Old 09-03-2005, 08:25 PM   #1
Chi_San
Member#: 53558
2005 Baja Sport
Gray/Silver two tone
Default Pulling a CEL code without tools?
I did a search, I did several in fact, and could not find instructions on how to pull a CEL code without having an ODBII scanner. Anyone help a little please?
Chi_San is offline   Reply With Quote
Old 09-03-2005, 10:04 PM   #2
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
Dude, go to your local Schuck's and have them pull it for you, for free.
Also, pretty sure that the computer only will communicate such things with another computer.
Good luck
Jared
PS: I've been to the local one so often that I try and just check the thing out with my ID since I know what needs to happen better than most of the employess. I'll probably buy one some day.
gtwagon941 is offline   Reply With Quote
Old 09-03-2005, 10:11 PM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Or go to Autozone, they do it as well. Also ask in your local forum to see if someone nearby has a scanner and can check it for you. There is no other way to pull codes on the OBDII Subarus.
Old 09-04-2005, 06:31 AM   #4
Chi_San
Member#: 53558
2005 Baja Sport
I thought you could turn the key a certain number of times or connect two wires under the dash and the CEL would blink the code to you.
Old 09-04-2005, 08:07 AM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
On the older OBDI cars, yes. On the OBDII cars, no.
Old 09-05-2005, 02:31 AM   #6
Chi_San
Member#: 53558
2005 Baja Sport
I got the code pulled today at Schmucks, P306, Cylinder #1 misfire.
Old 09-05-2005, 01:01 PM   #7
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
p306?????????????
Never seen that code before. Did you mean P301? Anyways, join the club.
I get tons of misfires with seemingly no cure...
Jared
Old 09-05-2005, 11:20 PM   #8
Chi_San
Member#: 53558
2005 Baja Sport
This one just started. I think it's plugs, or wires. Reccomendations on a good set of plugs/wires?
Old 09-06-2005, 12:10 AM   #9
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
I have magnecore wires. They are guaranteed forever. some have had some sort of issue with them, but I haven't. They are expensive but I thought why not, since they are guaranteed forever.
Plugs: NGK copper or Plat. Copper conduct better but don't last as long. Plats are more money but have a longer interval.
Most run copper I think. They are like a buck or so at Napa.
.02
Jared
Old 09-06-2005, 04:12 AM   #10
Chi_San
Member#: 53558
2005 Baja Sport
I'm going with NGK copper. I did some research here (hey, I used the search button, and found more info than I thought I would in the process) and decided that copper is what I want.
Is there a way to pull cel codes without a scanner? Carlito2002WGN Newbies & FAQs 8 06-07-2007 02:11 AM
Is there anyone who can pull my CEL code? legacyej22 North West Impreza Club Forum -- NWIC 2 12-25-2002 03:45 PM
Pulling CEL codes without an external device crash Service & Maintenance 4 06-14-2002 01:29 PM
Finding CEL code without pluging the ECU ? Extraze Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-19-2002 01:06 PM
Anyway to pull the engine codes without taking to the dealership jhoffmann Technical Forum Archive 1 07-26-2000 07:35 AM
