Notices
Old 09-06-2005, 08:04 PM   #1
t3hWIT
Member#: 58779
95 STi RA (rhd)
98 Tacoma (300k Club)
Default 95 1.8L - SAFC2 install???
Yesterday, after over a year and a half of debating (and deciding if its worth the money) I finally broke down and bought an Apexi S-AFC II, which teamslow wrx has up for sale. I thought great. Now i can tune for my basic mods and i have something to adjust in the long run.
Then it hit me. How the hell do I wire this thing? I mean im seeing posts on it being installed on newer RS's, but this is a 95 1.8L. I haven't been able to find much about the install on these engines. Now I obviously didnt receive it yet and dont know what all has to be wired, but I know it has to be wired to the ECU... which is another thing. I'm having a hard time finding a reliable ECU printout.
With that, any help would be appreciated.
thanks
-shaun
t3hWIT is offline   Reply With Quote
Old 09-07-2005, 09:34 AM   #2
leondal
Member#: 43114
1998 Legacy GT Turbo
Green
There are definitely wiring diagrams online for your ECU.
I can't remember where I got mine, but it wasn't terribly
difficult to find.
The actual wiring was pretty easy, too. Just remember that
you have a hotwire type maf sensor. The booklet will
tell you what color wires go to which wires on your harness,
you just need the wiring diagram to show you which wires
in the harness are your knock sensor, maf sensor, power,
throttle sensor, and rpm sensor.
And, yes, it made a hell of a difference, especially above
4000 rpms, where the car was running incredibly rich.
Good Luck!
leondal is offline   Reply With Quote
Old 09-07-2005, 09:58 AM   #3
t3hWIT
Member#: 58779
95 STi RA (rhd)
Sparky280 sent me a pdf diagram of the ecu wires and what sensors they go to. with that said this doesn't look too bad...
Old 09-07-2005, 11:21 AM   #4
mnlegacy
Member#: 94787
could someone send me the same pdf?
mnlegacy is offline   Reply With Quote
Old 09-07-2005, 01:54 PM   #5
t3hWIT
Member#: 58779
95 STi RA (rhd)
sure. pmd yah
Old 09-07-2005, 02:14 PM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
so do you have access to a wide band o2 .. w/o one an safc is a blinky light tool
Old 09-07-2005, 02:43 PM   #7
t3hWIT
Member#: 58779
95 STi RA (rhd)
no. its a blinky light tool. im on a college buget and a 500 wideband unfortunatly is out of my price range. id sure a hell love to have one thoh, and i am aware of its importance tuning-wise. i just cant afford it right now.
Old 09-07-2005, 03:10 PM   #8
Sparky280
Member#: 69896
98 WRX Swapped "L"
VF39 294HP/277TQ @19psi
just do the blue wire mod for a quick tune, until you can afford a wideband, or pay $$ to get dyno tune, i hear you get the most out of your AFC with a dyno tune.. i wouldnt know either cause i'm also poor...
Sparky280 is offline   Reply With Quote
Old 09-07-2005, 03:29 PM   #9
t3hWIT
Member#: 58779
95 STi RA (rhd)
now what exactly is this blue wire mod? ive searched it a couple different ways and from what I'm seeing is that you connect the extra MAF wire to the o2 sensor wire. im guessing on that one its meant for the front one (if this car also has two). however, im looking at voltage suggestions and the first one i saw was .78 as typical. but then i got different numbers as alot of people are thinking different things as far as that goes. any suggestions?
as far as anyone else needing diagrams, I have some from BeachBum and Sparky280 which i am willing to send to anyone who needs it. that would of course be through email.
Old 09-07-2005, 04:23 PM   #10
Sparky280
Member#: 69896
98 WRX Swapped "L"
yeah the blue wire mod is connect the extra MAF (blue wire) to the front o2 sensor on your ECU, and the typical stoich voltage of what i have read is .84v there's a few websites that have info on tuning with blue wire mod, just search google for it, there not for tuning a suby, i think there's a site on tuning an eclipse but it gives you a basic idea of how to do it.
Old 09-07-2005, 04:27 PM   #11
t3hWIT
Member#: 58779
95 STi RA (rhd)
ok. il do that. now this blue wire mod is my ghetto wideband? i mean is this how im going to tune it?
Old 09-07-2005, 04:55 PM   #12
BlkTS02
Member#: 50142
2002 2.5TS
MBP
Yup, set the SAFC to display "sensor chk". Ideally you'll want to adjust the a/f ratio so the sensor voltage stays around .84v at wot.
BlkTS02 is offline   Reply With Quote
Old 09-07-2005, 06:10 PM   #13
t3hWIT
Member#: 58779
95 STi RA (rhd)
yet another thing. the car this is being installed on is a 95 1.8, which i dont actually have in my posession yet. im going back home on saturday to pick it up, and then mod it the second weekend after. (mods salvaged off my 97 2.2L)
my question is, is this an OBD 2 car? sure its a 95, but it shares the same basic body style (that has proven to be important, worked at Autozone, checked CELs), and ive seen sone obd2 cars as far back as 93. is this one of them? i know it has a port there, but im not exactly how the ECU is set up...
