Old 09-06-2005, 12:54 AM   #1
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
'96 BrightonCoupeWRX-SR30
Legacy Injector volume EJ22T
on a EJ22T what is the volume on the stock pink ball injectors?
Kawikid20o2 is offline   Reply With Quote
Old 09-06-2005, 01:11 AM   #2
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
360cc
Ben
Old 09-06-2005, 01:28 AM   #3
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
Legacy
sweet...thanks alot!
Old 09-06-2005, 02:45 AM   #4
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
You can always get new yellow STI injectors. I think they are 555 cc.
subiekid is offline   Reply With Quote
Old 09-06-2005, 03:02 AM   #5
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
Legacy
they will fit the rail?
Old 09-06-2005, 10:54 AM   #6
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
Not the stock turbo rail.
They fit perfect into the '90-'94 n/a rail.
The STi injectors are the same shape as the early n/a injectors, but different from the turbo injectors.
IronMonkeyL255 is offline   Reply With Quote
Old 09-06-2005, 01:35 PM   #7
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
Legacy
ok so i would have to get an N/A fuel rail if i wanted to change to yellow tops.
Just one other thing...do you know how much hp those stock injectors are good for.
Old 09-06-2005, 04:10 PM   #8
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
Hmmm...
Depends. I think that they aren't good for too much over stock boost.
One of the guys on legacycentral is pushing the limits with 16PSI on the stock injectors and a Walbro fuel pump. I believe he is only running a bit over 200 WHP.
Someone please correct me if I'm wrong.....
Old 09-06-2005, 05:24 PM   #9
cowapult
Member#: 25324
2016 WRX
Dark Gray Metallic
That sounds about right. I think Phil basically maxed out what can be done with stock fuel system and stock engine management:
[email protected], [email protected]
cowapult is offline   Reply With Quote
Old 09-06-2005, 07:32 PM   #10
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
Legacy
hmm thats not that bad 16psi, i dont have an upgraded fuel pump but i just want to run closer to 10 psi instead of 7 what i am getting now
Old 09-06-2005, 10:21 PM   #11
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
The sti yellow injectors only fit in the 92-94 n/a rails, and NOT the 90-91 n/a rails.
Legacy777 is offline   Reply With Quote
Old 09-06-2005, 10:47 PM   #12
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
Legacy
do i have to upgrade my pump and injectors or will they be ok for 10psi
Old 09-06-2005, 11:47 PM   #13
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
Oh, yeah. Forgot to mention that.
Old 09-07-2005, 12:51 AM   #14
cowapult
Member#: 25324
2016 WRX
Dark Gray Metallic
Are you on the stock turbo?
Your car should already be running 9ish psi stock... automatically... as it was configured from the factory. Mine did. So yes, the fuel system can handle 10psi.
Old 09-07-2005, 09:30 AM   #15
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
Legacy
no i am running a TD04 and wrx top mount i think i might have to replace the vacume lines or something
Old 09-07-2005, 02:52 PM   #16
Legacy777
Member#: 4800
It'd be a good idea to upgrade to the walbro 255l pump.
Old 09-07-2005, 03:16 PM   #17
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
easy install on those? or do u have to drop the gastank?
Old 09-07-2005, 04:07 PM   #18
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
Easy install.
Just remove the carpet from the trunk to access the maintenance plates. Unscrew the passenger side one to expose the top of the fuel tank. Remove several 8mm (i think) bolts (carefully and with lots of PB blaster) and unplug an electrical connector. Then just pull the whole shebang out and strap on the new pump.
Installation is reverse of removal.
Old 09-07-2005, 04:39 PM   #19
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
how long should that all take, like an hour or something. it doesnt sound that hard.
Old 09-08-2005, 12:36 AM   #20
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
It took me about an hour or so.......
It really isn't that hard. You just have to know where everything is and how to remove it.
Old 09-08-2005, 01:40 AM   #21
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
Legacy
I have a leg. wagon would the pump be near the spare tire? or is more forward or backward of it.
Old 09-08-2005, 09:43 AM   #22
cowapult
Member#: 25324
2016 WRX
Dark Gray Metallic
there's an access panel between the spare tire and the rear seat under the carpet.
Old 09-08-2005, 10:39 AM   #23
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
Legacy
Great thanks alot guys!
EJ22t injectors, heads, int. man, 2.5RS injectors, and more NicFunkadelic Private 'For Sale' Classifieds 41 05-18-2006 11:03 AM
EJ22t Injectors on 1998 RS2.5? buraddo Normally Aspirated with bolt-on Forced Induction Powertrain 9 09-05-2003 03:02 PM
Some (possibly) good data with 12psi on an EJ22T on stock injectors & ECU Eric SS Normally Aspirated with bolt-on Forced Induction Powertrain 2 04-17-2003 03:18 AM
FYI: EJ22T injectors in an EJ22-T w/piggybacks wac Normally Aspirated with bolt-on Forced Induction Powertrain 26 09-01-2001 03:23 PM
Part #'s for EJ22T injectors and fuel rails... MPREZYA Normally Aspirated with bolt-on Forced Induction Powertrain 1 08-06-2001 04:03 PM
