Welcome to the North American Subaru Impreza Owners Club Thursday April 2, 2015
Old 09-03-2005, 02:43 PM   #1
G.Subramaniam
Member#: 64528
Default CR, Nitrous and Turbos
Why is it that High CR NA cars can handle 75hp nitrous shots
whereas they cant handle any boost
Nitrous is a form of adding oxygen
Is it because Nitrous cools the air and prevents detonation, which then allows it to tolerate high CR ?
G.Subramaniam is offline   Reply With Quote
Old 09-04-2005, 12:34 AM   #2
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
Well...I've considered nitrous lately just for giggles (pun intended). FWIR and FWIW, nitrous is a chemical supercharger. The trick to making it work is more fuel. It doesn't work all by itself. Some engines built for higher doses of N20 actually have lower compression. It's kinda like using high compression and low boost vs. low compression and high boost. Any way you can build cylinder pressures is going to be fast. An 11:1 motor can actually handle boost with the right fuel, just not a ton of it. "Which is better" is always up for debate, despite the fact that they all still work one way or another.
HamFist is offline   Reply With Quote
Old 09-04-2005, 07:45 AM   #3
SubyGC8
Member#: 70069
2005 Legacy GT
Satin Pearl White
I actually use nitrous and love it. What its doing is cooling the incoming air charge. Cooler air is more dense than hot air. A car with slightly higher compression can only handle a 75 shot of nitrous with added fuel. The reason this can be done is because in any given cylinder, when the piston drops for the intake stroke, it creates a low pressure. Now cooler, more dense air fills the low pressure cylinder. In a NA car when this happens, you will only fill that cylinder to 14.7psi or what ever atmospheric pressure is in your area. Now in the compression stroke, the piston is compressing the dense air charge which contains more oxygen. Thats why extra fuel is needed. In return on the ignition stroke more power is made. Nitrous in no way helps prevent from detonation. It still creates high temps within the cylinder which can ignite the air charge. Now as for a turbo, say you are boosting 10lbs, on the intake stroke, air is compressed into the cylinder adding to the 14.7psi atmospheric pressure making it 24.7psi. When air is compressed it heats up, that is why a intercooler is used. Now when the valve closes you have a high pressure in the cylinder which is then compressed by the piston. As HamFist stated, you can have a high compression engine and low boost. Or you can have a low compression engine and high boost. You will get similar amounts of power but the power bands will be in a different rpm range.
SubyGC8 is offline   Reply With Quote
Old 09-04-2005, 03:51 PM   #4
G.Subramaniam
Member#: 64528
Hamfist, how much boost can 11:1 take with correct fueling
do our cars like nitrous? and is anyone running with nitrous vandejr Newbies & FAQs 28 11-01-2005 08:58 PM
Nitrous and turbo together in harmony??? beecha91 Water/Methanol Injection, Nitrous & Intercooler Cooling 4 01-23-2005 01:07 AM
nitrous and turbo 949 Water/Methanol Injection, Nitrous & Intercooler Cooling 3 04-17-2004 05:28 PM
Work Emotion CR Wheels and Lugs Aerosim Research Ltd SCIC Vendor Classifieds 15 04-16-2004 03:46 PM
Work Emotion CR Wheels and Lugs Aerosim Research Ltd Wheels/Tires 1 04-11-2004 08:29 AM