Old 09-07-2005, 10:46 PM   #14
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
My 95 is OBD 1 and you check by using the black connectors next to the steering column. Check the ravensblade website and they have the ecu pinout. It is for a 93 but mine was the same and it's 95. The diagrams even tell you the voltage the wires are at so you can check them to verify they are correct.
2slofouru is offline   Reply With Quote
Old 09-09-2005, 08:45 PM   #15
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
NONO NO
the blue wire mode is worthless
A narrow band sensor basicly reads 3 states leaner than 14.65 ,14.65 and richer than 14.65
that said a car makes th most power at some where between 11.5 and 12.5 to 1 .. a narrow band sensor won't read below 13.2 at all
Old 09-13-2005, 10:49 AM   #16
t3hWIT
Member#: 58779
95 STi RA (rhd)
got another question here dealing with spark plugs and detonation. keeping in mind i dont have access to a wideband, i have to rely on the blue wire mod, as suggested by most.
my question is, to avoid detonation, should i go one step colder as far as spark plugs go? i know it is suggested for major mods such as boost/nitrous, and this is a somewhat minor mod, but would it help as far as avoiding detonation? current mods for the car are intake and exhaust for now.
Old 09-13-2005, 02:55 PM   #17
jamp555
Member#: 80754
1995 Impreza 1.6GL
I'm also fitting an S-AFCII to my 95 UKDM 1.6GL AWD and the unit arrived today. My ECU says this on it:
N3
22611 AA780
MECF-B10 E1 4228
Hitachi, Japan
Is that the same as in a 95 1.8? (I believe the 1.8 and 1.6 are the same engine except for con-rod length, correct?) If so could I have the PDF wiring diagram too please?
Thanks,
Ben
jamp555 is offline   Reply With Quote
Old 09-13-2005, 05:26 PM   #18
t3hWIT
Member#: 58779
95 STi RA (rhd)
N3
22611 AA780
MECF-B10 E1 4228
Hitachi, Japan
Thanks,
Ben
dude, as far as that goes, i didnt know they made a 1.6
i would look it up on alldata, but thats usdm. if you want the diagrams thoh, i have a few here.
Old 09-13-2005, 05:41 PM   #19
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
they make a 1.6 in other countreis
99subi is offline   Reply With Quote
Old 09-14-2005, 06:03 AM   #20
jamp555
Member#: 80754
1995 Impreza 1.6GL
Yep the 1.6 sold better than the 1.8 in the UK, despite the lowly 88bhp! We had them in bug-eye shape too but now there are only 2.0 N/A or Turbo and we're soon to have the 2.5 STi.
If you have a diagram for an EJ18 with an N3 ECU that would be very useful, cheers.
Old 09-14-2005, 07:04 AM   #21
t3hWIT
Member#: 58779
95 STi RA (rhd)
bit sure what u mean about the N3 ecu. how would i tell?
also, im bumping the spark plug question from post #16.
Old 09-14-2005, 11:09 AM   #22
jamp555
Member#: 80754
1995 Impreza 1.6GL
There is a sticker on the ECU, they are generally known by the 2 digit code in the top left corner, N3 in my case. Here's a pic of mine:
http://members.lycos.co.uk/subaru/scoobynet/Ecu.jpg
Sorry I don't know about your spark plugs idea. I wouldn't want to risk it as an alternative to wideband tuning though. I've been told the S-AFC can only take an hour to dyno tune - if that's true it'll cost me 75 or ~$140, a price worth paying I think especially as I'll get before and after power graphs so I'll know whether I've wasted my money or not
Old 09-14-2005, 04:43 PM   #23
t3hWIT
Member#: 58779
95 STi RA (rhd)
just noticed... the safc i have has 11 wires, not labeled, nothing in the manual. anybody have a diagram of what they're supposed to go to?
Old 09-18-2005, 10:59 PM   #24
t3hWIT
Member#: 58779
95 STi RA (rhd)
Hopefully the last question, as the install is this coming weekend.
The safc has a wire for the knock sensor. the 1.8 doesnt have it. can this still be installed correctly, albet with more minor tuning?
or should i/could i pul the one from the 2.2 and somehow get it working...
um... help?
im assuming that i just dont use the knock sensor wire, but i wanted to run it by you guys first.
thanks for all the help here
Old 09-23-2005, 09:43 PM   #25
t3hWIT
Member#: 58779
95 STi RA (rhd)
Installed. Had a problem, fixed it, but now I am in limp mode. Performed a search, couldn't find anything helpful, how do I get out of it?
95 1.8L for sale, pick up only 2slofouru Private 'For Sale' Classifieds 1 08-03-2005 09:16 AM
A/C not working, 95 1.8L Impreza germanturbo Normally Aspirated Powertrain 8 06-27-2005 06:59 PM
FS: 95 1.8L engine Aspen_2.5RS South East Region Forum 11 11-01-2003 07:49 AM
FS: 95 1.8L engine Aspen_2.5RS Private 'For Sale' Classifieds 1 10-29-2003 11:22 PM
2.5 L Engine into a 95 1.8L PumpsGOTAWD Subaru Conversions 4 08-04-2003 07:58 PM
