Welcome to the North American Subaru Impreza Owners Club Saturday July 12, 2014
Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 09-05-2005, 12:41 AM   #1
ix8vii
Member#: 77623
0508 STi OBP
0008 Forester S/LLB
Default Would the aftermarket FMIC fail the smog test in california.
What would be the main reason for failing the smog test.
ix8vii is offline   Reply With Quote
Old 09-05-2005, 12:42 AM   #2
AntiochCali
Member#: 30185
2003 320 whp
on a heatbreaker dyno
Yes, I believe it will fail the visual inspection....
AntiochCali is offline   Reply With Quote
Old 09-05-2005, 09:59 AM   #3
titsataki
Member#: 4402
2009 Outback XT
well. It depends. A FMIC or rather an intercooler is not a CARB item. However a BOV is one. So a FMIC with the stock BPV should be ok. There where it gets complicated. If you use a non stock intake you will fail. If you use a CARB approved intake again you should be ok.
You will have to take it to the referee and have it certified.
There are threads about that in the local CA forums here and the "other" Impreza club.
Cheers
Nick
PS: you can always put it on and run it. I do not think you can go to the referee on your own but not sure. (meaning an officer can write you up and send you to the referee). Me personally I am not yet ready to cut my bumper for a FMIC. Oh by the way if you have to cut or remove the bumper beam that is ilegal as well.
titsataki is offline   Reply With Quote
Old 09-05-2005, 11:52 AM   #4
metoo
Member#: 4764
2004 STi sold :(
forizzle
Putt the stock TMIC on, reduce the boost, and cap off your FMIC fender pipes. There's no law against a FMIC that is purely for show, is there?
metoo is offline   Reply With Quote
Old 09-05-2005, 12:04 PM   #5
ix8vii
Member#: 77623
0508 STi OBP
0008 Forester S/LLB
Darn. That really limit the situation back here. With those portable smog station popping like mushrooms on side streets.
Old 09-05-2005, 07:46 PM   #6
OMEGA SUPREME
Member#: 89995
05 Broke STI
glad i dont live in cali anymore
OMEGA SUPREME is offline   Reply With Quote
Old 09-05-2005, 09:38 PM   #7
Jon [in CT]
Member#: 2992
02 WRX Sedan
Guess again. Here's an example of a CARB EO issued for a replacement intercooler and its associated piping: http://arb.ca.gov/msprog/aftermkt/de...eo/D-354-1.pdf.
Jon [in CT] is offline   Reply With Quote
Old 09-06-2005, 02:48 PM   #8
ix8vii
Member#: 77623
0508 STi OBP
0008 Forester S/LLB
Jon so what's the english term. The way I see it that only applies to certain intercoolers. How about for our newer Subarus.
Old 09-06-2005, 03:17 PM   #9
Jon [in CT]
Member#: 2992
02 WRX Sedan
An EO lists the year/make/model for all the vehicles to which it is applicable. If someone installs that same equipment on a vehicle not covered by the EO, then the EO doesn't apply and the installation wouldn't be CARB-legal. Since nobody, so far, has gotten an EO which covers an aftermarket intercooler installed in a Subaru, there are no aftermarket intercoolers which are legal to use on Subarus in California.
If someone were to make an intercooler that met all of Subaru's specs for the stock intercooler, then it could be considered a "replacement" part, which would be CARB-legal. But who'd want to buy an intercooler that performed exactly the same as Subaru's? Maybe if it were pretty - for the bling factor.
You can search CARB's lists of EOs issued so far at http://www.arb.ca.gov/msprog/aftermk...es/amquery.php.
will i pass the smog test in california? newerWRX Newbies & FAQs 14 04-08-2007 04:06 PM
Anybody Heard Anything about the new smog test in NY? coyote73176 Tri-State Area Forum 7 05-21-2003 06:50 PM
Failed CA Smog Test - NOx too high AVATAR-X Service & Maintenance 5 01-31-2003 02:46 AM
New OBD-2 Smog Test in MD? z&cobb Mid Atlantic Impreza Club -- MAIC 24 08-16-2002 06:30 PM
Dyno Style Smog tests in Collin County and Dallas StevieD Texas Impreza Club Forum -- TXIC 2 03-19-2002 07:50 AM
