help you? TRH_legacy2k Off-Topic 24 06-25-2008 08:19 PM
how did you get your hands on your first car? Matt K Off-Topic 38 01-30-2006 03:39 AM
which HID kit and how did you run the wires into the lamp it8ezbngrn Electrical & Lighting 6 04-21-2004 05:52 PM
where did you run your power wire? Krelkor Car Audio, Video & Security 10 08-15-2002 02:03 AM
