Old 09-04-2005, 11:12 PM   #1
moby4dick
Member#: 51901
'04 WRX
Subaru Stars GP Moto GT32 twin scroll, Rallispec twin scroll, any experience?
I"ve been really intrigued by a twin scroll turbo kit, but have not read of ANYONE using it.
Anyone?
Also, regarding the GPMoto kit, I was curious if you could use a standard downpipe, or if due to the so called rotated mount, you HAD to use theirs. I'd like to have at least one cat and I think the GP Moto setup is catless. Thus ideally, I'd get the turbo, headers and supporting oil lines/misc hardware but use someone elses TBE. Guess I'll be giving those guys a call.
Similarly, anyone tryout the factory twin-scroll setup like Rallispec sells? Same questions as the GPMoto.
Thanks!
moby4dick is offline   Reply With Quote
Old 09-05-2005, 12:04 AM   #2
line
Member#: 76189
WRX: Parking Lot
Racer in Training
Recently I have been playing with the idea of running a twin scroll setup. From what I have pieced together if you buy a standard Subaru twin scroll kit it will come with a DP from Subaru (not the same as our DP, different bolt pattern) with a cat in it. It should also have the headers, uppipe, turbo, oil pan, oil feed lines, and a dip stick for the new pan. The GP moto kit needs it own DP also because garret doesn’t make direct bolt on turbo for our cars to my knowledge.
If you talk to the GP moto people please let me know when the turbo spools on our little 2.0L and what max HP we should expect to see.
For more info on the VF37 setup talk the guys at www.IAPERFORMANCE.com.
Best of luck
line is offline   Reply With Quote
Old 09-05-2005, 01:07 AM   #3
moby4dick
Member#: 51901
'04 WRX
I'll try and talk to the GPMoto people on Tuesday.
Rallispec offers the PE1825 option with the factory twin scroll kit. But with the factory kit, I'm assuming there will be at least 2 cats, both in the DP and the midpipe going to the muffler. That's one too many for me. Do you know if the UP has one as well?
Old 09-05-2005, 01:00 PM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
fwiw there are 2 uppipes with a twin scroll and no cats... and a jdm twin scroll DP won't bolt to a USDM cat back either (differnt lengths)
and no you won't be using a standard DP with the GPmoto kit but its my understanding that you can use a standard cat back
Old 09-05-2005, 01:05 PM   #5
line
Member#: 76189
WRX: Parking Lot
Racer in Training
www.IAPERFORMANCE.com is alot cheaper then rallispec. They are also good about returning emails (no idea how rallispec is).
Old 09-05-2005, 01:57 PM   #6
spankaveli
Member#: 42826
1999 Toyota Corolla
Tan
FWIW, Rallispec has returned all my emails very promptly.
spankaveli is offline   Reply With Quote
Old 09-06-2005, 12:48 AM   #7
moby4dick
Member#: 51901
'04 WRX
Unhappy
So based on this, with either the GPMoto kit OR the twin scroll kit, there is no "bolt on" solution for going with at least one cat? Makes it pretty hard to pass emissions!
Old 09-06-2005, 08:04 AM   #8
fragment
Member#: 8050
2004 FXTi - Stage 2
Goooooooolld
I have a OEM twin scroll with a Turbo XS downpipe and cat. All it took was a twin scroll flange from IA Performance and a good welding shop. Not "bolt on" but not really fabricated either.
fragment is offline   Reply With Quote
Old 09-06-2005, 08:27 AM   #9
J-Rex2004
Member#: 68490
'04 tippin' on
fo'fo jackstands.
JDM DP does have 1 cat in it. The you can get one of these JDM catbacks.
J-Rex2004 is offline   Reply With Quote
Old 09-12-2005, 02:02 AM   #10
eclip5e
Member#: 14686
2002 RASpec Impreza
Dent Sport/visual assault
That TurboXS downpipe replaces the midpipe as well, correct?
eclip5e is offline   Reply With Quote
Old 09-12-2005, 02:06 AM   #11
eclip5e
Member#: 14686
2002 RASpec Impreza
That Cusco one says its JDM spec, but fail to go into detail on what that means.
If it means the turbo flange side is JDM spec, then it will bolt right up to the twinscroll bellmouth-style flange.
If it means something else (length, or catback end spec) then it could be a problem?
Any more detail on that dp?
Old 09-12-2005, 08:20 AM   #12
fragment
Member#: 8050
2004 FXTi - Stage 2
Goooooooolld
Its a short style downpipe with a separate 3" mid pipe with high flow cat.
Old 09-12-2005, 08:59 AM   #13
J-Rex2004
Member#: 68490
'04 tippin' on
fo'fo jackstands.
I said get one of these catbacks...the ralli spec twin scroll setups come with the JDM DP. FWIW, the CUSCO does not have a twin scroll flange, its just the length that is different. I don't remember if the JDM DP's are longer or shorter than the US ones, but there is a difference.
Old 09-13-2005, 06:09 PM   #14
eclip5e
Member#: 14686
2002 RASpec Impreza
I think the easiest thing is to welde the twinscroll flange onto a Helix bellmouth or Invidia.
Old 02-12-2006, 03:00 PM   #15
o2sys
Member#: 43842
200? WRX STI
back to the subject here, so does anyone had a GT32 or a VF twin scroll on the USDM 2.0L how well does it hold, or how long will ht last?
o2sys is offline   Reply With Quote
Old 02-13-2006, 02:12 PM   #16
o2sys
Member#: 43842
200? WRX STI
bump....
Old 02-13-2006, 03:41 PM   #17
line
Member#: 76189
WRX: Parking Lot
Racer in Training
If you buy a VF37 kit its OEM on cars in japan so i would image that as long as you treated it well it should last along time. Now if your wondering about power then this might help you:
http://www.ktrperformance.com/dyno_t....php?id_num=19
Old 02-13-2006, 03:43 PM   #18
o2sys
Member#: 43842
200? WRX STI
well for the VF37 i figure it not as bad since VF are small turbos, but how about the GT32? is GT32 even a true twin scroll? where would you get a uppipe for it?
GT32 twin scroll turbo kit from GP MOTO preliminary dyno results!! Dynamispeed Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 130 09-09-2004 11:11 PM
I drove the GP Moto GT32 kit on STI! downshift1 Proven Power Bragging 60 08-18-2004 08:59 PM
GP MOTO Twin Scroll Garrett GT32 turbo kit for STI. Let's take it to the next level!! Dynamispeed SCIC Vendor Classifieds 18 04-05-2004 07:58 PM
GP MOTO Twin Scroll Garrett GT32 turbo kit for STI. Let's take it to the next level!! Dynamispeed Vendor 'For Sale' Classifieds 39 03-06-2004 12:52 PM
