Old 09-06-2005, 08:22 PM   #1
Annoying Eric
Member#: 94074
Default Idle problem after blowing SBF5
1998 Subaru Impreza L Wagon:
Background:
I was experiencing some stalling/sputtering/sluggishness when it rains, so I figured the spark plug wires were arching. I replaced the spark plugs and wires and the car ran better then ever before.
Two days later in the morning I started the car and it immediately stalled. I tried again and it started, still running strong. I stopped at a gas station to pick up some coffee, left the car running. Come back and leave the gas station, the car is still running strong. 5 minutes later I’m going about 30mph and the engine stalls, check engine light turns off; I pull it to the side of the road.
It turns out the SPF-5 fuse popped: causing no fuel/spark/start, it will crank. I unbolt the main fuse box to find out what wire is causing the fuse to pop. It is the black and red wire going to the: main relay, fuel pump relay, ecm, and data link connector (OBD2). It blows whenever the key is on the “on position”.
I unplug the ecm and turn to “on position”: fuse does not pop.
I swap the ecm with another I bought a salvage parts yard: still pops when plugged in.
I unplug the fuel pump: still pops.
I unplug both O2 sensors: fuse does not pop.
I plug back in the fuel pump: the car starts and runs, but the idle is funny: hanging around 1300/1400 rpm.
I plug back in the O2 sensors: the car starts and runs, but the idle is funny: hanging around 1300/1400 rpm.
New Problem:
Now everything is the way it was when I was blowing fuses except now it doesn’t blow and there is a weird idle.
Idle video: www.raynorsyr.com/sub-rpm.wmv
^it jumps up and down between 1300 and 1400 rpm, when cold or warm.
So there had to be a short somewhere right? Maybe at the fuel pump, it was pretty dusty and I cleaned the connector as much as I could. I must have gone through 12 fuses until I bought a 30a circuit breaker and popped that many times. I really don’t know, but the car is running great except for the idle problem, some sluggishness but not bad.
I have a check engine light….7 codes total that were erased except 2:
P0135 – Front Oxygen Sensor Heater Circuit Malfunction
P0141 – Rear Oxygen Sensor Heater Circuit Malfunction
P0183 – Fuel Temperature Sensor A Circuit High Input
P0443 – Evap System Purge Control Valve Circuit
P1102 – Pressure Sources Solenoid Valve Circuit Malfunction
*P0505 – idle control system malfunction
*not able to erase.
I hope I was descriptive enough, it's going to the dealer soon if I can't figure this out. Thank you for all your help.
AIM: s0dium22
Annoying Eric is offline   Reply With Quote
Old 09-06-2005, 08:26 PM   #2
Annoying Eric
Member#: 94074
s0dium22 doest work for some reason...try:f1ip0ut
Old 09-06-2005, 08:38 PM   #3
Annoying Eric
Member#: 94074
i am never posting a screen name again....I'm getting locked out of aim
Old 09-07-2005, 08:28 AM   #4
Ramon_12345
Member#: 72021
1999 JDM GC1 IMPREZA
WHITE
I am glad to see that you apparently got the short-circuit problem rectified.
I would suggest that you make a simple check to ensure that all of your vacuum hoses are connected since this can cause an erratic idle and it could be possible that a hose could have come loose while you were working in the engine bay with the fuse/breaker.
Ramon_12345 is offline   Reply With Quote
Idle problem after Tial Q Bov Install fl4tsc Newbies & FAQs 51 05-14-2012 09:21 PM
idle problem after replace radiator??? sum0325 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-12-2009 02:19 PM
Idle Problems after Spec-c intake manifold install wrxwagon253 North West Impreza Club Forum -- NWIC 16 11-03-2007 04:49 PM
massive idle problem after violent axle brake?? imprezaRS420 Legacy Forum 3 12-27-2006 10:57 PM
Idle problem after ECU reset Spectre23 Technical Forum Archive 1 05-19-2000 12:42 AM
