Vancouver Impreza Club
Old 09-04-2005, 04:15 PM   #1
awdlifestyles
Member#: 77777
Default HELP!! My car won't start???
Hey guys, I can't get my car to start!! When I turn the key to start the car, none of the engine lights light up??? I have checked all the fuses, checked the battery and still nothing. Anyone have any ideas??
awdlifestyles is offline   Reply With Quote
Old 09-04-2005, 04:18 PM   #2
Gethin
Member#: 2998
Mods?
Gethin is offline   Reply With Quote
Old 09-04-2005, 05:13 PM   #3
awdlifestyles
Member#: 77777
none.
Old 09-04-2005, 05:36 PM   #4
Gethin
Member#: 2998
So you have full battery power, all your fuses are ok, ones under the hood and ones in the car, and when you turn on the ignition you get nothing? Can you hear the fuel pump prime?
Old 09-04-2005, 05:47 PM   #5
awdlifestyles
Member#: 77777
Yep battery is full, check fuses in both places. The problem is that there is no power going to the anything except the seatbelt light and the keyhole ring. The radio, windows, heater and stuff don't get power to them either. So I can't even roll up my windows. I turn the key and the door ringer goes off but none on the dash lights or check engine, battery lights light up?? I can't seem to get power to anything...not even the headlights when the key is turned on.
Old 09-04-2005, 05:54 PM   #6
lummer shawn
Member#: 71484
02 2.5 RS
BRP
are you sure the battery is actually full?
when my alternator went in my legacy, i had pretty much the same issue when i tried to start it, and that is cuz the battery was pretty much dead too. i hooked it up with jumper cables to another car and bamm, stuff started to come to life
lummer shawn is offline   Reply With Quote
Old 09-04-2005, 05:57 PM   #7
awdlifestyles
Member#: 77777
Yep its full, tested it with a volt meter.
Old 09-04-2005, 05:58 PM   #8
awdlifestyles
Member#: 77777
I wish it was that simple!!
Old 09-04-2005, 06:27 PM   #9
Gethin
Member#: 2998
If it's under warranty call up your Subaru care number. Strange that all the fuses check out OK and your battery is fine?
Old 09-05-2005, 12:45 AM   #10
awdlifestyles
Member#: 77777
Ya I will. But any suggestions though?
Old 09-05-2005, 02:15 AM   #11
Gethin
Member#: 2998
Fried ECU? The only thing I have seen similar is a blown ECU fuse, same symptoms. But in your case, if you say the fuses are OK, then I have no clue apart from a nuked ECU. Only way to find out is to go through step by step through the wiring diagram and locate the problem. Easier for you to call Subaru care as it's under warranty and you dont want to start dicking with it.
Old 09-05-2005, 02:28 AM   #12
awdlifestyles
Member#: 77777
OH SHEEET! You really think its the ECU?? DAMN!!!
Old 09-05-2005, 02:31 AM   #13
Gethin
Member#: 2998
It's possible. But without having a multimeter, the car in front of me, and the Subaru docs, who knows! Could be the main relay for example. Did anything lead up to this? Any symptoms or were you working on anything?
Old 09-05-2005, 02:37 AM   #14
2phless
Member#: 69343
1998 TransAm cnvrtbl
12 volts at the battery doesn't always mean it's good. Have you tried a jump start from another running vehicle? Does the starter even make the 'click'? If you use the old school trick of crossing the battery wire with the start-lead from the ignition ot the starter itself, will that turn the engine over? (do this out of gear.)
2phless is offline   Reply With Quote
Old 09-05-2005, 03:13 AM   #15
awdlifestyles
Member#: 77777
where is the ECU on the 2005 RS?
Old 09-05-2005, 03:15 AM   #16
awdlifestyles
Member#: 77777
Nope no symptoms, its just go crappy on me.
Old 09-05-2005, 03:16 AM   #17
awdlifestyles
Member#: 77777
No the battery is fine cause I drove it an hour before this happened.
Old 09-05-2005, 03:25 AM   #18
jstbstn
Member#: 35020
02 WRX - Stage WTF
04 WRX Wide Wagon - Stg 3
But if there is an alternator problem the battery wouldn't have been charging during that hour of driving, just having it's juice used up. It sounds like you should try jump starting the car before anything else. When my battery kicked the bucket, it was the same type of issue... drove fine then nothing, just pushed it past the limit.
jstbstn is offline   Reply With Quote
Old 09-05-2005, 11:49 AM   #19
rally_rx
Member#: 89103
1999 Forester
White/Yellow
sounds like an alternator problem to me, try jumping it there's nothing to loose. Volts dont mean everything on the battery you should check the amps,
rally_rx is offline   Reply With Quote
Old 09-05-2005, 12:49 PM   #20
AllWheelDrift
Member#: 9191
2002 Impreza 2.5TS
Blue Ridge Pearl
Or check the volts while trying to start it. You could be seeing good voltage with no load but if the battery is bad it may collapse under load.
AllWheelDrift is offline   Reply With Quote
Old 09-05-2005, 03:05 PM   #21
fukamoto
Member#: 13339
2014 SWP WRX Wagon
Underneath the footwell of the passenger side.
fukamoto is offline   Reply With Quote
Old 09-05-2005, 06:19 PM   #22
Gethin
Member#: 2998
The ECU only needs 10v or above to initialise. If you're turning the ignition key to ON and you are getting no diagnostic lights whatsoever, then it's ECU related. Also check your grounds.
Old 09-05-2005, 06:34 PM   #23
5 Zigen
Member#: 769
04 SoBaLo EsTea-ai
ZERO/SPORTS/99 GM6/05 BP6
so u have a 2005 RS? did u have any aftermarket alarm (or even factory installed "alarm"?)
it sounds like ignition switch problem to me...either ignition killed or the switch is gone by itself (rare for a new car)
who installed ur alarm if u have one?
5 Zigen is offline   Reply With Quote
Old 09-06-2005, 01:56 AM   #24
awdlifestyles
Member#: 77777
Nope no alarm, I'm seriously choked...
Old 09-06-2005, 02:29 AM   #25
Gethin
Member#: 2998
Dude, it's under warranty. Call Subaru care!
help my car won't start roccotrapani Normally Aspirated Powertrain 15 09-25-2009 07:37 PM
HELP!!! my car won't start... snthorne Service & Maintenance 8 04-04-2006 02:06 AM
HELP!!! My car won't start! snthorne Engine Management & Tuning 0 04-03-2006 09:47 PM
My car won't start need help immediately!! Chung Southern California Impreza Club Forum -- SCIC 14 06-19-2002 09:55 PM
My car won't start after clutch install! Please help!!! baldcherub Transmission (AT/MT) & Driveline 7 12-11-2001 11:35 PM
