Old 09-06-2005, 03:39 PM   #1
Mike1967
Member#: 87762
Default Head replacement Budget
Thought I would share the my $ numbers for the head job that I am about to complete.
2 1/4 Ton Engine Hoist - $ 150 (Advance Auto Parts)
750 lb engine stand - $ 40 (Advance Auto Parts)
Both Heads Resurfaced - $ 47 (Total for both)
Torx Plus Bit for Cam Cap Cover - $ 20.00 (Snap On)
12 Point 14 MM Socket for Head Bolts - $ 18.00 (Snap On)
Feeler Gauges - $ 5.00 (Advance Auto Parts)
Head Gaskets - $ 26.88 each ($ 53.76 total) (Van's Auto Parts)
Front CAM Seals - $ 3.75 each ( $ 7.50 total) (Van's Auto Parts)
Head Bolts - $ 67.00 a set ( $ 134.00 total) (Van's Auto Parts)
TOTAL = $ 475.26
Mike1967 is offline   Reply With Quote
Old 09-06-2005, 05:46 PM   #2
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Good stuff, Thanks.
Got some part Numbers?
Tim Sanderson is offline   Reply With Quote
Old 09-06-2005, 05:55 PM   #3
impr25rs
Member#: 60162
04 Aspen RS
The One Not Turbo'd, NA!!
This will help me out later
Not to hijack your thread, but if you wanted to remove the valve springs and retainers, what do you need? Do you need a specific tool from Subaru? I heard that you do, but I don't know for sure.
impr25rs is offline   Reply With Quote
Old 09-06-2005, 06:02 PM   #4
Mike1967
Member#: 87762
No Prob !
Check the thread entitled "Help with crank/cam pulleys and timing belt" below on this same page. It is not necessary on my 2.5 DOHC because it has hydraulic valves that realign themselves.
Whats a good yet budget gear set to replace 04 WRX wtfh4xx Transmission (AT/MT) & Driveline 13 09-28-2009 08:27 PM
5 Speed replacement on a budget!? Wheel Man Transmission (AT/MT) & Driveline 1 03-15-2009 08:45 AM
Ej205 replacement $3k budget hybrid gti 2 Subaru Conversions 2 02-12-2009 01:20 PM
Need to get my engine rebuilt/block replaced on a budget whtlegacy Mid West Subaru Owners Club Forum -- MWSOC 5 08-19-2008 11:06 AM
Replacing speakers on a budget strohausii Car Audio, Video & Security 47 04-01-2005 09:38 PM
