Old 09-07-2005, 02:38 PM   #1
012.5RS
Member#: 95051
02 WRX Wagon
World Rally Blue
Default Turboing A N/A 2.5L
I am thinking of turbocharging my RS. Who's kits would you reccomend and where could i get them? My car has 83k miles so would i need to rebuild the internals? I'm figuring i will. And if so who would you reccomend for the internals? I'm planning on all forged. Also what boost would you reccomend when im done?
012.5RS is offline   Reply With Quote
Old 09-07-2005, 02:43 PM   #2
AaronWRX
Member#: 7194
2011 997.2 Turbo
dont be foolish. Do an engine swap.
AaronWRX is offline   Reply With Quote
Old 09-07-2005, 02:51 PM   #3
impr25rs
Member#: 60162
04 Aspen RS
The One Not Turbo'd, NA!!
Look in the aftermarket forced induction forum for info
impr25rs is offline   Reply With Quote
Old 09-07-2005, 04:09 PM   #4
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
No-dout....on what AaronWRX says
Hold out for a long or short block depending on your $$$ situation. I got my hands on a STI long block with ECU and full harrness w/1500 miles for only $3000. ( no turbo or TMIC ) That is what it will run you to buy internals and true out your cylinder walls and get it all rebuilt. But in the end it always falls on CASH flow and what U want
By the way......I got JE 2.5L pistons w/ rings and con rods to sell you if U do a build. I was goin down the road you are thinkin of till I came appon the STI block. I'll even drop em off you aint far away.....$350...........PM me if interested
dangerousatom is offline   Reply With Quote
Old 09-07-2005, 04:50 PM   #5
jnorth85
Member#: 76785
2000 580Whp The RSTI
SRP
what they say motor swap if you dont do it now you will later on.
jnorth85 is offline   Reply With Quote
Old 09-07-2005, 05:27 PM   #6
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
How much boost do you WANT to run? The AVO turbo kit is a set it and forget it setup that will give you 5-6 psi of boost. This will make you faster than a stock WRX, without the tons of lag of the WRX. If you don't get any more power hungry than that, then you won't need new internals. But if you want more power than that, engine swap is just as easy
www.rallitek.com for the AVO turbo kit
Old 09-07-2005, 05:33 PM   #7
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
my kit is always an option as well
http://forums.nasioc.com/forums/showthread.php?t=805127
Ben
Old 09-07-2005, 07:33 PM   #8
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
None!
This depends on how much boost you plan on running.
All forged internals? Who know's! Tranny, fueling and engine management plays a major role when you start pushing the boost. 5-6psi of boost to play it safe and your car will be fast enough. It gets addictive.
Kevin Thomas is offline   Reply With Quote
Old 09-07-2005, 09:01 PM   #9
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
'96 BrightonCoupeWRX-SR30
Legacy
wow..cus hes not here allready!
Kawikid20o2 is offline   Reply With Quote
Old 09-07-2005, 10:21 PM   #10
Master2192
Member#: 83254
98 2.5 RS
04 WRX
Someone moved it here...
Old 09-07-2005, 10:54 PM   #11
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
Legacy
my bad i dont see anywhere that it was moved i thought it usually says that on the thread title. but what ever
Old 09-08-2005, 08:53 AM   #12
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
In the next couple of months my shop will be developing new kits that will be very competitive with current offerings.
Drac9 is offline   Reply With Quote
Old 09-19-2005, 07:33 AM   #13
012.5RS
Member#: 95051
02 WRX Wagon
World Rally Blue
http://www.rallitek.com/products.asp...Y&HB=&ACC=&SP=
is this just the turbo or the whole setup?
Old 09-19-2005, 10:00 AM   #14
leondal
Member#: 43114
1998 Legacy GT Turbo
Green
How about, instead of just giving our lame opinions, and being
ridiculously pessimistic and snide about this, we actually help
him out:
There are a number of options:
1) A good start would be to read some of the older posts in here
and do a search for this. Honestly, there are tons, and I mean
tons of posts about this.
2) A second good resource is Unique Motorsports. You can get to them
at http://www.uniquemotorsports.com. They have a lot of info on
making your own turbo setup.
3) There are several places that make turbo kits for the RS, to include
Forced Air Technologies http://www.forcedairtech.com and AVO, which
can be purchased at SPO Motorsports http://www.spomotorsports.com
There are a few more which are outlined in the various posts.
4) A supercharger is an option, but there are very few prefabbed kits
out there for subarus. Again, there are a couple very lengthy threads
here about superchargers.
Turbo lag is relative, and honestly, going from NA to turbo doesn't add
any lag, because being NA is like having lag that never ends. It'll just
adjust your power band so that after 3000 RPMs, you'll really have power.
leondal is offline   Reply With Quote
Old 09-19-2005, 11:38 AM   #15
Sko
Member#: 90396
2005 Legacy 2.5i
Brilliant Silver Metallic
Just a turbo. The momentum EJ5-40T is capable of 400hp at half the price.
Sko is offline   Reply With Quote
Old 09-19-2005, 01:33 PM   #16
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
PM me with specs and more information. I might be interested...
