Old 08-20-2001, 02:39 AM   #1
Greg Sharpe
Member#: 741
04 EVO SSL
Asphalt Black
Default Stiffer front sway bars - GC8 & WRX
I had been using a Whiteline 18-22 bar for a few autoXs, but didn't like how the car handled. The car would roll alot, and it would swap ends too late during the turn. The rest of the car was totally stock and I was super broke at the time, so springs or struts were out of the question. After watching some video of my car at the autoXs, I noticed a gross amount of body roll, even with the rear bar set at 20mm. So I crossed my fingers and ordered a Whiteline 19mm front bar. To my supreme delight, the car has more overall traction, better turn-in, and ...get this, it spins out easier! (with both bars installed, rear @20mm)
You're confused, here's why. Whiteline bars are stiffer than FHI at any given diameter, and by alot. I've tested a bunch of sway bars buy both manufacturers, and the difference is noticible even when just puttering around town. So the jist is that Whiteline's 19mm front bar is stiffer than the stock GC8 20mm front bar, and the car will handle better with the smaller Whiteline bar!
I posted this because I've heard people say "stiffer front bars are bad, they make the car understeer" too many times. It can be true that a larger front bar will cause more understeer, but take it from someone like KC from NESIC, with a 22mm front bar on his WRX running in G-stock, the car turns in faster which means faster runs!
This is a discussion regarding this from a while back, good suspension speak stuff here: http://www.i-club.com/forums/showthr...threadid=81469
This is a recent thread that eventually becomes a product review of a 22mm front bar on a WRX wagon: http://i-club.com/forums/showthread....threadid=17949
I hope this helps someone with limited funds be more competitive or enjoy a better handling Impreza.
Greg Sharpe is offline   Reply With Quote
Old 08-25-2001, 12:07 AM   #2
DuBYARX
Member#: 6549
2002 SRP-WRX
92 Ice Blue Legacy Wagon
Ok here come the questions:
What is the size of the stock front bar on the WRX?
If I change the front bar should I change the rear to an adjustable one?
(Front ) What size 20mm or 22 mm?
Does the front bar contain most of the body roll?
Thanx
DuBYARX is offline   Reply With Quote
Old 08-25-2001, 01:54 AM   #3
Greg Sharpe
Member#: 741
04 EVO SSL
Asphalt Black
From experiance with my RS, I'd say the front bar has more leverage to controll body roll, than does the rear bar.
FS "SPT package" 19mm front sway bar from 02 wrx. Will fit 02-03 maybe 04-05 wrx??? Davenow New England Impreza Club Forum -- NESIC 7 09-01-2005 01:19 PM
Front Sway Bar GC8 Install Tips? hacman Mid West Subaru Owners Club Forum -- MWSOC 9 03-02-2003 09:13 PM
FS: used spt front sway bar for 02 WRX [freeman] Canada Region Forum 11 01-25-2003 11:45 PM
Whiteline front sway bar GC8 Q. obyone Brakes, Steering & Suspension 8 11-25-2002 06:14 PM
I need some help... Front Sway bar install on WRX Wagon Whelp Bay Area Impreza Club Forum -- BAIC 10 07-25-2002 06:00 PM
