Welcome to the North American Subaru Impreza Owners Club Wednesday October 22, 2014
Old 09-03-2005, 01:38 PM   #1
Cardiff Giant
Member#: 40325
2013 Nissan Rogue
Default Odd Problem with Engine Quitting
So this has only happened a handful of times but I'm still slightly concerned about it. Next time I take it to the dealer I'm gonna have them check it out since I'm still under warranty.
Anyhow, seems like every now and again, when I start my car (04 OBS 5MT), I'll have it in neutral the RPMS will get to idle (about 1500) and then drop to 1k and then either sputter back up to idle or sometimes the engine just stops. It always is fine when I restart it and the car drives fine but I'm a little concerned about this. It's probably only done this about 4 or 5 times since I bought the car (July of 03)but I have no idea what it is. Any ideas? I've been following the maintenance schedule pretty tightly, though I am due for an oil change. The car has about 19k on it.
Cardiff Giant is offline   Reply With Quote
Old 09-04-2005, 02:53 PM   #2
sha_zapple
Member#: 41012
1998 Legacy L
My car only did that when the autostart would mess up. Otherwise im not sure. Could have something to do with the vacuum lines, try checking those out (although I doubt it since its a new car, one could be loose though). Also, disconnect your battery for a while (that will reset the ECU, and maybe get rid of your mystery problem)
sha_zapple is offline   Reply With Quote
Odd problem with my front/center diff on 2005 STi... help AndrewSS Transmission (AT/MT) & Driveline 1 05-01-2006 01:22 PM
Well my friend has a very odd problem with his WRX Cyhper420 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 06-22-2005 01:15 AM
odd problem with the car suby4ub Normally Aspirated Powertrain 31 02-10-2005 09:23 AM
Very odd problem with my subie, need some clues. auricom Mid Atlantic Impreza Club -- MAIC 7 07-09-2003 11:57 PM
Odd problem with mine trenity8_u_up STi Forum Archive 3 06-25-2003 02:13 AM
