Welcome to the North American Subaru Impreza Owners Club Friday August 28, 2015
Old 09-07-2005, 11:07 AM   #1
nutzkicker617
Member#: 63255
2007 M Coupe
Alpine White
Default COBB AP fix up pipe cel?
im goingto finally get my up pipe and was wondering if i need a cel fix or does the AP stage 2 map 91 oct fix that alraedy?
CEL Codes Defeated [WHEN USING AS BASE MAP]
(** means new to latest revision):
P0037 - Rear O2 Sensor Heater Control Circuit Low **
P0038 - Rear 02 Sensor Heater Control Circuit High **
P0136 - Rear O2 Sensor Circuit Malfunction **
P0139 - Rear O2 Sensor Circuit Slow Response **
P0420 - Catalyst System Efficiency Below Threshold
P0545 - Exhaust Gas Temperature Sensor Circuit Low
P0546 - Exhaust Gas Temperature Sensor Circuit High
P1301 - Misfire Detected (High Temperature Exhaust Gas) **
P1312 - Exhaust Gas Temperature Sensor Malfunction **
P1544 - Exhaust Gas Temperature Too High **
thanx!
nutzkicker617 is offline   Reply With Quote
Old 09-07-2005, 12:30 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
Cobb recommends that you put the restrictor in any way
you don't need it to .. the cell won't flash but the ecu still references the egt sensor for some closed loop fueling parameters
Old 09-07-2005, 12:57 PM   #3
WRXSleeper
Member#: 43853
2004 WRX Sedan Stg 2
Platinum Silver
for $.99 for 5 resistors and 5 minutes of your time just fix the cel cause you may sell the AP and need to do the fix it anyways.
WRXSleeper is offline   Reply With Quote
WTB:17x7.5 Alloys 48-53mm 5x100, xftrmrkt catless up pipe, CEL fixes, short shifter, QuikWgn NWIC Private Classifieds 2 07-16-2006 02:43 AM
can cobb AP clear/read ecutek CELs? swift2fly Engine Management & Tuning 13 06-20-2006 09:59 PM
Will COBB AP fix the CEL with HELIX DP? BBBsti LTD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-02-2006 11:07 PM
Will AP Remove Up Pipe EGT CEL? Killian Maynard Engine Management & Tuning 14 01-10-2005 09:44 AM
Up-Pipe CEL Fix. Who's Done it? mav1c Mid Atlantic Impreza Club -- MAIC 8 12-19-2003 03:56 PM
