Welcome to the North American Subaru Impreza Owners Club Sunday May 24, 2015
Old 09-04-2005, 10:59 AM   #1
vipernj
Member#: 86854
2004 fx35 02 Z06
Default How much power can a stock 2.5 motor hold?
Hey guys, I just need to know the limits on a 2.5 RS motor. Im picking one up soon and I need to know how much boost, timing, etc I can run safely... Ive always had WRX's so I dont really know anything about the 2.5. Anything help would be thankful..
vipernj is offline   Reply With Quote
Old 09-04-2005, 01:47 PM   #2
HolyCrikey
Member#: 66776
2005 Mazda3 Hatch
Titanium Grey Metallic
Search man. Many many many threads about the limits of the EJ25.
When it comes to boost, not much. I've heard of running about 6-8 psi without going into boost all the time, and the engine will hold up. Go over that and you're putting your engine in risk. The block is simply not made to handle a turbocharged application (without MUCH money dumped into it). That is why subaru has the WRX and STI platforms. Simple as that.
HolyCrikey is offline   Reply With Quote
Old 09-04-2005, 04:21 PM   #3
Caplin 2.5
Member#: 71203
2005 2.5rs
Crystal Gray Metallic
why do u wanna pick up an RS motor to turbo?
but as Holy said, 6-8 psi.
Caplin 2.5 is offline   Reply With Quote
Old 09-04-2005, 04:48 PM   #4
vipernj
Member#: 86854
2004 fx35 02 Z06
well im buying a 99 2.5RS and was planning to boost it. I was just wondering...I might buy it and wait for a while then drop a EJ20 into it. Not sure yet.
Old 09-04-2005, 05:01 PM   #5
Jesse00
Member#: 78036
02 Impreza 2.5TS
Midnight Blue
its 6-8psi with supporting mods... its not worth the money as you wont get that much hp gain from it... just do a swap instead
Jesse00 is offline   Reply With Quote
Old 09-04-2005, 05:07 PM   #6
EVOs_Master
Member#: 94470
Cert Subaru Tech.
2004 PSM STI
I have a 2.5rs and when I had a turbo kit on the stock motor at 9psi I was walking all over most wrx's I raced, sorry guys but true. Then I walked all over a 99 rs with an ej20 with up and down pipes, intake, pulleys, utec or whatever it is, and 17psi by about 2.5 cars lengths, just a thought. But yeah do a search, you'll find a lot.
EVOs_Master is offline   Reply With Quote
Old 09-04-2005, 06:42 PM   #7
poormansporsche
Member#: 79798
With a turbo you'll get crazy amounts of torque and less lag. But it doesn't run as smooth and you'll blow your 2nd gear if you don't treat it nice.
cheers
garrett
poormansporsche is offline   Reply With Quote
how much power can a stock transmission hold? Mr.Minney Transmission (AT/MT) & Driveline 14 10-02-2009 10:21 AM
How Much Hp Can The Stock 2.0 Hold?? jcbluescooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 04-25-2009 03:15 PM
How much power can an '04 2.5RS tranny hold? JEEENKINNNS Transmission (AT/MT) & Driveline 4 01-04-2007 07:15 PM
How much power can the stock trans hold/ Are WRX trannys fragile? Reference thread! RebelINS Transmission (AT/MT) & Driveline 12 07-02-2003 09:10 PM
How much psi will a stock 2.5 motor take? 2.5rsMI Normally Aspirated with bolt-on Forced Induction Powertrain 9 09-18-2001 05:19 PM
