Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 05-08-2001, 01:21 PM   #1
bryanw
Member#: 807
2002 WRX Wagon
Post 22B Displacement
I noticed something strange when I was looking over the specs of the 22B engine. The accepted story is that they started with an STi 2.0 engine and bored it out to get 2.2 liters. Now I looked up the specs and it claims to be 2212 cc. Now that sounds fine, but that happens to match the displacement of the 2.2 sold in the U.S. exactly! I think that's a heck of a coincidence.
One of three scenarios must be true here:
1) The specs are different and the 22B's engine is not 2212 cc.
2) The published specs of the U.S. 2.2 is wrong and it isn't 2212 cc.
3) The blocks are identical.
Anybody?
bryanw is offline   Reply With Quote
Old 05-08-2001, 01:25 PM   #2
Jewbaru
Member#: 1994
2013 Impreza WRX
Post
they're probably both bored EJ20 blocks, just the 22b block is an STi version. *Shrug*.
Jewbaru is offline   Reply With Quote
Old 05-08-2001, 01:46 PM   #3
bill harvey
Member#: 10
2005 Legacy Gt wagon
Garnet red pearl
Post
subaru only has 1 four cylinder block that is a ej20 the rest are that blcok bored and stroked even though they now cast the 2.5 and such as 2.5's but they all came from that design... just because something has the same displacement doesn't mean it is the same. the closest thing we have in the usa to the 22b block is the old legacy turbo block.
bill harvey is offline   Reply With Quote
Old 05-08-2001, 01:53 PM   #4
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
*nod* The 22B setup was basically a stroked 2.0L from what I understand.
Old 05-08-2001, 02:17 PM   #5
bryanw
Member#: 807
2002 WRX Wagon
Post
Yea, I know all that, but my point is why does it match the displacement of the U.S. 22B EXACTLY when they were supposedly engineered completely separately. That's one hell of a coincidence.
Ok, I just looked up the bore and stroke of both engines. THEY'RE IDENTICAL. How can that be when we've been told repeatedly that STi started with the 2.0 and massaged it to 2.2 liters EXCLUSIVELY for the 22B? If so, how in the hell could it possibly have the exact same bore and stroke as the American 2.2 that was around for the previous 5 years?!!?
Old 05-08-2001, 02:26 PM   #6
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
Maybe they tuned it exclusively for the 22B versus increased the displacement. *shrug*
Old 05-08-2001, 02:39 PM   #7
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
I think you've got your story wrong there pahdnah.
The EJ22 existed long before the 22B, before any Impreza. Just what do you think Subaru was rallying with in the early 90s?
Just because in 1998 they wanted to do the 22B and bring back the EJ22 turbo doesn't mean they would use anything but the old bore&stroke. Much better components than any previous production EJ22T ever got, no doubt-- truly unique engineering nah. It even has the same turbo as the STi4, undersized for the 22B by most estimations.
ColinL is offline   Reply With Quote
Old 05-08-2001, 02:54 PM   #8
bryanw
Member#: 807
2002 WRX Wagon
Post
From C&D:
"Mechanically, the 22B's major difference from the Type R STi is its bigger engine. An increase in cylinder bore punched out displacement to 2.2 liters, which Subaru says makes for better midrange torque"
I checked the specs and the 1.8, 2.0, and 2.2 all have the same stroke with different bores. The 1.8 and 2.0 have been around since the 80's so maybe it's just C&D's wording that I'm confused about. They make it sound like Subaru developed the 2.2 just for the 22B.
Old 05-08-2001, 02:58 PM   #9
scooby5
Member#: 1998
1999 Impreza STi v5
Silver Mica
Post
The 22b block is bored to 2.2l, not stroked.
scooby5 is offline   Reply With Quote
Old 05-08-2001, 03:58 PM   #10
Jay_UK
Member#: 296
Post
The 22B is not bored...
it is a 2.2 block... ala Legacy 2.2
It uses 96.9mm bore.. with a stock stroke
There is no way you can bore a 2.0 (92mm) bore out to 96.9mm
J.
Jay_UK is offline   Reply With Quote
Old 05-08-2001, 11:39 PM   #11
sjt
Member#: 4135
The Spurs will
RETURN!
Post
rsquire! where are you in our hour of need???
sjt is offline   Reply With Quote
Old 05-08-2001, 11:51 PM   #12
Blugin
Member#: 5270
2008 EvoX MR
Red
Post
On Gran Turismo (the athority of all things automobile ) it says that it has an ej22 block with ej20 heads among other things...
Blugin is offline   Reply With Quote
Old 05-09-2001, 12:26 AM   #13
SuicidalLabRat
Member#: 4096
noun [ ve·hi·cle ]
a carrier,as of infection
Post
Why is this a question? Even were it bored over, there would be no conspiracy; If I bore a 400 ci block over to 426 it doesn't make it a 426HEMI, I would not see the query in the identical cylinder size. Engines are cast differently, use different materials or grade compounds, are journaled different, bridged, open or closed; identical bore means nothing other than that, two engines with identical bore.
SLR-
SuicidalLabRat is offline   Reply With Quote
Old 05-09-2001, 12:37 AM   #14
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
Post
one word of advise, never belive an american car magazine. Though most of their info is correct, I recall that they too, suggested that the 22b makes actually 350hp according to a butt dyno. Just don't believe everything you read.
To take a closer examination of the 22b bottom end, You'll need to look at all the critical engine parts. Such as, oil pathways, crankshaft, tierods and bearings, pistons, Block tolerance, and Block molding tecniques. Obviously it's not just your run of the mill EJ22T block nor is it your everyday EJ20(a-gh) models. You can blow smoke of all kinds, but you'll have to ask the pro's on the UK board, might wanna ask prodrive and see if they had anything to do with the the design of the 22b
WRXwannbe is offline   Reply With Quote
22b front bumper with grill, 22b side skirts, 22b rear bumper, and Cwest front bumper D Spec Dc2 Private 'For Sale' Classifieds 51 05-17-2005 06:20 PM
No replacement for DISPLACEMENT?!? adamsrs Normally Aspirated Powertrain 181 06-30-2001 02:07 AM
instead of increasing displacement or raising boost how about... bayWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 05-25-2001 10:59 AM
possible to increase displacement on new WRX? jmott Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 27 05-21-2001 09:03 AM
stroking the EJ engine for more displacement chyisan Technical Forum Archive 31 09-06-2000 01:53 PM
