Old 09-07-2005, 01:04 AM   #1
ronf
Member#: 51034
03 WRX, 02Forester
Default Tires for 04 sti BBS wheels , any advantages of 215 over 225 ?
215 or 225 ?
thanks
ronf is offline   Reply With Quote
Old 09-07-2005, 02:01 AM   #2
beastSTI
Member#: 87633
2005 Impreza WRX STI
Do they make all season for BBS? I would get those. Thanks
beastSTI is offline   Reply With Quote
Old 09-07-2005, 08:50 AM   #3
REX8
Member#: 24038
You'll get a wider (not bigger) contact patch with the 225's. That will give you more lateral grip. Depending on how you drive your car, you may or may or may not notice.
Old 09-07-2005, 09:37 AM   #4
dbrier
Member#: 6598
2012 Mazdaspeed3
Crystal White Pearl
There are only two advantages I can think of if both tires fit and don't rub.
1. Cost
2. Better winter traction.
I would go wider, especially on the BBS wheel.
dbrier is offline   Reply With Quote
Old 09-07-2005, 12:29 PM   #5
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Wider. Heck I run 235/45 17's on my 04 STi for all season tires.
-Clint
Old 09-07-2005, 04:17 PM   #6
Len
Member#: 39937
2011 328i 6MT
LMB
225 also gives you slightly larger diameter that is actually very close to stock. But they are more expensive, heavier, and may rub on the wagon. I went with 215's on 04 STi BBS rims on my wagon and I'm very happy with them. Plus the fact that they are about 2% smaller means you get 2% faster acceleration.
Len is offline   Reply With Quote
Old 09-08-2005, 12:18 AM   #7
sjrhee
Member#: 68010
2004 WRX w/ Cobb 2.5
-Clint
I agree, I just got the same size after driving my friend's wrx with 235's definitely more contact patch and less squeal. Now if I can just get 4 tires out of my room ...the rubber smell is getting to me
sjrhee is offline   Reply With Quote
Old 09-08-2005, 12:23 AM   #8
ronf
Member#: 51034
03 WRX, 02Forester
-Clint
but how about acceleration response ?
Old 09-08-2005, 01:06 PM   #9
HerculesPeanut
Member#: 35421
2003 WRX
W R Blue
I chose 215 over 225 mostly due to reduced weight. My 215s were 3lbs/corner lighter. Having a very slightly lower gear was not a bad thing either.
HerculesPeanut is offline   Reply With Quote
Old 09-08-2005, 01:13 PM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
.....d00ds ! ! ! ! !! ! !
....do NOT try to compare gearing between an STi and a WRX ! ! ! ! ! !! !
the STi is better off with a bit taller tire....the WRX NOT.
Old 09-08-2005, 01:28 PM   #11
HerculesPeanut
Member#: 35421
2003 WRX
W R Blue
Scotty brings up a good point. Maybe we should clarify things here. I assume from your post and your info that we are discussing a WRX with STI 17" wheels.
Perhaps you should confirm that.
Old 09-08-2005, 01:44 PM   #12
ronf
Member#: 51034
03 WRX, 02Forester
as you can see from my profile --03WRX and it's a 4eat
so probably i should go with 215s for better low end response ?
mmm.. more likely to get curb damage with 215..?
Old 09-08-2005, 02:08 PM   #13
Uncle Scotty
Member#: 16200
OK buy Nates beans
....turn in concepts seems to not have read the thread.....and intrejected confusing information, here.
for an AT WRX.....I would MOST definitly use a 215/45....and .....forget curb damage...and just don't hit them....jesus.........
...and I would NOT use STi wheels for winter wheels, anyway...get some cheap junk wheels for winter duty and don't kill the nice bbs wheels with all the winter crap.
