Old 09-07-2005, 04:44 PM   #1
smyth
Member#: 42243
2003 Impreza WRX RIP
1996 Impreza L- Blown Eng
Default a little help with finding out where i can get a short block
hey i'm thinking of building up the engine in my old subaru. its a 1996 impreza 2.2L. unfortunately though the block is split. i was thinking about getting a v7 sti motor for it however i've reconsidered because i'd rather not have to redo the entire wire harness. instead i plan on purchasing a 2.2l short block and then building that up, installing turbo/ic/engine managment/forged internals/etc. anyone know a good place with good prices to get either a used or new 2.2 short block. i don't want a 2.0 with the displacement increased to 2.2 because then i still run into the harness problem. any help would be greatly appriciated.
thanks
kyle
smyth is offline   Reply With Quote
Old 09-07-2005, 07:05 PM   #2
InsaneAznKid
Member#: 57037
1998 Audi A4 1.8T
Pearl White
I'll have a 2.2L Longblock at the end of this month or middle, planning on having my engine swapped this month.
lemme know if your interested.
-Eric
InsaneAznKid is offline   Reply With Quote
Old 09-07-2005, 11:12 PM   #3
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Try getting in contact with crawford performance. I believe they are a vendor on this forum.
Good stuff.
Tim Sanderson is offline   Reply With Quote
Old 09-08-2005, 10:06 AM   #4
smyth
Member#: 42243
thanks.
Old 09-08-2005, 11:27 AM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
smyth,
For starters, you will get a lot more information in the proper forum. Aftermarket Forced Induction is where this sort of project belongs. Aside from that, I think you need to spend some time doing more reading. Where did you get the idea that you can use a 2.2l bottom end without wiring, but that a 2.0l bottom end requires it? That just makes no sense. Shortblocks have nothing to do with engine management!!!
Regardless of what bottom end you use, you will need a bare minimum of an AFC, RRFPR and a boost controller to make your project at all driveable. An E-manage or a Perfect Power would be a far better solution, but guess what? That requires wiring. Nothing at all like the wiring of a factory style engine swap, but you are still in there cutting up your harness. Like I suggested above, head over to AFI and do some reading. There have been 4-5 threads in the last month real similar to your ideas, so don't start a new one. And in case you are getting defensive, I am not trying to be harsh. I am just offering the path of least resistance with the quickest learning of what this requires. And if you are looking for any parts, PM me. I just pulled apart a turbo'd Impreza L cuz the motor popped...
Old 09-09-2005, 11:20 AM   #6
smyth
Member#: 42243
soory i worded my situation improperly actually. what i want to do it get a 2.2l block to just drop in it now so i can drive it, then tear out my 2.2 and see if its fixable, then build that. when the built engine goes in i'd do the wiring. right now i just want a stocker that runs. i know excactly what you're saying and you're 100% right, it was my fault for a misleading description.
thanks
kyle
no being definsive here, i appriciate the help.
OT: Find out where I can watch A Christmas Story at work BigWrecKs Off-Topic 14 12-24-2008 02:12 PM
xGames 14 Tickets and MEET - Find out where to get free tickets p8baller07 Southern California Impreza Club Forum -- SCIC 97 07-29-2008 04:40 AM
local help with finding a 2.5 ltr long or short block OvrClkdPmp MWSOC Private Classifieds 8 07-25-2007 10:14 PM
need a little help with finding a pic ramrod Member's Car Gallery 2 01-27-2006 10:16 PM
