Old 09-04-2005, 04:45 PM   #1
DBSS_Gohan
Member#: 95140
Default Check engine light
Ok, new question, looking at an 00 RS with 130k on it just about, and It's got a check engine light. But otherwise seems fine. They say it's because the previous owner, lost the gas cap, and then put a new one on it, so it lost fuel pressure or somthing, and the ecu needed to be reset...
Now In my previous car experience... Reseting the ECU typicaly requires unhooking the battery, and holding the brakes, or some other variation, and then ta da, reset.
I know subaru has an ECU reflash thing that I've heard about with the tuning ports, and if you ever need to have your ECU put back to default... so my question is.. does that apply here? Or is it going to be another problem besides this?
ty in advance.
DBSS_Gohan is offline   Reply With Quote
Old 09-04-2005, 04:49 PM   #2
svek
Member#: 82259
1999 impreza 2.2L
Brilliant Red <4EAT Club>
its gonna be a different problem most likely. i lost my gas cap once, and was too lazy to get another one for about a month. never got an engine light. the general consensus around here is go to to autozone and they can hook up the ODBII scanner to the car and give you the error code. its going to be something like "p1130" so when you get that code go to this website http://www.iequus.com/obd_def.asp and type it in, it will tell you what the problem is. report back to us with the info.
svek is offline   Reply With Quote
Old 09-04-2005, 05:05 PM   #3
svek
Member#: 82259
1999 impreza 2.2L
crappy double post
Old 09-04-2005, 07:49 PM   #4
poormansporsche
Member#: 79798
Yeah if you have the gas cap it'll eventually go away. The computer will reset the CEL over a period of time (depending on what the code tripped was) and the MIL will turn off. If it doesn't turn off then it's still a problem. I'd get the code checked and maybe reset it and drive it around for a few days. If there is a problem the seller should be respectful of that. I could also be something like a misfire. Subarus can be known for that.
cheers
garrett
poormansporsche is offline   Reply With Quote
Check engine light, VDC light is on, and cruise control light is flashing grimace09 Normally Aspirated Powertrain 7 08-09-2012 04:42 PM
Check engine light, VDC light is on, and cruise control and sport light is flashing Legacymun2k6 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 01-30-2010 01:47 PM
check engine light, wierd engine trouble? gipoliceman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-14-2003 10:04 PM
Engine coolant temp sensor check engine light? rhdude Mid Atlantic Impreza Club -- MAIC 2 11-09-2002 03:42 AM
Engine vibrating, check engine light on codemunky Service & Maintenance 2 09-15-2002 08:50 AM