Old 09-08-2005, 02:22 PM   #14
Gunner
Member#: 36540
04 GGA
Cobb Stage 1 EQ Tuned
The stock 070 225 tires with the STi wheels on my 04 wagon doesn't rub at all because the offset is correct. People who has rubbing problems are those who use the Rota wheels which doesn't have the correct offset with 225 wheels and need to roll their fenders.
Gunner is offline   Reply With Quote
Old 09-08-2005, 08:12 PM   #15
Len
Member#: 39937
2011 328i 6MT
LMB
I would like to think so, but some tires are just wider than the others. I did quite a bit of searching when I was in the market, and while what you said was generally true, there were a few exceptions and I couldn't convince myself that 225's most definetely won't rub.
Old 09-08-2005, 08:25 PM   #16
Uncle Scotty
Member#: 16200
OK buy Nates beans
...the wheel offset REALLY makes a difference....a +48 might rub where a +53 won't(5mm difference)....same tire.....wheel choice is FAR more important than tire choice.
Old 09-09-2005, 09:16 AM   #17
dbrier
Member#: 6598
2012 Mazdaspeed3
Crystal White Pearl
Scotty has it right (again)
The wagon owners have issues with 225 on +48 wheels. Some rub, many others don't. It makes things confusing as they argue and hand out advice.
Once you move to the correct offset (+53), the discussion stops - all 225 fit.
Old 09-09-2005, 03:04 PM   #18
alien
Member#: 82721
2011 WRX STI Sedan
I've read a lot of threads, done a lot of searching... inevitably, I'm missed the answer to my question somewhere. I'll ask anyways. What are the pros/cons for 215/45R17 vs. 225/45R17 for the 5MT WRX sedan?
I'm deciding between 17" Gram Light 57S, 57C (7.5" wide) or Prodrive P-WRC1 wheels for next spring, going to run my stock RE92s through winter and then put winter tires on the stock rims probably next winter season. If could pick up a set of STI BBS wheels for cheap, I'd consider it, but the basic debate remains the same regardless of wheel choice (AFAIK). Any advice you guys can offer is appreciated.
alien is offline   Reply With Quote
Old 09-10-2005, 03:35 AM   #19
Uncle Ben
Member#: 28628
2003 WRX Sedan
World Rally Blue Pearl
Too bad +53 aesthetics wise doesn't look as nice as a slightly lower offset wheel. I just dislike that stock sunken-in appearance.
Uncle Ben is offline   Reply With Quote
Old 09-10-2005, 01:57 PM   #20
Uncle Scotty
Member#: 16200
OK buy Nates beans
....and maybe you shouldn't be so worried about what it looks like....that is a way to common affliction of the kiddie generation, here.....
....caring too much about what others think is a bad mindset to get stuck in, too.
Old 09-10-2005, 05:50 PM   #21
HerculesPeanut
Member#: 35421
2003 WRX
W R Blue
Very true.
Old 09-14-2005, 12:48 PM   #22
subieworx
Member#: 47769
Sure is, but there is nothing wrong iwth having some pride in your appearance. Just don't let it go to your head.
subieworx is offline   Reply With Quote
Old 09-14-2005, 01:39 PM   #23
ronf
Member#: 51034
03 WRX, 02Forester
thank you all !!
WTB: 04 STI BBS wheels any color (4) bigsur1997 Private 'Wanted' Classifieds 0 12-09-2009 09:59 PM
Wheel spacers for 04 STI BBS wheels 2006subaru Tire & Wheel 16 06-15-2009 11:39 AM
For Trade:CA: Rota P1 18s (Tommy Gold) For 04 STi BBS Wheels SpADeZ_WRX Wheels/Tires 4 12-29-2008 12:15 AM
For Trade:CA: Rota P1 18x8 Tommy Gold For 04 STI BBS Wheels *Pixs* SpADeZ_WRX Wheels/Tires 9 03-24-2008 10:58 AM
WTB set of Gold 04 STi BBS wheels (<200 mi of Denver CO) IIcx Private 'Wanted' Classifieds 1 11-14-2006 08:48 PM
