Old 09-06-2005, 07:09 PM   #1
mannslayer
Member#: 94978
Question 02RS Cold Air Intake Install
Just bought a cheap ebay CAI for my 02RS, and the damn thing didn't come with any instructions, and I am certainly no expert under the hood to boot... Can someone help me with what I need to do to install this thing properly with maybe some pictures? Thanks.
mannslayer is offline   Reply With Quote
Old 09-06-2005, 07:43 PM   #2
impr25rs
Member#: 60162
04 Aspen RS
The One Not Turbo'd, NA!!
First Off I am assuming that it is like an Injen intake (2 piece plumbing with intake
First off remove the stock air filter box and plumbing. The bolts that hold all the front box are a little tight to get to.
Remove the vaccum hoses and note the order they are in.
Lossen the hose clamp that is on the airbox/throttle body (use a screw driver or socket)
I would then jack the car up on the passenger front and remove the tire.
Then insert the little silicon tape like strap that goes around the hole for the CAI so it doesn't rattle (metal to metal conact)
I would take the smaller piping that fits in the wheel well and attact the silicon hose and hose camp on the end that will go from the engine bay to the well.
I would insert the piping section that piping into the fender and the piping will kinda follow the wheel well.
Then insert the cone filter with a hose clamp on it. This will be tight. Connect the filter the piping and use a screw driver to tighten.
Then take the longer piece and attach it to the silicon hose from the first piping piece using another hose clap.
Attach the longer to the throttle body with a silicon hose and clamp.
Reattach the vaccum lines.
I believe you have to plug the IAT sensor hole with a little plug supplied by the kit.
Here is a pic of my injen, hopefully it will help
impr25rs is offline   Reply With Quote
Perrin Cold Air Intake Install jpjester Newbies & FAQs 41 01-16-2010 11:06 AM
cold air intake install 03clipsegts Interior & Exterior Modification 10 06-19-2006 06:39 PM
OBX Cold Air Intake Installation KCG17 Normally Aspirated Powertrain 1 07-18-2002 03:53 PM
AEM Cold Air Intake Installation Instructions Imprezer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 05-16-2002 01:30 PM
AEM cold air intake installed Bradus Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-31-2001 12:18 AM
