#1 |
Member#: 90826
Vehicle:1997 -S14, +GC8 -blue, +grey |
Hey guys... just wanted to inquire upon your wisdom regarding underboosting.
I've searched the forums and could not find anything specific to my problem but close, and i have looked into the few possibilities that were laid out but have yet to solve the problem I have a jdm v.5 sti motor, 2 days it ago it was making 17psi-19psi max boost depending on gear and rmp. Yesterday while driving down I270 and hitting WOT i noticed it was a lil slower. I checked the boost and i was only getting about 10psi or so. So what ive checked so far is driving until i hit full boost, i hit full boost right now at 10psi around 3500-4000 rpm which was normal when i was able to boost at 19psi. But instead of the boost climbing it stops at 10psi. Driving up until then 10psi and up the rpm feels normal, the motor still pulls like before. its just the boost stops at 10psi. So we visually checked the vaccum hoses, no disconnections or visual leaks. Intercooler and everything looks fine. I even emptied the oil catch can, but the can didnt seem clogged or anything, air can freely move in it. I then check the intake and noticed that the clamp from intake to turbo was broken, so i tighten it. check everything else. Reset the ECU and drove... Since there was no intake leak anymore the cars response was better, but then the underboost issue is still there. I know that underboosting can be caused by wastegate, blow off valve or bad boost solenoid other than vacuums. Is there any else i can do to check or any other factors i can look into and ways to check these mechanical issues so that i get my boost back? any help is appreciated, thanks guys. -peter.
#2 |
Member#: 29201
Vehicle:BMW M3 Honda S2000x2 |
I don't want to scare you but you should do a compression check if the hose (rather than the clamp) came off the turbo inlet. The turbo will pull in un-metered air that the MAF didn't read. You could have been running dangerously lean.
About the boost, 10psi is roughly wastegate boost. So you could have an electrical problem, rather than a vacuum problem. Hook up a scan tool and see if there are any codes. Check your wiring going to the wastegate solenoid. An EGT too high code, from running lean, may cause the ECU to limit boost to wastegate boost. Pete |
#3 | |
Member#: 90826
I just fixed the clamp and tightened it. And its a jdm ecu and the obd II will not read. so scanning wont work. Last edited by peters14gc; 09-06-2005 at 10:01 AM. |
#4 |
Member#: 90826
thanks for all the advice guys... im actually boosting normally now. I guess sundays ECU reset took some time to figure things out after i fixed the intake issue.
feels good around 17-20psi again. |
| Thread Tools | |
| Display Modes | |
| MD: Gauging interest in JDM Forester 2.5 shortblock (same as STi) with ~4000 miles | StealthWRX | Private 'For Sale' Classifieds | 37 | 01-12-2006 09:33 PM |
| Gauging interest in JDM Ver. 5 WRX motor | b57m57w57 | Private 'For Sale' Classifieds | 48 | 11-12-2005 01:56 PM |
| underboosting in a jdm sti v.5 motor. | peters14gc | Factory 2.0L Turbo Powertrain | 11 | 09-07-2005 12:11 AM |
| underboosting in a jdm sti v.5 motor. | peters14gc | Mid Atlantic Impreza Club -- MAIC | 4 | 09-06-2005 09:27 PM |
| 04 JDM Sti headlight in an 04 2.5 RS? | digi | Interior & Exterior Modification | 11 | 11-30-2003 05:18 AM |
