Old 09-04-2005, 02:00 PM   #1
mamiyarz67
Member#: 55940
05 LGT 5SPD WGN
Brilliant Silver Metallic
Default So my parents are convinced they dont need premium
please please help me tell them that running plus in their 3.0 h6 in the tribeca that has a whoopping 2000 miles on it.
*sigh* i tried to tell my dad that the freeking computer will only handle So much knock and even then why bother, i know gas is mad expensive but an extra 10C a gallon wont kill them..
anyone got a coupla good reasons other than knock/detonation
he wont listen to me on that point - i need a "i put gas in and car exploded" story
i hate when they think they know more than subaru
mamiyarz67 is offline   Reply With Quote
Old 09-04-2005, 02:05 PM   #2
Ruff
Member#: 32131
2006 Nissan 350Z
Was 01 2.5 RS
The h6 doesn't need premium does it? Just use what the freakin car asks for.
Ruff is offline   Reply With Quote
Old 09-04-2005, 02:15 PM   #3
FalconRS
Member#: 92913
2005 2.5RS Wagon
Crystal Grey Metallic
I also was under the impression the H6 didn't require premium. Either way, should say on the inside of the gas flap. Just look, if it says regular unleaded recommended, no need to spend more money.
FalconRS is offline   Reply With Quote
Old 09-04-2005, 02:22 PM   #4
FalconRS
Member#: 92913
2005 2.5RS Wagon
I stand corrected, recommended fuel according to subaru is Premium 91.
Old 09-04-2005, 02:25 PM   #5
Ruff
Member#: 32131
2006 Nissan 350Z
Was 01 2.5 RS
Point that out to your parents mamiyarz67.
Old 09-04-2005, 02:43 PM   #6
El_Kameleon_G
Member#: 87103
2005 Impreza RS RWD
Plat'num Plus...SOLD!
It's not required if you're not punching it everywhere. That's the only time better fuel works. Not when you are on part thottle. I think you can use a grade under the recommended for a while.
El_Kameleon_G is offline   Reply With Quote
Old 09-04-2005, 04:04 PM   #7
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Tell your parents that they should use the fuel that the owners manual recommends. If they do not and the dealership find that there is fault with the car based on using the wrong grade of fuel, that their warranty will be voided.
You may have some people argue this point over on here but remember this. If you drove a Porsche 911 Turbo and you put 87 octane in it when the owners manual clearly states to use (insert higher/premium grade gas here), would Porsche as a company be responsible for engine damage or the owner of the Porsche?
Kevin Thomas is offline   Reply With Quote
Old 09-04-2005, 04:07 PM   #8
rs2.5-3.0
Member#: 52933
2008 LGCY2.5iSE.5.mt
want to do an STi conv ;)
took the words right outta my mouth
rs2.5-3.0 is offline   Reply With Quote
Old 09-04-2005, 05:20 PM   #9
Hayes
Member#: 11808
30,000 dollar car. Manufacture say minimum 91 octane. I think I would NOT use anything less and take a chance except for a real emergency like death or dismemberment and running the patient to the hospital. Why is an extra 2-4 dollars a week more importaint than the 5-6,000 dollar engine? JMHO eddie
Hayes is offline   Reply With Quote
Old 09-04-2005, 06:22 PM   #10
mamiyarz67
Member#: 55940
05 LGT 5SPD WGN
yeah thats what i dont get
they did this with their Audi A6 3.0L before (required plus, ran it on reg in the winter.. apparently because they dont need higher octane in the winter..)
which i said, no, with colder temps, more dense air = needs better octane, not lower!
yeah that could be a point that if they have problems and see the fuel itll be warr. void
Old 09-04-2005, 06:26 PM   #11
Jesse00
Member#: 78036
02 Impreza 2.5TS
Midnight Blue
just tell them if they continue using cheaper gas than required, they would need to get a new car soon. A blown engine from using incorrect gas wont be covered by warranty...
Jesse00 is offline   Reply With Quote
Old 09-04-2005, 06:30 PM   #12
poormansporsche
Member#: 79798
You should also point out that the low octane to high octane is getting cheaper. Whats the big deal now days? High octane is still 20 cents higher than regular and the price has tripled. Just say "You'll pay 45 dollars to fill up but 47 is too much?" I can almost see this being a bit different if gas was still cheap. Like 13 dollars vs 15 dollars. But you're already paying 45 or so 2 more bucks isn't going to break the bank.
Also! If your ride says 91 use 91. My old GTI would idle horribly if i used 89. Detonation kills engines. I say there is never a good reason to use less than what the manufacturer recommends. Even if you baby the throttle.
cheers
garrett
poormansporsche is offline   Reply With Quote
Old 09-05-2005, 12:22 AM   #13
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Well, I'll be the dissenter and say that a modern ECU is more than capable of compensating for using 89 or even 87 in an engine that's designed for 91. Will the performance be optimized? Obviously not. Is there any chance that the engine will be damaged or they could "blow the engine" by using lower octance gas? No.
Actually, that's not true. Engines are under much higher stress when temperatures are higher - the cooling system has a harder time removing heat from the engine, the air charge temperature is higher putting you that much closer to a knock/detonation threshold, etc.
From a Gasoline FAQ website - "You can often reduce the octane of the fuel you use in winter because the temperature decrease and possible humidity changes may significantly reduce the octane requirement of the engine."
"Back in the day", when cars were still carbureted and didn't have fancy electronics to run the engine, knock was way more likely to occur in the summertime, not the wintertime.
The density of the air coming in doesn't have anything to do with the octane requirement. There's a reason the engine has an ACT sensor - that's one of the inputs the ECU is going to use to determine air density and hence determine how much fuel to inject. If the engine is using a MAF (vice MAP), it's directly measuring the amount of air coming in. Either way, the denser air is mixed with more fuel to obtain the correct AFR, and the octane of the fuel has nothing to do with that.
Pat Olsen
'97 Legacy 2.5GT sedan
Patrick Olsen is online now   Reply With Quote
Old 09-05-2005, 09:56 AM   #14
rs2.5-3.0
Member#: 52933
As a rule of thumb, ALWAYS FOLLOW THE OWNER'S MANUAL!
mamiyarz67: I am not going to sound like a know-it-all, although I have the education/ experience to comment. So I will leave you with the following link which will more than answer your question.
I strongly suggest that you have you parents read it. Or print it and let them read it:
http://auto.howstuffworks.com/question90.htm
Good luck,
Brian
My parents are bums, they never leave their cel phones on Cjchaps Off-Topic 16 07-20-2007 10:54 AM
so my parents are leaving for a week... svek Off-Topic 29 06-15-2005 12:44 AM
"Crashed my WRX, so my parents bought me an STi...." 03WRXMA New England Impreza Club Forum -- NESIC 191 07-30-2004 08:00 AM
tires got slashed.... ne1 have old kuhmo ecsta 712 225/40/18 they dont need? LttLDGN Southern California Impreza Club Forum -- SCIC 7 08-18-2003 08:11 AM
Anyone got a stock hood they dont need? krazedant Tri-State Area Forum 1 06-25-2003 08:21 PM
Message Board Statistics All times are GMT -4. The time now is 03:10 PM.