Old 09-19-2005, 01:59 PM   #17
thehatchninja
Member#: 96129
just piece your own kit together and don't skimp on tuning, and don't run more than 8 psi.....you'll be fine
thehatchninja is offline   Reply With Quote
Old 09-19-2005, 09:06 PM   #18
012.5RS
Member#: 95051
02 WRX Wagon
World Rally Blue
sorry man i already called dibs on them. and hopefully will be picking them up on sat.
im looking for maybe like 300hp/300TQ at the wheels... now im used to V8's so you'll have to excuse me, will running 8psi enable me that kind of power? I'm buying the pistons/rings/rods of dangerousatom. They are JE's(which i know from drag racing my ponchos are great pistons) stock bore(for what im getting em for i dont care about not boring it out), they are forged good up to 30 psi and are N2O friendly. Dished out for a DOHC head like the WRX or STI but from what I understand they can be used in a SOHC head setup like in a NA 2.5RS. The pistons will take the block to 8.5-1 compresion. The rings that he got with them were Turbo Nitrous(im assuming moly) for heavy boost and an optional shot of N2O.
Now how high might it raise the cr from 8.5 under 8-10psi? Does anyone have a website that has calculators for this? Can i bolt the DOHC head to my short block? Also pls lemme know any odd ball stuff that i might need. I still wanna get a forged crank, does anyone know of a company that makes them? i know i gotta upgrade spark and fuel... duh. But hopefully when im done ill be dancing like this...
I found these two kits from Forced Air: both 5psi
http://www.forcedairtech.com/turbokits_gc8_stage1.html
http://www.forcedairtech.com/turbokits_gc8_stage2.html
There is also this AVO kit:
http://www.spomotorsports.com/Catego...tomerID=336143
its like $1500 more than the stage 1 kit. i think it might be worth the extra money for reliablity and power sakes.
Is the intercooler worth the extra $1000? I know sometimes ive seen it where the intercooler will actually make a car slower if it is running low boost like 5psi. Also im sure the pistons and rods im getting will handle a baby 5psi. Do you think its worth buying a forged crank for this little boost? Can i always boost the psi up? This seems like a good deal since its everything you need. I think ill probably go with the stage 1 since this will be a daily driven car.
Old 09-20-2005, 01:26 PM   #19
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Intercooler is more for reliability in a changing environment (or hot climate) at 5psi or so. Apparently the intercooler itself is not cheap and of course people will make a bit of money on top of it. I'm guessing you're building up your EJ251 instead of swapping in an EJ257? I'm not sure if it's wise to do that when you're trying to get 300whp - you're lowering your compression so you would need to run about 14psi or so to be near the STi power level (STi runs 8:1 and 14psi and their heads probably flow better than the stock SOHC head)
kgb is offline   Reply With Quote
Old 09-20-2005, 08:10 PM   #20
012.5RS
Member#: 95051
02 WRX Wagon
World Rally Blue
can i put the DOHC head on my short block?
Old 09-20-2005, 09:10 PM   #21
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Yes, but it's more trouble than its worth because your stock ECU won't know how to fire that
Old 09-20-2005, 11:50 PM   #22
012.5RS
Member#: 95051
02 WRX Wagon
World Rally Blue
well i can always port my head, and to up the cr i can just mill the head so i wont have to boost 14psi
Old 09-21-2005, 12:25 AM   #23
Boom05rs25
Member#: 95157
05 Impreza RS 2.5
OBP 5spd Winged
Boost it......Do it right!"low to moderate boost" When you fry the rings have local machine shop you trust,rebuild the stock block with forged crank,rods & lower compression forged pistons"run about 2k. Dont waste thousands off dollars and countless hours on a clip swap or sti block swap. Short block rebuild will net you way better pay-off with a real performance build. This is if you can handle an engine pull and tune yourself ,If not...Then yes a clip swap is a good option for you
P.S. Keep SOHC, less parts=cheaper in the long run and they flow close to the same anyways, dont mill the head its just asking for trouble....the idea is to lower compression...unless you like 108 octane gas. EJ251 has 10:1 you dont want to increase that,thats were detnation occurs
Edit: This is all "IMO" its also my plan.
Boom05rs25 is offline   Reply With Quote
Old 09-21-2005, 06:47 PM   #24
012.5RS
Member#: 95051
02 WRX Wagon
World Rally Blue
thx for the support man. I'm getting JE forged pistons that drop it to 8.5:1 cr. is that a good range? I wanna get a kit from Forced Air Technologies that is 5psi and adds approx 60-80hp. Of course the turbo comes after the TWE Stage II Cams and Stage II Head. I'm getting the JE forged pistons, rods and rings from a member here on sat for $350. Then all i need it the crank for the bottom end. I figure with the forged internals i can bump it to 10psi max and reach atleast 300hp.
Old 09-21-2005, 08:31 PM   #25
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
If you drop from 10:1 down to 8.5:1, you lose some low end. At 8.5:1 I believe you need quite a bit more than 10psi to reach 300 at the crank.
Dyno Tune: 2.5L Shortblock + VF39 = 270hp/310tq w/ 91 oct (05 WRX) Kenji815 Proven Power Bragging 28 06-19-2010 07:21 PM
WTB: Stock mount turbo for '02 WRX 2.5L hybrid - looking for 18G or 20G mainly. tundra Private 'Wanted' Classifieds 8 08-08-2009 09:05 AM
V2 Accessport for 2.5l 04-07 STi, 04-06 LGT, 2.5l Turbo metros MAIC Private Classifieds 1 05-06-2009 12:39 PM
Subaru 2.5L Turbo Wins 2008 International Engine of the Year in 2.0L - 2.5L Category Jon [in CT] News & Rumors 19 05-08-2008 03:52 PM
89 xt turbo on a 98 2.5L? farrell Normally Aspirated with bolt-on Forced Induction Powertrain 3 08-04-2004 10:04 AM
