Welcome to the North American Subaru Impreza Owners Club Thursday June 20, 2013
Old 09-06-2005, 02:29 PM   #1
Mike1967
Member#: 87762
Default Need help identifying part# for Rear CAM Seals
I want to replace the front and rear seals for my 2.5 SOHC.
Unfortunately every part store I have called only lists the front CAM seal. They have no listing for the rear seal.
Is there another name for this seal ?
The front CAM seal looks like a rubber washer. The end of the CAM shaft fits through the seal. It is the end of the CAMSHAFT that attaches to the timing belt sprocket.
The rear seal is a solid rubber seal...like a plug.
Any help is greatly appreciated !!!!!!
Mike1967 is offline   Reply With Quote
Old 09-06-2005, 06:08 PM   #2
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Plug
part number 807045040
Tim Sanderson is offline   Reply With Quote
Old 09-06-2005, 06:32 PM   #3
Mike1967
Member#: 87762
Originally Posted by Tim Sanderson
Plug
THANKS !
Old 09-06-2005, 06:45 PM   #4
Seeinstars
Member#: 31226
2000 2.5RS coupe
2004 jbp forester xt
You shouldn't have to replace the rear cam seals, just get all the old rtv off, and put new rtv on and tap them back in. I never replace them. They don't come in the rebuild kits, and my dealership usually doesn't stock them.
Seeinstars is offline   Reply With Quote
Old 09-06-2005, 07:04 PM   #5
Mike1967
Member#: 87762
Cool...that is exactly what the guy at the machine shop told me.
This is probably going to sound stupid...but what is RTV ?
Old 09-06-2005, 07:22 PM   #6
Seeinstars
Member#: 31226
2000 2.5RS coupe
kinda like silicone, its what is used when putting the engine, transmissions, heads, everything. the better stuff is grey, there's also black.
Don't know what it stands for, (brain fart) can't think of it right now, but you'll definatlly need it. Go to autozone, and ask for it.
Old 09-06-2005, 07:39 PM   #7
Mike1967
Member#: 87762
Gasket putty ?
Old 09-06-2005, 08:08 PM   #8
Seeinstars
Member#: 31226
2000 2.5RS coupe
Gasket putty ?
kinda like that. liquid gasket. It's what you have to have though, or it will leak.
Old 02-11-2006, 10:56 PM   #9
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
room temperature vulcanizing
ss
subysouth is offline   Reply With Quote
Old 02-13-2006, 10:01 PM   #10
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
ss
^^^^^what he said.
Old 04-22-2007, 08:57 AM   #11
MK19_
Member#: 49148
Dogs are forever in
the pushup position...
Originally Posted by Tim Sanderson View Post
Plug
I ordered those and they appear to be the plugs for the front. On the plus side however, I inspected the rears and they are good to go. Replacing the fronts however... is gonna be a bitch
MK19_ is offline   Reply With Quote
Old 04-22-2007, 02:16 PM   #12
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
i use the grey rtv, it has a 650 degree F. rating.
~Josh~
Need help identifying rear calipers MicMcKee Newbies & FAQs 4 08-30-2009 11:30 PM
Need help identifying '04 Rear Spats / Skirts jtsherri Interior & Exterior Modification 18 02-10-2008 07:20 PM
Need help identifying a noise in the right rear cnk Brakes, Steering & Suspension 14 02-03-2005 02:59 PM
Need help identifying rear suspension problem Egan Brakes, Steering & Suspension 7 12-01-2003 05:57 PM
Right rear cam seal Kevin Thomas Normally Aspirated Powertrain 4 12-02-2000 06:44 PM
Message Board Statistics All times are GMT -4. The time now is 05:31 AM.
